Mystery Washer in Oil Pan - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 11 Old 16th April 2019, 04:22 PM Thread Starter
KrautHammer
KrautHammer's Avatar
@herrubermensch
Removed my oil pan to check for timing guide debris and repair a drain plug thread that started to feel "soft." I was relieved to find no plastic debris or metal shavings at all! However I did find this rather large washer, and proceeded to panic. I see no such washer in the vicinity on the diagrams and was hoping one of the engine builder experts could chime in....Peter?
2002 Beast Schwarz-Metallic/Blk Sport
KrautHammer is offline
post #2 of 11 Old 16th April 2019, 05:20 PM
Sailor24
Sailor24's Avatar
Stick a long magnet all the way to the back of the motor. Things don't drop and stay. Can you clean and shot two more pics of the washer on white paper, one each side, need to see marks or damage on route to the pan.
Then take one more pic on the ruler but do it on the metric side of the ruler, it is German and all the specs are in MM.
When you are done all that look up at the oil pump. There are no marks from falling thru chains so it must have lived low, appears to be too big to fall thru a port in the head, sort of leaves oil pump, but not all parts of something show-up in realoem, because they are part of a unit and not sold separately.
Sailor24 is online now
post #3 of 11 Old 16th April 2019, 10:06 PM Thread Starter
KrautHammer
@Sailor24
OD 22.987[mm]
ID 15.52[mm]
Thickness 2[mm]
On close inspection it looks like it got bounced around a bit on its journey to the lower pan. Item 7?
post #4 of 11 Old 17th April 2019, 07:21 AM
Sailor24
Sailor24's Avatar
Could be 7, no specs for 7 so... It does not look like a bolt washer, first no 15mm bolts, but it has no marks like it was compressed by a bolt. If it was 7 I would suspect some plastic in the pan, it had to fall off?
It looks more like a banjo bolt washer but it is not the right material, looks like steel, is it magnetic?
It is definitely a strange part.
post #5 of 11 Old 17th April 2019, 07:04 PM Thread Starter
KrautHammer
Its zinc plated steel and 2[mm] thick so its not a banjo crush washer.
Thanks for looking into it.
post #6 of 11 Old 18th April 2019, 05:45 PM
herrubermensch
It's not 7. 7 is tiny.
That washer looks like the one that goes on the end of the dipstick, right above the upper oil pan. That would make sense, as that large a washer almost certainly would have wreaked serious havoc had it come from a position higher up in the engine.
--Peter
herrubermensch is offline
post #7 of 11 Old 18th April 2019, 06:22 PM Thread Starter
KrautHammer
--Peter
Item 15?
Yeah that makes more sense, not sure how it would get into the pan unless a previous technician dropped it and said "F'it" oil pickup wont suck it up so...going to lunch. I will check for the presence of the dipstick washer in it's proper position this evening.
I removed the oil pump sprocket cover to get a look at the lower chain tensioner and inspect for wear, it looks brand new, no grooves. I am concluding that the previous owner replaced the chain guides but will confirm this when I PM VANOS seals and rod bearings @100k. Car was exceptionally well maintained but, dealer purchase so no records. Right now the valve train is whisper quite and the engine runs perfectly, oil analysis is clean, no guide pieces in pan, if it ain't broke...
Thanks all
post #8 of 11 Old 18th April 2019, 07:17 PM
herrubermensch
Originally Posted by KrautHammer View Post
Item 15?
Thanks all
Yep, 15 looks like it to me.
--Peter
post #9 of 11 Old 18th April 2019, 08:16 PM
Trizzuth
Trizzuth's Avatar
I was originally thinking crush washer for oil pan bolt, but how the heck would that get in there when the washer goes on the outside?? Good diagnosis gents, great idea to check for presence of the dip stick washer too, and if you can get it out of there and it does exist at least you can compare the two side by side to see if the look the same.
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #10 of 11 Old 18th April 2019, 10:36 PM Thread Starter
KrautHammer
Much better than the oil pump sprocket thrust washer I assumed it was before looking at the diagrams and realizing no such thing exists...
Concerns have been alleviated provided the dipstick tube is sealed up adequately.
My new (to me) e60 M5: Tire Tracks on the soul gmak E60 M5 and E61 M5 Touring Discussion 183 14th May 2019 12:44 PM
E60 For Sale: FS: E60 M5 Oil Pan *CHEAP* Showstoppa Parts / Other For Sale or Wanted 1 14th November 2011 06:39 PM
Intersting read on oil consumption jt2ma71 E39 M5 and E52 Z8 Discussion 7 18th August 2011 08:01 AM
What oil? CSLjimmy E60 M5 and E61 M5 Touring Discussion 16 19th May 2009 10:01 PM
