Anyone used Schwaben pro scan tool to bleed brakes? - BMW M5 Forum and M6 Forums
post #1 of 8 Old 12th March 2019, 09:50 PM Thread Starter
OjaiM5
I too am suffering from a soft brake pedal like a few others on here lately. I did a pressure bleed today with no luck. Has anyone used or own the Schwaben scanner tool? Does it do most of the stuff that a laptop with INPA software can do?
I know I am going to have to buy either an android, pc laptop, or a scan tool. I would prefer a scan tool mostly because I know nothing about PCs.
Do you guys have any suggestions?
Much appreciated
OjaiM5 is online now
post #2 of 8 Old 17th March 2019, 10:33 PM Thread Starter
OjaiM5
I just ordered one. I don't have the time to try and set up a PC. Hopefully this hand held does most of the same stuff. I will keep you guys posted.
post #3 of 8 Old 18th March 2019, 04:02 PM
godnf8
godnf8's Avatar
Please do, interested as well.
2008 BMW M5 E60 Current DD
godnf8 is offline
post #4 of 8 Old 9th April 2019, 08:22 PM Thread Starter
OjaiM5
So the scanner is pretty neat and I think will help down the road with codes and actively testing sensors and functions.
The ABS activation was super easy, sadly did not fix my problem.
When I first activated the system it was pouring out and by the end (activating it 5 times a caliper) the fluid was trickling out. Does any one know if I need to be activate the return pump as well?
Pretty discouraged at this point with my soft brakes.
post #5 of 8 Old 9th April 2019, 10:45 PM Thread Starter
OjaiM5
So I played with the scanner more and looked if I missed an option to do one wheel at a time or something else. I am now wondering if I should do the same procedure but use #2 Return pump test? Maybe I ran the ABS incorrectly. Any thoughts?
post #6 of 8 Old 10th April 2019, 11:11 PM
wrparrish
I dont know for sure. I'm in the same boat as you though ( have the same scanner, and have some brake work coming up). I'm going to try running the pre-charge pump 1x, the return pump 1x, and then bleed as per usual at each caliper, starting at right rear and making my way back to the front left. I'll post back what my results are.
wrparrish is online now
The Following 2 Users Say Thank You to wrparrish For This Useful Post:
OjaiM5 (10th April 2019)
post #7 of 8 Old 10th April 2019, 11:14 PM Thread Starter
OjaiM5
Thanks!
Yes let's figure this out. It is funny how they don't provide a real step by step. I will try your suggestion and report back.
post #8 of 8 Old Today, 02:50 AM
ObjectEdit
I have the Foxwell version of it with BMW coding in it. Worked well, and activated the ABS solenoids so I could bleed the new brake fluid through it. I was replacing all my brake lines to ECS SS braided ones including the 2 at the ABS pumps.
When bleeding I used the Motive pressure bleeder, along with the Foxwell unit, and everything went well.
ObjectEdit is online now
QUESTION: Does anyone have the DINAN BRAKES and if so......... FAST 5 E39 M5 and E52 Z8 Discussion 19 26th April 2006 08:11 PM
Brake Rotor Issue Joe Lapicki E39 M5 and E52 Z8 Discussion 29 26th December 2002 03:42 PM
Next project! - New brakes but have some questions atomic80 E39 M5 and E52 Z8 Discussion 9 16th April 2002 10:29 PM
19" wheels on the M5: Why? kgk E39 M5 and E52 Z8 Discussion 44 23rd August 2001 08:27 AM
Movit GT2 Brakes! JPK//E28M5 E34 M5 Discussion 3 14th May 2000 07:57 PM
