Supercharger blown intake plenum (again) - Page 3 - BMW M5 Forum and M6 Forums
 5Likes
post #21 of 33 Old 13th March 2019, 05:58 AM
herrubermensch
Originally Posted by TheShafro View Post
1. How much boost are you running?
2. In your photo, there should be 4 nuts in the center of the lid. One side I can't see since it's blown off, but the other doesn't have any? Was this plenum modified?
3. Both of those plenum options are a waste of money. As Ferris said, you need your BOV at the plenum, close to the TB's. I've never blown one this way, even with plastic lids at 10psi.
We had a customer recently crack an aluminum plenum with BOV mounted on the plenum, but he is running nearly 15-20 psi. He is adding a second BOV on the plenum and having his original plenum re-welded and reinforced in some particularly weak places (around the perimeter in particular).
--Peter
herrubermensch is offline
post #22 of 33 Old 13th March 2019, 05:59 AM
herrubermensch
Don't spend more money at RK, they're garbage.
Biased, my friend. Biased. Like with most companies, there is good and there is not as good.
--Peter
post #23 of 33 Old 13th March 2019, 12:17 PM
TheShafro
TheShafro's Avatar
--Peter
At 15psi+, I do recommend adding a second BOV; but most people won't reach those levels. Regardless, having it downstream seems to be an issue.
Ditto, I also have a reinforcement method for the lid.
--Peter
Plenty of first hand experience that form my opinion, not bias. There's good, there's trash, and then there's RK.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is online now
post #24 of 33 Old 13th March 2019, 06:35 PM Thread Starter
M.A.D.MikE
M.A.D.MikE's Avatar
--Peter
I'm running stock 9 psi. Offtopic question, from your experience, how high can you go (in terms of boost) on v3si, stock internals, bosh green injectors (440cc)?
Originally Posted by Silent View Post
It looks like you do a lot of hard launches and your boost peaks above 9psi.
Iíve cracked my plastic one in the past as well.
As Shady mentioned, you need those 4 center mounting posts. Someone local tried what you did and the results were the same as yours.
You have few options,
Get an aluminum lid
Weld the bov adapter on the lower plenum, but you donít have to at 9psi
Get a CF plenum, if cracks have it replaced under warranty
Get evolve
I totally forgot to post the solution to my problem! I got new aluminium lid, and welded BOV on the lower plenum as it's been suggested. The pedal feel is totally different now! It feels like i'm in a sport mode, even when i'm not. I really recommend doing this to anybody with SC setup!
File Type: jpeg WhatsApp Image 2019-03-11 at 15.38.53.jpeg (115.4 KB, 36 views)
RK Autowerks Stage 2 Kit 620HP
42 Draft Designs Ultimate Oil Catch Can
Setrab ProLine STD oil cooler
Depo Racing boost gauge
Carbon Fiber hood + black kidney grills
16:9 monitor + MKIV retrofit
2000+ facelift steering wheel
E60 545 SSK + F10 M5 shifter knob
Foglights delete + custom front mesh grill
M.A.D.MikE is offline
post #25 of 33 Old 13th March 2019, 06:42 PM
herrubermensch
I wouldn't feel comfortable going beyond 12 psi on pump gas.
--Peter
The Following 2 Users Say Thank You to herrubermensch For This Useful Post:
M.A.D.MikE (13th March 2019)
post #26 of 33 Old 13th March 2019, 11:44 PM
Silent
Silent's Avatar
I totally forgot to post the solution to my problem! I got new aluminium lid, and welded BOV on the lower plenum as it's been suggested. The pedal feel is totally different now! It feels like i'm in a sport mode, even when i'm not. I really recommend doing this to anybody with SC setup![/QUOTE]
Probably cause you have no boost leaks.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #27 of 33 Old 14th March 2019, 05:32 AM
TheShafro
TheShafro's Avatar
Now clean that engine bay up. That looks like a salvage title, 7 owner, 4 accident, Glendale craigslist, "$25k I know what I have" car
-Shady H.
@theshafro
'08 JZB/FR E92
lllM3
post #28 of 33 Old 14th March 2019, 06:19 AM
Silent
Silent's Avatar
More like Sherman Oaks
Sold
Silent is offline
post #29 of 33 Old 14th March 2019, 01:49 PM
Trizzuth
Trizzuth's Avatar
I'm glad someone said it! That was the first thing I thought when seeing the original picture, but the latter one is even worse! Almost looks like you drive with your hood off in the winter as they are spraying the roads with salt.
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #30 of 33 Old 14th March 2019, 07:06 PM Thread Starter
M.A.D.MikE
M.A.D.MikE's Avatar
Probably cause you have no boost leaks.[/QUOTE]
It's definitely better then when i had BOV on intake pipe, even when plenum was intact.
I'm more of a substance over looks person
Intake plenum vacuum line question jcolley E60 M5 and E61 M5 Touring Discussion 15 8th September 2018 10:08 PM
ESS Vortech Supercharger Oil in Plenum, is this normal? ChrisSKillaZ E39 M5 and E52 Z8 Discussion 8 12th December 2017 03:32 PM
DIY: Whews...Finally replace CPS intake - Bank 2 (Cyl 5-8) J Irwan E39 M5 and E52 Z8 Discussion 5 3rd October 2017 06:56 AM
Don't be afraid to pull off the plenum! gherardini E39 M5 and E52 Z8 Discussion 11 6th March 2015 01:48 AM
DIY: Fabrication Chronicles - Making an intake and Modifying a Supercharger rao E39 M5 and E52 Z8 Discussion 23 10th November 2012 11:38 PM
