s62 Crankshaft repair/grinding - BMW M5 Forum and M6 Forums
 5Likes
  • 1 Post By TexaZ3
  • 2 Post By herrubermensch
  • 2 Post By dranik182
post #1 of 10 Old 19th March 2019, 06:15 AM Thread Starter
dranik182
Hello everyone!
I just took apart engine after spun bearing and wondering if anyone has expirience in s62 crank repair?
There are 2 options:
1. to weld and grind it to nominal size:
-which is more expensive, at least 500$
-the only company i know in socal who are able to do that is marine cranckshafts - waiting time at least 6 weeks
-once they did crank for my s85 and it still runs great
2. to grind it for undersized bearings
- bmw has undersized bearings in catalogue +0.25 and 0.50
- crank shop i found nearby estimated 50$ to grind one rod journal - the guy said that he can try 0.25, but most likely damage is beyond that point so 0.50 is my option
So i have couple questions. I believe crank is hardened or has some coating on top of the journal, so is it ok just to grind it without any other proceedures? Also can i grind only 1 journal, or i have to do all 4? Will it affect to a stroke somehow?
Any opinions highly appreciated!
dranik182 is offline
post #2 of 10 Old 19th March 2019, 07:30 AM
Sailor24
Sailor24's Avatar
Sailor24 is online now
post #3 of 10 Old 19th March 2019, 07:46 AM
mmzcee
mmzcee's Avatar
Originally Posted by dranik182 View Post
Hello everyone!
Assume the scoring on the crankshaft was severe enough to the point that it requires this work?
Do you have any additional details on how/when you discovered the spun bearing ? And if you continued to drive on it afterwards?
mmzcee is online now
post #4 of 10 Old 19th March 2019, 04:42 PM
gsfent
gsfent's Avatar
If you grind the crank to remove metal, won't you need OVERSIZED bearings?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
post #5 of 10 Old 19th March 2019, 05:25 PM Thread Starter
dranik182
I thought the same before I read that:
ďAn oversized bearing has the same inside diameter but a bit more material on the outside diameter. An undersized bearing measures the same outside but is thicker on the inside.Ē
The Following User Says Thank You to dranik182 For This Useful Post:
gsfent (29th March 2019)
post #6 of 10 Old 19th March 2019, 05:27 PM Thread Starter
dranik182
I bought the car with knocking engine, so I was ready for it)
post #7 of 10 Old 19th March 2019, 06:36 PM
TexaZ3
TexaZ3's Avatar
The crank will need to be heat-treated after grinding.
I think the best bet right now just to get a good replacement crank and go with standard bearings.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #8 of 10 Old 19th March 2019, 10:21 PM
herrubermensch
It's just terminology. They are oversized in the critical dimension!
--Peter
herrubermensch is offline
post #9 of 10 Old 19th March 2019, 10:24 PM
herrubermensch
Correct. Some argue that grinding down one size doesn't go through all of the existing heat-treatment, but I would never take that risk.
Agree that a replacement crank will be both cheaper and faster than sending it to Marine Crankshaft. If you do choose to use the existing crank, I would recommend the weld and re-grind approach rather than using (what I call) oversize bearings.
--Peter
post #10 of 10 Old 20th April 2019, 01:42 AM Thread Starter
dranik182
I decided to let marine Crankshafts do their magic and it went out perfect.
E39 For Sale: BMW S62 Crankshaft (used) noxcape Parts / Other For Sale or Wanted 2 21st February 2016 02:00 AM
E39 For Sale: S62 Crankshaft, freshly machined/polished nlzmo400r Parts / Other For Sale or Wanted 13 13th October 2015 11:55 PM
Which Pulley Kit ? IndyRedBeast E60 M5 and E61 M5 Touring Discussion 78 1st June 2012 06:30 PM
Power Pulleys Steven Ferrario E39 M5 and E52 Z8 Discussion 40 29th January 2012 07:41 PM
Rogue vs Evosport pulley kit - Which one proves more HP? RUFM5 E39 M5 and E52 Z8 Discussion 99 9th May 2011 02:38 PM
