Fully Integrated Bluetooth Solution - Page 8 - BMW M5 Forum and M6 Forums
 25Likes
post #71 of 73 Old 4th June 2019, 10:19 PM
DonutRanger
Will this still work if my navigation screen isn’t working?
I have that issue where my navigation is corrupted so the screen stays blank, because the battery died, but I can still control the radio by blindly scrolling through channels.
All I need is to stream Spotify through my phone which I can control through my phone. Hopefully it works, thanks for all your effort.
DonutRanger is online now
post #72 of 73 Old 1st July 2019, 11:06 PM Thread Starter
t3ddftw
Originally Posted by 0ptimus Prime View Post
Subscribed and pre-ordered!
Thanks!
Sorry for the late reply! Yes it would work, but it'd be really hard to use it without the MKIV in working order as you will not be able to enable pairing.
I can make it work for you by allowing you to initiate pairing via the command line interface, but that would be a PITA for you.
However, wouldn't a GROM BT3 make more sense for you? The big value add for my unit is the OE integration which you will not be able to take advantage of
t3ddftw is offline
post #73 of 73 Old 7th July 2019, 04:09 AM
DonutRanger
Originally Posted by t3ddftw View Post
Thanks!
I decided to just purchase an MK4 Unit from eBay since my MK3 is broken. So I will go ahead and buy your solution, as I am trying to keep the OEM look. Looks like it is close to release, looking forward to it.
Tags
a2dp , bluetooth , ibus
Most cost effective bluetooth solution, tcu/ulf or aftermarket? nightkrawler E39 M5 and E52 Z8 Discussion 35 27th December 2011 11:32 PM
Solution to issues with Bluetooth and WM5.0! (JetWare software) spatterso E60 M5 and E61 M5 Touring Discussion 51 20th April 2007 02:53 PM
BMW technical bulletin regarding Bluetooth issues cobradav E60 M5 and E61 M5 Touring Discussion 0 14th July 2006 02:17 AM
fully integrated bluetooth bluebmw E60 M5 and E61 M5 Touring Discussion 19 29th July 2004 01:54 AM
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 02:32 PM
