Supercharger blown intake plenum (again) - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 33 Old 8th March 2019, 10:16 AM Thread Starter
M.A.D.MikE
M.A.D.MikE's Avatar
As the title suggest, i've blown my second intake plenum cover, because blow-off valve was unable to work fast enough. Is there a way to avoid this somehow with cheap fixes, or the only options are
https://www.m5board.com/vbulletin/m5...et-plenum.html or https://www.rkautowerks.com/index.php/product/e39m5cfp/ ?
File Type: jpeg WhatsApp Image 2019-03-08 at 11.53.36.jpeg (111.5 KB, 109 views)
RK Autowerks Stage 2 Kit 620HP
42 Draft Designs Ultimate Oil Catch Can
Setrab ProLine STD oil cooler
Depo Racing boost gauge
Carbon Fiber hood + black kidney grills
16:9 monitor + MKIV retrofit
2000+ facelift steering wheel
E60 545 SSK + F10 M5 shifter knob
Foglights delete + custom front mesh grill
M.A.D.MikE is offline
post #2 of 33 Old 8th March 2019, 10:28 AM
Craze
Craze is offline
post #3 of 33 Old 8th March 2019, 10:49 AM Thread Starter
M.A.D.MikE
M.A.D.MikE's Avatar
Originally Posted by Craze View Post
I believe evolve has a solution
Yeah, i linked it, but $3k is not what i'd call a "cheap fix"
post #4 of 33 Old 8th March 2019, 11:30 AM
Craze
Sorry missed the cheap bit
You are running an m car supercharged
Cheap doesnt fit in that sentence so best to accept that unfortunately
Craze is offline
post #5 of 33 Old 8th March 2019, 12:21 PM
mubarak
mubarak's Avatar
I have blown my stock plenum at high rpm at 8 boost of pressure .
Stock one is very weak for supercharge systems.
I order evolve almunuim ones and now 6 years and all good .
You get what you pay for my friends.
Look at this it is a piece of art.
https://www.m5board.com/vbulletin/e3...ml#post5424386
Thank you
mubarak is online now
post #6 of 33 Old 8th March 2019, 12:26 PM
Ferris
It looks like your blow off valve is further up stream, have you considered moving it to the plenum it'self?
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #7 of 33 Old 8th March 2019, 01:53 PM
TheShafro
TheShafro's Avatar
1. How much boost are you running?
2. In your photo, there should be 4 nuts in the center of the lid. One side I can't see since it's blown off, but the other doesn't have any? Was this plenum modified?
3. Both of those plenum options are a waste of money. As Ferris said, you need your BOV at the plenum, close to the TB's. I've never blown one this way, even with plastic lids at 10psi.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is offline
post #8 of 33 Old 8th March 2019, 04:50 PM
mmzcee
mmzcee's Avatar
wow, never heard of that happening before. Is this a a concern for ESS kits w/ stock pulley?
mmzcee is offline
post #9 of 33 Old 8th March 2019, 05:41 PM
Trizzuth
Trizzuth's Avatar
Also, I'd like to point out that the RK piece is only a grand, as opposed to 3. But damn that Evolve plenum and base is NUTTTSSSSSSS!
Picture of blown plenum was amazing. Thanks for posting that up!
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #10 of 33 Old 8th March 2019, 06:16 PM Thread Starter
M.A.D.MikE
M.A.D.MikE's Avatar
Thank you
I believe you, but $3k is just too much for me
1) Stock RK stage 2 - 9 psi
2) Yes, the plenum kept cracking in the base of 4 mount you mentioned, so i decided to eliminate them altogether (bad idea)
3) Yes, blowoff is on the intake 1-2 pipe, i'll move it on the plenum, thanks for the advice!
Here is my first "blowout" for collection purposes
Intake plenum vacuum line question jcolley E60 M5 and E61 M5 Touring Discussion 15 8th September 2018 10:08 PM
ESS Vortech Supercharger Oil in Plenum, is this normal? ChrisSKillaZ E39 M5 and E52 Z8 Discussion 8 12th December 2017 03:32 PM
DIY: Whews...Finally replace CPS intake - Bank 2 (Cyl 5-8) J Irwan E39 M5 and E52 Z8 Discussion 5 3rd October 2017 06:56 AM
Don't be afraid to pull off the plenum! gherardini E39 M5 and E52 Z8 Discussion 11 6th March 2015 01:48 AM
DIY: Fabrication Chronicles - Making an intake and Modifying a Supercharger rao E39 M5 and E52 Z8 Discussion 23 10th November 2012 11:38 PM
