Fully Integrated Bluetooth Solution - Page 4 - BMW M5 Forum and M6 Forums
 25Likes
post #31 of 73 Old 1st April 2019, 03:32 AM Thread Starter
t3ddftw
Originally Posted by 155plus View Post
Added me to the pre-order list.
Assume this is fully fused etc, so worst scenario in case of hw failure is a blown fuse, nothing worse, right?
Correct! There is an on board 1.5A fuse. It's a littleblock SMD fuse holder, so if it were to go over current, it can be easily replaced without soldering. The board uses about 800mA when active, but different scenarios can drive that current a little higher 🙂
t3ddftw is offline
post #32 of 73 Old 1st April 2019, 11:59 AM
155plus
155plus's Avatar
A question.
For those of us using the StealthOne - where we today use the Phone button for muting the V1 - do you think can these units work together?
See link below, esp page 13 and 30.
http://www.bimmerboard.com/members/m...nual_V-1.6.pdf
'03 LMB/Caramel
Dinan 3.45, JRZ stage 3, swaybars, strut brace, short shifter, sf
V1/Stealthone and LI - when V1 won't help...
Black kidney's, iBright V3 angel eyes, HID fogs, and tint
Illuminated M5 door sills (now that's very, very cool!)
Magnaflow 14816s, euro brake ducts
To come:
Nothing - the mod itch has been scratched enough...
155plus is offline
The Following User Says Thank You to 155plus For This Useful Post:
josiahg52 (1st April 2019)
post #33 of 73 Old 1st April 2019, 07:36 PM Thread Starter
t3ddftw
A question.
Hello,
It seems as though you can use the Up/Down buttons rather than the phone button to mute the S1, so if you were to use the BlueBus for calls, I'd recommend using that combo instead.
With that being said, as long as you're not on a call or have a call ringing through, the phone button won't do anything to the BlueBus. A long press of the phone button will call your phones assistant (Siri / Google), so there's that.
Thanks!
-Ted
t3ddftw is offline
post #34 of 73 Old 1st April 2019, 08:00 PM
155plus
155plus's Avatar
Originally Posted by t3ddftw View Post
Hello,
-Ted
Hmm, OK . So can use up-down instead - or i can use the phone button as long as I'm not on the phone? Cool.
I'd maybe even ask to not have the long press configured to start Siri/Google?
'03 LMB/Caramel
To come:
155plus is offline
post #35 of 73 Old 1st April 2019, 08:31 PM Thread Starter
t3ddftw
I can certainly make this an option
t3ddftw is offline
post #36 of 73 Old 2nd April 2019, 08:08 PM
flumoxed
Hello!
The BlueBus is obviously way better integrated than the GROM units are. Additionally, my unit has upgradable software, so you'll keep getting new features as they're developed.
I have a beta user with an E39 M5 who happened to own the GROM prior to the BlueBus and he states that my unit has better range and the audio quality is way better.
Thanks!
-Ted
Thanks for the response Ted.
My main gripes with the GROM unit are 1) music will not autoplay upon vehicle entry, 2) next/play/pause functionality via vehicle controls work maybe 70% of time, and 3) non-nonsensical metadata is displayed.
Would the BlueBus solve those issues from the GROM?
In any case I've signed up for a pre-order!
flumoxed is offline
post #37 of 73 Old 2nd April 2019, 08:12 PM Thread Starter
t3ddftw
1. This is an option that you can set with the BlueBus. I don't personally like it, but my beta users liked the idea of it
2. I've never had an issue getting playback controls to work with the BlueBus. When you hit the Next/Prev buttons on the Radio or on the steering wheel, the radio tells the CD Changer to go to the Next/Previous track, which is really easy to code around.
3. Yeah, I've seen this on their install videos. I have no idea what the metadata is supposed to represent on the GROM units.
