Pierburg fuel pump replacement - BMW M5 Forum and M6 Forums
 2Likes
  • 2 Post By Hakon
post #1 of 8 Old 26th February 2019, 10:19 AM Thread Starter
Hakon
Hakon's Avatar
A heads up when replacing the fuel pump, by itself, not the whole assembly.
When replacing the fuel pump one clip is required to secure the hose to the pump (part No 5)
RealOEM.com - Online BMW Parts Catalog
In the U.K, BMW supply the clamp as a Jubilee / worm clamp and not the Oetiker clamp as seen on disassembly.
The Clamp (No.5) as supplied by BMW in the U.K is the wrong size and does not provide adequate clamping force and subsequently leaks around the hose, once the pump is activated.
I have double checked this with BMW and re-ordered through a different dealer, only to be given the same clamp size again.
I've ordered three sizes of Oetiker and will report once fitted.
Hakon
Hakon is offline
post #2 of 8 Old 26th February 2019, 10:57 AM
Sailor24
Sailor24's Avatar
If they sold you the right part, then they would also have to sell the tool to install it. The way they mark things up that tool would likely sell for around the same price as your first child's education.
Sailor24 is online now
post #3 of 8 Old 26th February 2019, 11:10 AM Thread Starter
Hakon
Hakon's Avatar
Hakon is offline
post #4 of 8 Old 28th February 2019, 04:00 AM
cncmastr
cncmastr's Avatar
Can you measure the supplies clamp?
E30 318is
E46 M3
E53 4.8is
F31 328xi sports wagon
E39 M5 S2
http://obsessedmotorsport.com/blog/
cncmastr is online now
post #5 of 8 Old 28th February 2019, 09:12 AM Thread Starter
Hakon
Hakon's Avatar
The old Oetiker clamp I removed has 11.3 stamped on the side
However I measured the diameter and it was less than 11.3.
I've ordered a number of varying sized of Oetiker clamps and should have them today
Hakon is offline
post #6 of 8 Old 28th February 2019, 07:15 PM
garry_lay
garry_lay's Avatar
Just curious how many miles on your car now when you are changing your fuel pump. I changed the fuel pump on my 2003 M5 at 110K miles shortly after the fuel pump went south on my 2000 540i with 160K miles.
garry_lay is online now
post #7 of 8 Old 1st March 2019, 09:16 AM Thread Starter
Hakon
Hakon's Avatar
80109 miles in 17 years as of yesterday.
As one of the two items that can strand an M5 (fuel relay being the other) and a very reasonable price for the pump alone, as well as being a straight forward DIY job, it was always on the list.
Hakon is offline
post #8 of 8 Old 1st March 2019, 07:27 PM Thread Starter
Hakon
Hakon's Avatar
Hakon is offline
DIY: E60 M5 Master DIY Thread petesamprs E60 M5 and E61 M5 Touring Discussion 100 13th September 2018 08:54 AM
DIY Fuel Pump and Fuel Filter replacement M5 Jed E60 M5 and E61 M5 Touring Discussion 26 9th May 2016 12:25 PM
E39 M5 Fuel Pump Kit w/relay & filter $380 Shipped!! jfoj E39 M5 and E52 Z8 Discussion 34 27th October 2012 03:41 PM
Info needed on fuel siphon pump MPowrd E39 M5 and E52 Z8 Discussion 7 28th July 2012 07:32 PM
B10 BI TURBO fuel pump replacement ? colmorgan100 ALPINABoard.com | BMW Alpina Discussion 17 8th April 2012 09:02 AM
