Little Guidance on T-stat replacement - BMW M5 Forum and M6 Forums
post #1 of 4 Old 16th April 2019, 07:08 AM Thread Starter
cal45fan
Well, the obvious thermostat and seal is needed. Iíve read I need 6 other seals that go on the pipes.
Does anyone have the part numbers and quantities? Thank you.
cal45fan is online now
post #2 of 4 Old 16th April 2019, 09:51 AM
BreakMyWindow
BreakMyWindow's Avatar
BreakMyWindow is offline
post #3 of 4 Old 16th April 2019, 11:07 AM
gsfent
gsfent's Avatar
2 small pipes, 1 large pipe. So 4 and 2 (one at each end of each pipe). Get extras. Cheap enough to have on hand. The smaller ones especially are prone to tearing.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
post #4 of 4 Old 17th April 2019, 03:56 AM
lovesm3s
lovesm3s's Avatar
Look up some videos on youtube. E39source has a video which all the part #'s are displayed on the video. I would get extra just in case. I ripped one putting it in. fairly easy to do but tedious
18 x5 Mineral White/Mocha
04 M3 LSB/LSB
01 M5 Carbon Black/Imola
98 328i Arctic Silver/Dove
lovesm3s is offline
DIY - S62 V-belts replacement and fan clutch replacement. J Irwan E39 M5 and E52 Z8 Discussion 56 8th May 2017 12:17 AM
Temperature sensor replacement question Dr.K E39 M5 and E52 Z8 Discussion 14 2nd November 2010 11:04 AM
Jlevi SW | Carbon Fiber & Monochrome BMW Replacement Roundels [email protected] SW M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 5 24th September 2010 10:52 AM
Replacement Carpet & Mats GSM5er E28 M5 Discussion 3 21st September 2005 05:01 PM
Replacement Vanos replaced? agriskman E39 M5 and E52 Z8 Discussion 4 15th November 2004 11:33 PM
