Misfiring at 5,500 rpm or higher with little to no engine load - Page 5 - BMW M5 Forum and M6 Forums
 27Likes
post #41 of 47 Old 13th April 2019, 04:15 AM Thread Starter
SupercarFreak
Originally Posted by boris1 View Post
At this point you know the solution. Buy the proper BMW spacer #9 and if you want to go all out, but a new crank position sensor, although that is not really necessary. If it runs fine now, then little scraping of the crank sensor isn't impacting its performance.
I ordered the spacer and a new Hella sensor last night. I'm so over this problem. It has basically had this issue since I've owned it and I've never been able to figure it out. I've been able to fix everything else wrong with the car on my own, one thing at a time, but not this. Thanks so much for your help. The car is really sorted now, it's a great feeling. Plus I'm switching to 10w60, I've been running 5w30 like an idiot.
Thanks to everyone for your ideas and advice. A lot of the things mentioned aren't a bad idea to replace anyway on a 16 year old 70k mile car.
You guys rock
Alex
SupercarFreak is offline
post #42 of 47 Old 13th April 2019, 11:17 AM
curtissp321
curtissp321's Avatar
What a great result - interesting problem as well. I seem to recall the Ďbookí talks about using multiple spacers if need be. Looks like you car never had any at all or perhaps misplaced in a clutch change...
Simon
curtissp321 is offline
post #43 of 47 Old 13th April 2019, 01:34 PM
technician117
technician117's Avatar
As a point of reference, not all cars had a shim. I don't know how it was measured to determine if a shim was needed or not, but I've actually never seen one in person. I've done clutch jobs on at least 5 or maybe 6 different m5's. None had the shim.
Glad to see you're getting the problem sorted. This is not a common solution to your symptoms!
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 50k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
282,000 miles and counting
'00 Imola/Imola 104k,
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #44 of 47 Old 14th April 2019, 01:38 AM
Sailor24
Sailor24's Avatar
I am suspicious of something else, maybe you can shed some light. The buildup of crud on the sensor seems very rare, I have not seen it nor have I seen even much dirt on the inside of the bell. How about you? Oil yes but even that seems to wash clean? Wondering if something else is going on ?
Sailor24 is offline
post #45 of 47 Old 6th May 2019, 08:36 PM Thread Starter
SupercarFreak
I don't think anything is abnormal from what I've seen. I've done a bunch of clutches and the sensor is generally pretty dirty along with the bell housing. It's just friction disk material buildup from what I can tell.
post #46 of 47 Old 6th May 2019, 08:39 PM Thread Starter
SupercarFreak
Originally Posted by M3Fan View Post
FWIW I used this guy for my injector cleaning and he did a great job. Very thorough and knowledgable, quick, easy to deal with. Place Order ? Rosch Fuel Injector Cleaning Services
Thanks for the link! I just shipped my injectors to them today.
After 4-5 tanks of fuel injector cleaner car still has the same problem. Installed new crank sensor and BMW shim- no change.
Fuel filter comes tomorrow, already have a new pressure regulator.
Will keep everyone updated.
post #47 of 47 Old 6th May 2019, 10:33 PM
TMcNasty
TMcNasty's Avatar
Personally I would have changed the FF first. Plenty of threads I recall from back when I joined (2008) where high-rpm faults were fixed simply w/ the FF being replaced.
TMcNasty is offline
S50B32 chain tensioner upgrade for the S38B36 and S38B38 raymondw E34 M5 Discussion 90 24th January 2018 08:19 PM
Dyno results are in. boots F10 M5 Discussion 77 6th February 2013 01:43 PM
Delimited E55 does 190+ sdstarnes GTBoard.com: General Sportscars 154 19th February 2006 04:49 PM
Optimal Shift Points-it's at 7000 KirklandM5 E39 M5 and E52 Z8 Discussion 26 14th June 2001 12:58 AM
