ABS/DSC Light Issue - Page 2 - BMW M5 Forum and M6 Forums
 4Likes
post #11 of 21 Old 15th April 2019, 02:21 PM
Rosie
Originally Posted by espritv8 View Post
Well, that's a real pain. I have INPA and BMW scanner. Wish those 2 could at least do that simple task.
Under the ABS menu in INPA there's options to open the system valves and activate pump. There is no procedure to get the air out using these options?
I don't have DIS and really hope to avoid dealing with it. It has been a pain already to have the INPA and bmw scanner running on my laptop.
Yeah, so do I.
INPA only activates the pump and valves individually. If it does get the air out of the system itís probably more by luck than design.
The DIS procedure runs the pump and activates the valves in a specific sequence to purge the air out of the DSC Hydraulic unit and into the lines to then be bled out of the calipers.
Iíve used DIS on an E39 with a F&R Brembo GT BBK - the brakes felt good before, but some air was expelled and they became mind blowingly awesome!
Rosie is offline
post #12 of 21 Old 15th April 2019, 03:44 PM Thread Starter
espritv8
Originally Posted by Rosie View Post
Yeah, so do I.
Ok thanks, I'll try to get then... found it at around 20$ on ebay.
espritv8 is offline
post #13 of 21 Old 15th April 2019, 07:53 PM Thread Starter
espritv8
I've ran INPA and found the pressure sensor testing.
Numbers go up when pressure is applied so I guess the pressure sensor is fine. Weird thing though, brake switch stays at 1-1.2v even if no pressure is applied. Normal?
espritv8 is offline
post #14 of 21 Old 15th April 2019, 08:01 PM Thread Starter
espritv8
Also while connected to INPA, I would hear a clicking noise from the front end and lights will turn on or off at the same time. Wonder if that's normal too?!?!
espritv8 is offline
post #15 of 21 Old 15th April 2019, 08:47 PM
josiahg52
josiahg52's Avatar
Can you post a photo of your cluster with the warning lights on?
josiahg52 is online now
post #16 of 21 Old 16th April 2019, 05:43 AM
Sailor24
Sailor24's Avatar
It is likely the ABS/DSC module. If there are 50 ABS issues reported 49 relate to a failure in that module. The smart thing to do is remove the module and send it out for testing and even if it tests fine have them go over it and redo some common solder issues and you won't have an issue in the future. Even if you do they will fix it for free depending where you send it.Frankly if you start messing with that system and you don't know what you are doing you will introduce air into the system and then... well just read all the threads on getting air out of the ABS, not pleasant.
Sailor24 is online now
post #17 of 21 Old 16th April 2019, 06:08 AM
Rosie
Very true and well said.
Rosie is offline
post #18 of 21 Old 18th April 2019, 01:52 AM Thread Starter
espritv8
espritv8 is offline
post #19 of 21 Old 18th April 2019, 01:57 AM Thread Starter
espritv8
The reason why I suspect air in the system is that it was working fine with no lights before the fluid flush.
Or maybe it's that gooey stuff that got moved around in the system and interferes with the ABS???
I'll try another flush and bleed procedure after getting DIS, and then will send the ABS module for repair if not working. I wish there was just a way to diagnose the issue first.
espritv8 is offline
post #20 of 21 Old 18th April 2019, 04:33 PM
josiahg52
josiahg52's Avatar
Huh, that's what I thought. The lights are different than the US cars. Must be some obscure respective transportation department's requirement.
I think it would be worth it to get your DSC module refurbished. In the US there is Module Masters.
BMW dealership couldn't resolve a check engine light after 5 visits over 3 months... Manny G. F10 M5 Discussion 0 13th December 2018 08:05 PM
Replacing license plate light bulb? Wright E39 M5 and E52 Z8 Discussion 58 29th September 2015 08:07 PM
Cluster/Indicator light issue. RJ2k10 E39 M5 and E52 Z8 Discussion 11 12th August 2014 05:15 PM
Check Licplate light!?!? Anger vent Wright E39 M5 and E52 Z8 Discussion 15 19th September 2010 04:44 AM
(( ! )) DBC Warning Light, Help needed slunk_23 E39 M5 and E52 Z8 Discussion 2 19th December 2008 04:08 PM
