Transmission Main Bearing - BMW M5 Forum and M6 Forums
post #1 of 3 Old 18th February 2019, 12:33 AM Thread Starter
mfenny
I recently purchased a 2001 M5 with 110k on the odometer. The rear main seal was weeping so we decided to repair it and replace the clutch at the same time. While they had it apart they noticed that the main shaft in the transmission had play in it meaning that the main bearing was going bad. I'm told that the way the bearing is pressed into the housing that it is not replaceable or serviceable; meaning replacing the transmission. I'm concerned about purchasing a used unit not knowing where it came from or how many miles are on it or the condition of the internals. I can purchase a new unit from BMW for $7,500.00 which I will do if I have to.
Has anyone had this experience before or heard of this? Any input would be greatly appreciated!!!!
Thanks!
mfenny is offline
post #2 of 3 Old 18th February 2019, 01:10 AM
Ferris
Don't believe it's not serviceable. It could be a daunting to a diy but a transmission re builder can do it no problem.
for reference check out this guy and this thread, AMAZING and anything pressed in can be pressed out or removed
http://www.m3forum.net/m3forum/showthread.php?t=475959
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #3 of 3 Old 18th February 2019, 01:42 AM Thread Starter
mfenny
mfenny is offline
Please help! Need transmission advice! :( waynehudd2 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 19th November 2016 12:13 PM
DIY: Total Engine rebuild and twin plate clutch s85 with pictures M5v10man E60 M5 and E61 M5 Touring Discussion 60 15th September 2016 02:12 AM
Transmission Noise After New Driveshaft? WTF joeywx E39 M5 and E52 Z8 Discussion 12 2nd February 2012 10:07 PM
Rod and Main Bearing Replacement Quote... rhouse181 E39 M5 and E52 Z8 Discussion 1 18th January 2008 11:38 PM
Understanding main bearing size Ajax5678 E34 M5 Discussion 5 7th March 2007 05:18 PM
