Misfiring at 5,500 rpm or higher with little to no engine load - Page 2 - BMW M5 Forum and M6 Forums
 27Likes
post #11 of 47 Old 29th March 2019, 03:12 PM Thread Starter
SupercarFreak
Thanks for all of the great recommendations guys.
Just ordered 4 02 sensors, 2 MAFs, fuel filter and 1 bottle of fuel system cleaner. We'll start there.
Fuel tank levels in the cluster are 8.1 L on the left and 10.8 L on the right.
Will keep everyone updated.
Thanks again
SupercarFreak is offline
post #12 of 47 Old 29th March 2019, 03:13 PM Thread Starter
SupercarFreak
Originally Posted by M3Fan View Post
FWIW I used this guy for my injector cleaning and he did a great job. Very thorough and knowledgable, quick, easy to deal with. http://roschfuelinjectorcleaning.com/place-orders/
Thanks for the info!!!
post #13 of 47 Old 29th March 2019, 04:14 PM
technician117
technician117's Avatar
I'm betting on fuel filter and/or pump. Those other items should be done anyway as PM.
Keep us posted!
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 50k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
282,000 miles and counting
'00 Imola/Imola 104k,
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #14 of 47 Old 29th March 2019, 04:47 PM
Ferris
No load higher RPM misfires are probably going to be vanos or air measuring related. The DME swings pretty lean in no load off throttle cases.
I had a similiar issue a while back, nice and warm engine off throttle at about 4k it would start missing and drop into cut out, playing around was able to correct it by adding a hair more fueling and it went a way. So I started down the fuel air path, instead of spark, decided to run the vanos test and it failed. Turned out to be problem.
At the very least I'd run the vanos test before throwing parts at it.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #15 of 47 Old 29th March 2019, 05:28 PM
Sailor24
Sailor24's Avatar
Here is a free test. Problem is my memory, the details might not be right but you will still get the concept. I am assuming what I quoted was with the car off, if it was running you might have problems. Look at the same function in the OBC, start the car the and let it idle, you should see the fuel transfer from the left to right tank at a rate of 2l/min(???). I wrote about the rate and tested this many times, but I am not sure I remember the correct numbers.
That test gives you a ton of info and the rate is easy to confirm by others if need be. Not only does it test the jet pump system, but it also tests how strong your fuel pump is and if your filter is plugged up. It does not tell you specifically what is wrong, you will need more tests but it is a great place to start.
Sailor24 is online now
post #16 of 47 Old 29th March 2019, 05:41 PM Thread Starter
SupercarFreak
Thanks Ferris. Ripped all the old parts out of the car this morning. Once the new parts are in, if it misfires again I'll take it to the dealer to perform the VANOS test and if it fails that I'll rebuild the units myself with the Besian kit.
On a side note, KW Variant 1's are AWESOME.
My thrust rod bushings are leaking so I have Moosehead spherical bushings mounted in new Lemforder arms on the way. I don't have a hydraulic press and the ball joint boots are torn so figured I'd replace the arms as well.
post #17 of 47 Old 29th March 2019, 05:46 PM Thread Starter
SupercarFreak
Thanks Sailor, that is a great idea. I will do this once the car is drivable again
post #18 of 47 Old 29th March 2019, 06:36 PM
herrubermensch
herrubermensch is offline
post #19 of 47 Old 29th March 2019, 11:37 PM
xrviz
xrviz's Avatar
I am gonna use Occam's razor here and call it all (at least most) due to a dying fuel pump which will be worse at lower tank levels, give you the misfire with empty tank code, misfire codes, and O2 sensor codes (reporting lean).
xrviz is online now
The Following User Says Thank You to xrviz For This Useful Post:
josiahg52 (30th March 2019)
post #20 of 47 Old 30th March 2019, 07:11 PM Thread Starter
SupercarFreak
Originally Posted by herrubermensch View Post
Great looking beast, and a nicely appointed garage!
--Peter
Thanks Peter I really appreciate it 😎
Been here for about a year now and I pretty much have it set up just how I want. Took a lot of time and money but I’ve always dreamed of having a shop at my house!
Thanks for the input. What you said makes perfect sense and I wouldn’t be surprised if it ends up being the fuel pump. I will keep everyone updated.
S50B32 chain tensioner upgrade for the S38B36 and S38B38 raymondw E34 M5 Discussion 90 24th January 2018 08:19 PM
Dyno results are in. boots F10 M5 Discussion 77 6th February 2013 01:43 PM
Delimited E55 does 190+ sdstarnes GTBoard.com: General Sportscars 154 19th February 2006 04:49 PM
Optimal Shift Points-it's at 7000 KirklandM5 E39 M5 and E52 Z8 Discussion 26 14th June 2001 12:58 AM
