Fully Integrated Bluetooth Solution - Page 5 - BMW M5 Forum and M6 Forums
 23Likes
post #41 of 66 Old 8th April 2019, 09:50 PM
Hdhntr23
Hdhntr23's Avatar
Originally Posted by josiahg52 View Post
The cluster MID is not thst important to me. I was just curious.
It was years ago, but I think I used Carly for BMW in my X5. Oddly, in the X5, that function resides with the FRM. I do remember there's not a ton of options in that program for the M5, unfortunately.
I don't know if other programs would be able to modify the M5's LCM properly. I only know the Intravee allowed 3-blink.
Josiah,
Are you causing trouble again?
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
post #42 of 66 Old 8th April 2019, 10:32 PM
josiahg52
josiahg52's Avatar
Originally Posted by Hdhntr23 View Post
Josiah,
Never have I ever.
josiahg52 is offline
post #43 of 66 Old 8th April 2019, 11:11 PM Thread Starter
t3ddftw
I assume the instrument cluster notifies the LCM when the turn signal stalk is toggled, even slightly. With that data, my unit could potentially continue to trigger the turn signal for x amount of blinks.
I will have to do some testing on my E46 and see what kind of messages are sent when the turn signals are activated.
-Ted
t3ddftw is offline
post #44 of 66 Old 8th April 2019, 11:39 PM
josiahg52
josiahg52's Avatar
-Ted
I'd guess the Intravee works on that principle.
I prefer five but I think most others would just like three so you should look to develop whatever you think is going to be most accepted or desired.
post #45 of 66 Old 8th April 2019, 11:43 PM Thread Starter
t3ddftw
There's no reason it can't be a configurable value
I'm big on configurable options, just not to the point of the Intravee where literally everything is configurable, making it hard to use.
t3ddftw is offline
post #46 of 66 Old 8th April 2019, 11:45 PM
Fatandre
Fatandre is offline
post #47 of 66 Old 8th April 2019, 11:48 PM Thread Starter
t3ddftw
Originally Posted by Fatandre View Post
Would this also work with the cd43 radio that I have in my e31?
The CD43 is IBus capable, but it doesn't support the UI mode where the telephone is allowed to write to the screen as far as I know. This means that you wouldn't be able to see metadata, or configure the device without a computer.
There's also the question of it being pre-wired for the CD Changer, which is not one I know the answer to .
So, in short: "Yes, but it would be a crappy integration and likely require some extra work on your end to wire it up".
t3ddftw is offline
post #48 of 66 Old 8th April 2019, 11:49 PM
Fatandre
Darn it.
I am looking for a plug in solution for the cd43 or the becker indianapolis i have
Fatandre is offline
post #49 of 66 Old 8th April 2019, 11:59 PM
Rosie
-Ted
The indicator stalk position isn’t monitored - it’s just a direct input into the LCM.
The Intravee, Modlight & Ibusapp all use the Bus signal for the bulb illumination from the LCM to IKE/KOM.
Same with the flash to pass option.
Rosie is offline
post #50 of 66 Old 9th April 2019, 12:41 AM Thread Starter
t3ddftw
Thanks for the info! I wonder how they can tell a single illumination from many, then. Otherwise, the module is going to be sending the command to flash the turn signals at the same time they're already flashing (when fully depressing the stalk).
I'll have to test this in my car
t3ddftw is offline
Tags
a2dp , bluetooth , ibus
Most cost effective bluetooth solution, tcu/ulf or aftermarket? nightkrawler E39 M5 and E52 Z8 Discussion 35 27th December 2011 11:32 PM
Solution to issues with Bluetooth and WM5.0! (JetWare software) spatterso E60 M5 and E61 M5 Touring Discussion 51 20th April 2007 02:53 PM
BMW technical bulletin regarding Bluetooth issues cobradav E60 M5 and E61 M5 Touring Discussion 0 14th July 2006 02:17 AM
fully integrated bluetooth bluebmw E60 M5 and E61 M5 Touring Discussion 19 29th July 2004 01:54 AM
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 02:32 PM
