Where to start with Vanos maintenance? - Page 3 - BMW M5 Forum and M6 Forums
 3Likes
post #21 of 34 Old 19th March 2019, 12:34 AM
Sailor24
Sailor24's Avatar
It is enough to make me clean it again and then I would move it to the inlet side and run the test again. Leaky outlets will cause vanos rattle on startup. 5 is significant but not a game breaker.
Sailor24 is online now
The Following User Says Thank You to Sailor24 For This Useful Post:
austrianvespaguy (19th March 2019)
post #22 of 34 Old 19th March 2019, 02:36 PM Thread Starter
austrianvespaguy
austrianvespaguy's Avatar
Thanks Sailor, I'll go ahead and do another flush on the bank 2 solenoids, but I don't think I want to mess around with swapping stuff with bank 1 as it passed with great numbers, so don't want to mess with that one! FWIW my hot-start rattle has disappeared after the first solenoid maintenance, so clearly was worth doing. In other good news while I was messing around in DIS, I decided to clear the adaptations, reset the throttle mapping, and balance the idle; holy crap what a difference! Throttle response is immensely crisper and I've also noticed a significant improvement in the torque curve. Now I wish I knew what was 'off' previously that was dragging things down, but oh well, she's a totally different car now and I sure hope she stays that way!
austrianvespaguy is offline
post #23 of 34 Old 19th March 2019, 04:32 PM Thread Starter
austrianvespaguy
More good news, pulled the bank 2 solenoids here this morning and sure enough seemed like there was something stopping up the most-outboard noid. Got it flushed and back on the car, reran test and now passes! Still 3 degrees off, but if that passes the test, good enough for me!
post #24 of 34 Old 19th March 2019, 05:40 PM
xrviz
xrviz's Avatar
xrviz is offline
post #25 of 34 Old 26th June 2019, 11:37 PM
pyite
pyite's Avatar
I have a similar question to this one. Should I start a new thread or add to this one?
I have had a fairly quiet dieseling sound for awhile (when I bought the car there were only clicking noises), but after letting the car sit for a couple of weeks the noise is painfully loud. It doesn't go away when the car is warm, and it hasn't cooled down enough for me to try it cold. It sounds like it is coming from the vanos or maybe the top of the timing chain on bank 1 (right side, passenger side in US). It is almost certainly VANOS-related, from what I have read.
Should I buy the $200 drvanos O-ring upgrade kit, or are more parts needed? The car has > 230K miles so I don't mind doing this as Step 1 in the diagnostic process.
Is there anything I should try that doesn't require buying parts or removing the intake manifold (I really don't want to torque down dozens of bolts twice) ?
pyite is online now
post #26 of 34 Old 27th June 2019, 06:16 PM
Sailor24
Sailor24's Avatar
I have no idea what is in a Dr Vanos kit, but it has way more than you need to start with. All you need to start is a set of Drings and this thread.https://www.m5board.com/vbulletin/e3..._full-diy.html
Don't mess with the pistons and other parts until you know the noids are all perfect and doing their jobs.
post #27 of 34 Old 27th June 2019, 07:05 PM
pyite
pyite's Avatar
Just a set of D rings and a gasket.
Thanks, I'll get the rings ordered and test the solenoids while I wait for shipping.
Mark
pyite is online now
post #28 of 34 Old 27th June 2019, 08:43 PM
Sailor24
Sailor24's Avatar
For $200 outrageous. He normally does not sell Drings only the dealers do. He normally had vitron orings, the Drings are better.
post #29 of 34 Old 27th June 2019, 10:11 PM
pyite
pyite's Avatar
It does seem a little steep! What is the best source for these parts?
Thanks again,
Mark
pyite is online now
post #30 of 34 Old 28th June 2019, 01:25 AM
Sailor24
Sailor24's Avatar
Only the dealer has the proper Drings and the cover gasket is just a dust gasket and if it comes out without breaking can be reused. If you do break it it can be temporarily replaced with one cut from paper which will do the job until you get a proper replacement. Some even say run without that gasket, not my preference but I travel a lot of gravel roads.
M5 is sick. Exhaust camshaft VANOS advance value. Please help DJREMIXED E39 M5 and E52 Z8 Discussion 55 30th June 2010 02:33 AM
Vanos knock on start up and a hard blip on throttle. Rezlo E39 M5 and E52 Z8 Discussion 28 25th November 2009 01:45 PM
Start up vanos noise getting louder M5NJR E39 M5 and E52 Z8 Discussion 9 27th November 2006 08:01 PM
Respond only if your E39 M5 had its Vanos replaced. Salty E39 M5 and E52 Z8 Discussion 9 3rd February 2006 02:45 AM
Service Bulletins - VANOS TexasM5 E39 M5 and E52 Z8 Discussion 10 22nd June 2004 03:00 AM