So, yeah, the BlueBus doesn't have any of those issues
Thanks for the supprot!
t3ddftw is offline
post #38 of 73 Old 2nd April 2019, 11:35 PM
josiahg52
josiahg52's Avatar
Yes, metadata can be displayed on both. I know some E38s had rear MIDs and factory nav, that's why that option is multiple choice 🙂
A compatible microphone may work at the factory location, but I imagine it would not work well because it'll be hard for it to pick up your voice. Most aftermarket mics state that they should be installed in the corner of the cluster, which makes sense but is aesthetically unpleasing.
In any case, I'd actually recommend hijacking the OE harness for a non OE mic. That means running two wires up the driver A pillar to the OE mic harness from where ever your mic has been installed. As long as the factory ULF or TCU are not installed, it'll be fine.
All E38 and E39 models that I have come across has the 3 pin white SES connector in the trunk that contains the mic positive and negative signals, so my kit will come with a jumper wire to connect that to the BlueBus.
The PCB mentioned is the OE mic adapter board. It takes the homelink connector and steps down the 12v to provide 5v to the OE microphone. The other side of the board decouples the DC voltage with a capacitor and outputs to the factory harness. You can see more about it here: https://github.com/tedsalmon/BlueBus...r-Installation
Note that the board pictured is a prototype.
Are you using an Intravee for the 5-blink? I've been asked repeatedly for this feature, so I'm actively working on implementing it.
What I can say about the factory mic is that it has way better gain than a bog standard mic. It also, allegedly, has superior noise cancelation abilities, but I don't think this matters much as my BT adapter has algorithms employed for this.
Thanks!
-Ted
Thank you for your response.
I was specifically asking if metadata will be displayed on the MID in the cluster and the navigation display.
You answered my next question. The unit is powered from the Homelink adapter and it has a pass through connector so the Homelink is still operable. I use Homelink.
I'd prefer to use the OE mic because it's already installed and I don't like sticking things in my car.
I coded 5-blink directly using software for my X5. My M5 is lightly coded but the turn signals are normal. I don't own an Intravee.
I also have a Stealth One. That's something you should look into. I'm not looking forward to the day when mine stops working. Mine already acts up a bit. I'll have to drag the manual out and take a look at it again.
josiahg52 is offline
post #39 of 73 Old 3rd April 2019, 12:43 AM Thread Starter
t3ddftw
Ah, the cluster MID is currently unused. I do plan to make the unit broadcast to that MID, similar to how the Radio does in AM/FM mode.
How did you code 5-blink? Admittedly, I need to do more research on the subject, but I assume the Intravee/other IBus device manipulated the LCM into running that feature.
I don't have a V1, but I have dealt with an S1 in someone elses car before. I don't think there's anything that will cause conflicts with the BlueBus and the S1, though.
t3ddftw is offline
post #40 of 73 Old 3rd April 2019, 01:02 AM
josiahg52
josiahg52's Avatar
The cluster MID is not thst important to me. I was just curious.
It was years ago, but I think I used Carly for BMW in my X5. Oddly, in the X5, that function resides with the FRM. I do remember there's not a ton of options in that program for the M5, unfortunately.
I don't know if other programs would be able to modify the M5's LCM properly. I only know the Intravee allowed 3-blink.
Tags
a2dp , bluetooth , ibus
Most cost effective bluetooth solution, tcu/ulf or aftermarket? nightkrawler E39 M5 and E52 Z8 Discussion 35 27th December 2011 11:32 PM
Solution to issues with Bluetooth and WM5.0! (JetWare software) spatterso E60 M5 and E61 M5 Touring Discussion 51 20th April 2007 02:53 PM
BMW technical bulletin regarding Bluetooth issues cobradav E60 M5 and E61 M5 Touring Discussion 0 14th July 2006 02:17 AM
fully integrated bluetooth bluebmw E60 M5 and E61 M5 Touring Discussion 19 29th July 2004 01:54 AM
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 02:32 PM
