E39 M5 - Help me decide, QuickJack or FloorJack/Stands - Page 3 - BMW M5 Forum and M6 Forums
 5Likes
post #21 of 48 Old 1st April 2019, 09:01 AM
kiznarsh
kiznarsh's Avatar
Originally Posted by xrviz View Post
I'm with Kiz I wish I had a Quickjack anytime I want to do something quickish like brake bleeding. I doubt I would do a clutch with it though.
I have the Esco's and trust them. Even so if I'm underneath I pull the wheels and put them under the frame.
I use a floor jack on a front side jack point to raise the nose enough to get my low profile jack to the center point so I don't need ramps.
Speaking of wishing I had a QuickJack...
This was the first time getting the Cayman up on 4 jack stands and figuring out the best way to do it took like an hour.
The handle of my jack was interfering with the jack stand so I couldn't place it in the right spot.
So I had to bring the jack in from the front of the car, but of course I didn't have enough clearance so I put a 2x8" underneath. Tried again. Nope, still not enough clearance. Added more wood until I could slide it in far enough to raise it.
Normally I don't need to get the car this high for things like oil changes or brake bleeding, but I'm doing the water pump & thermostat and wanted plenty of room. But getting the front left side so high raised the entire front end, so now I'm scrambling to get wood under the right side tire so the chassis isn't flexing all over the place. ŪAy dios mio!
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
post #22 of 48 Old 1st April 2019, 02:06 PM
Sailor24
Sailor24's Avatar
Just going to state the obvious, you have the space and clearly the coin, buy yourself a two post lift. My convenience is worth three grand easy. The space would cost me 20 more and that is not worth my convenience.
Sailor24 is offline
post #23 of 48 Old 1st April 2019, 05:25 PM
kiznarsh
kiznarsh's Avatar
That's a negative with an 8-ft ceiling.
kiznarsh is offline
post #24 of 48 Old 1st April 2019, 07:31 PM
Sailor24
Sailor24's Avatar
Not at all. Makes the work lower is all.The posts are less than 8' , you just move the safety bar down to 7'10" to prevent the lift from going higher. The shop I work on my RS4 in is 8', we do things in rolling office chairs, or get a sore back standing hunched.
Sailor24 is offline
post #25 of 48 Old 1st April 2019, 08:00 PM
de Witt
de Witt's Avatar
This or even going with a four post lift, which can be had in shorter lift heights, will make all the difference in the world. Four post lifts take up a lot of space but every time I use the two post rotary, I just cannot see being without it.
Ignore the trainwreck mess on the benches even though I am pointing it out!
de Witt is offline
post #26 of 48 Old 1st April 2019, 10:56 PM
josiahg52
josiahg52's Avatar
How wide are these two posts generally? I got the height for sure but always wondered about the width.
josiahg52 is offline
post #27 of 48 Old 1st April 2019, 11:06 PM
de Witt
de Witt's Avatar
Mine is 11' 5.4" wide. I have regularly used the lift for a 2006 GMC Sierra extended cab duramax, lifts it no sweat, I do have motorized extending mirrors and those are pulled in when on the lift.
de Witt is offline
The Following User Says Thank You to de Witt For This Useful Post:
josiahg52 (1st April 2019)
post #28 of 48 Old 7th April 2019, 05:25 AM
nikh23
Has anyone used the maxjax? Iíve had this same debate about quickjack vs jackstands and have talked myself out of the quickjack for the most part. But whenever I get on my back for a longer duration I envy those with a proper lift but still value my garage space for the 95% of the time I likely donít need a lift. Maxjax seems to offer best of both worlds at a tolerable price.
https://www.maxjaxusa.com
nikh23 is offline
post #29 of 48 Old 7th April 2019, 05:45 AM
offroadkarter
offroadkarter's Avatar
Of course I just bought a quickjack and now I read on here my m5 won't fit on it, so that's awesome. I guess I can use it on the mustang with the jacking rails and marauders which are body on frame.
I don't plan on doing big jobs on this, I'll be buying a rotary 2 post soon enough. This was more for simple jobs and possibly detailing as well.
These are actual garbage. A friend of mine, who used to own my m5 actually, owned one of these and we had to do a bit of work to it to make it quasi-safe.
We had to shim the blocks inside the lift posts because out of the box, the car would rock up and down at least an inch if not more while you were working on it. The carriers had so much side to side play.
if you're buying a lift, get something ALI certified, the maxjax worked but wow was it sketchy.
2000 E39 M5 Carbon Black Evolve CAI / Evolve Alpha-N / Stoptech ST40 BBK / UUC SSK / Dinan front STB / Dinan RSB
2016 Ford Mustang GT PP
2004 Mercury Marauder
2003 Mercury Marauder
1996 Ford Bronco
offroadkarter is offline
post #30 of 48 Old 7th April 2019, 06:48 AM
nikh23
Well thatís unfortunate. I was getting excited that this may fit my needs/wants for a ďbudgetĒ friendly option. A two/four post lift just wonít fit in my garage or make it otherwise useless for storing actual cars and other non vehicle related work. I guess itís time to move to a bigger house (or smaller house with bigger garage)
nikh23 is offline
NorCal - Bay Area Members Thread EuroCarFan USA West Forum 797 17th October 2018 05:24 PM
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 64 30th December 2013 08:35 PM
E39 For Sale: PARTING OUT 2001 BMW E39 M5 Carbon Black AlpineM3503 Parts / Other For Sale or Wanted 65 24th July 2012 10:51 PM
M5 owners in the UK jgfabs E39 M5 and E52 Z8 Discussion 62 4th June 2010 06:28 PM
