ABS/DSC Light Issue - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 20 Old 13th April 2019, 06:21 PM Thread Starter
espritv8
ABS/DSC Light Issue
Hi guys,
Recently bought an 2002 E39 M5 with 90K miles. Drove around 200kms in December, then stored it, until last week.
During storage, I made some basic maintenance on it. Flushed the brake fluid with the motive brake pressure bleeder. Previous owners seem to never had done maintenance on this because there was some gooey stuff that came out from the calipers.
So last week, after driving less than 5 miles, the ABS/DSC lights came on. It will go off after turning the car off, but randomly comes back usually after driving only a few miles. I will also light up when the car is stationary.
INPA gave me the following codes:
- Brake switch 105
- pressure sensor 114
- steering angle sensor 103
Cleared them and drove some more, lights came back, and now getting only the 114 code.
When lights are off, ABS and DSC works fine. Activating valves and pumps with INPA makes noise so I guess it' all working fine. Brake pads are good too.
What should I look for to pinpoint the problem? Could it be that some of the old fluid interferes with the system? Did I get air in the system? (pedal is firm though)
Also I've installed the shark injector that came with the car, could it be the issue?
Thanks!
espritv8 is offline
post #2 of 20 Old 13th April 2019, 07:22 PM
josiahg52
josiahg52's Avatar
Which light or lights were on initially exactly? The ABS and the separate DSC light? There's an orange BRAKE light, a red PARK BRAKE light, an orange ABS light and the DSC-off symbol light.
Which light or lights are on after "clearing" them?
Have you checked the brake fluid level in the reservoir?
josiahg52 is offline
The Following 2 Users Say Thank You to josiahg52 For This Useful Post:
espritv8 (14th April 2019)
post #3 of 20 Old 13th April 2019, 09:02 PM Thread Starter
espritv8
It's the same lights that are coming on. DSC off, ABS and the exclamation mark next to the abs.
Didn't check the fluid yet but when I had the flush it was ok. I'll later today.
espritv8 is offline
post #4 of 20 Old 13th April 2019, 11:38 PM
Rosie
The engine tune won’t have anything to do with the DSC fault.
If your brake fluid was that bad, I’d probably start with replacing the pressure sensor.
Rosie is online now
The Following 2 Users Say Thank You to Rosie For This Useful Post:
post #5 of 20 Old 14th April 2019, 12:21 AM Thread Starter
espritv8
espritv8 is offline
post #6 of 20 Old 14th April 2019, 01:13 AM Thread Starter
espritv8
Yeah but sensor is 200$. Wish I could pinpoint the issue first.
Maybe I can remove it and clean it with brake cleaner?
espritv8 is offline
post #7 of 20 Old 14th April 2019, 02:35 AM
Rosie
Can’t hurt.
Maybe try a junkyard one first.
They’re easy to get to and remove and really don’t fail often.
It is in all of these models:-
Rosie is online now
post #8 of 20 Old 15th April 2019, 12:01 AM Thread Starter
espritv8
Ok so I'll try cleaning it first and I suspect I may have air in the abs system.
Not sure how to bleed the abs with INPA? Any hints? Made a search and nothing usefull came up.
espritv8 is offline
post #9 of 20 Old 15th April 2019, 02:01 AM
Rosie
INPA doesn’t have the bleed routine program for an E39.
Only DIS or ISTA D does in the “Service Functions” menu but they’re really difficult to get working.
It also needs to be done with a pressure bleeding connected at the same time.
https://www.newtis.info/tisv2/a/en/e...lation/AryWRXx
Rosie is online now
post #10 of 20 Old 15th April 2019, 02:08 PM Thread Starter
espritv8
Well, that's a real pain. I have INPA and BMW scanner. Wish those 2 could at least do that simple task.
Under the ABS menu in INPA there's options to open the system valves and activate pump. There is no procedure to get the air out using these options?
I don't have DIS and really hope to avoid dealing with it. It has been a pain already to have the INPA and bmw scanner running on my laptop.
espritv8 is offline
BMW dealership couldn't resolve a check engine light after 5 visits over 3 months... Manny G. F10 M5 Discussion 0 13th December 2018 08:05 PM
Replacing license plate light bulb? Wright E39 M5 and E52 Z8 Discussion 58 29th September 2015 08:07 PM
Cluster/Indicator light issue. RJ2k10 E39 M5 and E52 Z8 Discussion 11 12th August 2014 05:15 PM
Check Licplate light!?!? Anger vent Wright E39 M5 and E52 Z8 Discussion 15 19th September 2010 04:44 AM
(( ! )) DBC Warning Light, Help needed slunk_23 E39 M5 and E52 Z8 Discussion 2 19th December 2008 04:08 PM
