Doors keep unlocking! - BMW M5 Forum and M6 Forums
post #1 of 8 Old 11th April 2019, 03:18 AM Thread Starter
psyb0rg
psyb0rg's Avatar
Unhappy Doors keep unlocking!
So, I damaged the key fob button (long story) and the buttons don't work "reliably" anymore. Now when I lock the door from the outside using the key in the key hole, old school way, all the locks automatically unlock as soon as I turn the key back to the neutral position.
I thought that the lock button on the key fob is being permanently pressed, but then I used to the second key fob, which has been dead for years, and I get the same behavior! I made sure the first key fob is out of range.
Oh also, if I keep trying to lock the car by turning the key, after the 4-5th attempt all the windows roll down. I thought that only happened if you pressed the unlocked button on the fob for a few seconds?
Any idea what could be happening here?
psyb0rg is offline
post #2 of 8 Old 11th April 2019, 07:33 PM Thread Starter
psyb0rg
psyb0rg's Avatar
No one? I noticed that it unlocks as soon as it hits the neutral position...tried to move the key really slowly and made sure it doesn't move to the left side (unlock side) when I stop rotating.
psyb0rg is offline
post #3 of 8 Old 11th April 2019, 09:15 PM
Ferris
you sure it's out of range?
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #4 of 8 Old 11th April 2019, 11:03 PM Thread Starter
psyb0rg
psyb0rg's Avatar
Yes. Left it at home, which is a few miles away
psyb0rg is offline
post #5 of 8 Old Yesterday, 12:02 AM
Ibmotoren
Ibmotoren's Avatar
Sorry, canít help you with your problem, but yes you can open all the windows using the key in the door.
See page 32 of the manual-
2001 Manual
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is online now
post #6 of 8 Old Yesterday, 04:23 AM
Ferris
I guess that's pretty definitive.
IIRC you can code the windows to auto down by holding the key, it sounds like you have a bad gateway module or it's going bad. I believe there are some tests that you can do with it in inpa.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #7 of 8 Old Yesterday, 09:38 PM Thread Starter
psyb0rg
psyb0rg's Avatar
psyb0rg is offline
post #8 of 8 Old Today, 12:37 AM
Sailor24
Sailor24's Avatar
Pretty sure locking is controlled by the GM or general module, but my memory is so bad hard to know. I did check some of my notes and they confirmed that. I would suggest you do a search of the general module and confirm it is what controls the locks.
You likely have some body codes to go with that fault so report all your codes from INPA and state what module they come from.
Sailor24 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Trumpet/blowing horn sound when unlocking doors laomaiv10 E60 M5 and E61 M5 Touring Discussion 10 15th November 2014 07:26 PM
winding/humming noise when unlocking doors? E60 BimManiac E60 M5 and E61 M5 Touring Discussion 11 23rd September 2013 04:17 AM
Tranny rear seal still leaking after replacement 4heid E34 M5 Discussion 11 17th June 2013 08:19 AM
Unlocking back doors ezmoney888 E60 M5 and E61 M5 Touring Discussion 12 21st February 2009 03:23 AM
unlocking your doors cause the engine to produce "sound" \dev\null E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 15th February 2003 11:26 PM
