Square wheel setup on stock suspension - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 17 Old 1st December 2018, 11:22 PM
gsfent
gsfent's Avatar
Originally Posted by 3pedal View Post
Are longer bolts needed?
Yes. Good time to change to studs and never worry about it again. There are black plastic caps (VW I think) that fit over the nut and from 5 feet away you can't tell the difference.
As to camber, there is a range. So depending on how wide the wheels are, set it somewhere in the range and monitor your wear. I would max out the fronts, set the rears about the same. Max front is about 1.25 degrees from memory.
It seems toe in has at least as much effect on wear as camber, so set toe in sparingly.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #12 of 17 Old 2nd December 2018, 01:49 AM
CSBM5
CSBM5's Avatar
Front camber is non-adjustable on the E39 without installing camber plates. It's usually between -0.5 and -1.0, stock.
Current stable:
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
gsfent (2nd December 2018)
post #13 of 17 Old 2nd December 2018, 03:28 AM
jojo
jojo's Avatar
I run a square setup on stock springs. 3mm spacers will slightly rub the shock tower at full steering lock.
Ps- even with my 3mm spacers, I wish I could dial in just a bit of neg camber to match the rear.
jojo is offline
post #14 of 17 Old 3rd December 2018, 04:19 PM
KrautHammer
KrautHammer's Avatar
Camber plates are a great addition to our cars since it is non-adjustable from the factory. I consider camber plates along with wheel studs a required "support modification" for square set, or any M5 that might see an occasional track day.
2002 Beast Schwarz-Metallic/Blk Sport
KrautHammer is offline
post #15 of 17 Old 20th December 2018, 03:25 AM Thread Starter
tube
apoligies for the late response, but I do have a follow-up question. if 3mm front rubs the shock tower, do you think a 4-5mm (hub-centric) spacer would be enough to eliminate all scrubbing?
2003 M5 | Carbon Black Metallic | Daily Driven
144k miles (as of April 2019)
Squared 65s | Euro Headlights | CQuartz Ceramic Coating
UUC SSK | UUC DSSR
Muffler Delete | aFe Intake
UUC Twin Disc Clutch
tube is offline
post #16 of 17 Old 20th December 2018, 04:12 PM
KrautHammer
post #17 of 17 Old 3rd January 2019, 10:36 PM
gzig5
Some tires won't rub. My Hankooks didn't, but the Pilot SS just barely kiss the tube with aggressive driving as evidenced by the light rub mark. But, it doesn't affect anything performance or reliability wise. Go with the thicker spacer if you wan that look but you may run into issues with the fender lip depending on your camber setting. 3mm is good to go with stock rear wheels.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
Ideal Square Setup on Stock Suspension? Westyside E39 M5 and E52 Z8 Discussion 19 21st May 2019 06:41 PM
Suspension Alignment specs for a lowered square setup with camber plates? nakedpants E39 M5 and E52 Z8 Discussion 18 19th July 2017 09:59 PM
Anyone running a square wheel setup (9.5s) with staggered tire sizes? [email protected] SW E39 M5 and E52 Z8 Discussion 34 16th July 2017 01:54 PM
Suspension Alignment, maximising tire life (lowered on coilovers and square setup) nakedpants E39 M5 and E52 Z8 Discussion 1 14th March 2013 06:23 PM
E39 Want to buy: wheel spacers & Lugs for Square setup zooop1 Parts / Other For Sale or Wanted 2 19th February 2011 08:12 AM
