My Brake Pedal Feel is Kicking My Butt... - Page 3 - BMW M5 Forum and M6 Forums
 38Likes
post #21 of 209 Old 12th December 2018, 03:11 PM
uhad2point
uhad2point's Avatar
A couple of things, as I too struggled with this:
1. Rebuilding the calipers helps, including the pin bushings, seals, and boots. And it's cheap and honestly not that hard. But, if you're going to do it, do the pistons as well, as they are likely pretty worn.
2. If you're going to use the brake pedal and the pressure bleeder simultaneously, that's okay, just be *really* careful how quickly you let off the pedal, as to make sure that fluid flows out of the bleeder and into the system, instead of pulling any air in as the pedal comes back up.
3. The thickness of your rear brake pads has a big impact on pedal feel. If you have thin pads in the rear, you can get enough caliper flex + pad knockback that when you first step on the pedal, all you're doing is taking the slack out of the rear pads and not actually applying real braking force. I suppose this is true for the fronts also, but I've found that fresh rear brake pads has solved my pedal feel issues more than once.
Ultimately I abandoned ship on the front calipers and ordered Stoptechs. I'm putting them on now. I imagine I'll get spoiled by them and end up replacing the rear brakes too.
uhad2point is offline
post #22 of 209 Old 12th December 2018, 03:27 PM
Ferris
Agree 100% on this point the rears dictate the feel while the fronts do the work.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #23 of 209 Old 13th December 2018, 11:14 PM Thread Starter
mr_g_bock
Update... and responses to past posts.
I have new pads at all four corners. The car has about 77k miles on it and has been garaged most of it's life (last eight years in Florida).
When I last did a bleed with the Motive Power Bleeder along with a ten pedal pump (simultaneously). I had the tubing from the bleed nipple going into the catch bottle and submerged into a couple of inches of clean fluid.
I don't want to just throw new parts on in the hope of fixing this problem. I want to know what is the problem part first. I searched the web for 'how to test a brake booster', 'how to diagnose a brake booster vacuum leak' among variations of these search questions.
1. Engine off > Pumped brake pedal and hold pedal > Start engine - pedal sinks way down to the floor.
2. Engine started and allowed to idle for a minute or so > Shut engine off > Waited two minutes > Pressed brake pedal - initially the pedal felt firm. I maintained firm foot pressure on the pedal which slowly went way down over a couple minutes of time.
Does this conclusively indicate a bad booster?
I am not sure if I am missing something here. I believe the rod that goes through the booster is basically a solid rod. This is hard pinned to the brake pedal arm. The other end is right up against the piston of the master cylinder. So as the brake pedal is depressed, the piston of the master cylinder must move accordingly wither the booster is good or bad (only the amount of effort to push would change). When I have the engine running, the brake pedal goes way down with out too much effort. I can't think that there is still that much air in the system that does not bleed out.
Suggestions please and Happy Holidays to All!!!!!!!
mr_g_bock is online now
post #24 of 209 Old 14th December 2018, 12:43 AM
Ferris
I have to disagree with the booster diagnosis here. Booster provide brake pedal force assist using engine vacuum, on one side of a diaphragm, I've never heard of nor can I comprehend how it can fail in this mode. Typically when it fails it doesn't provide enough assist, it makes noises or it leads to engine vacuum leaks.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #25 of 209 Old 14th December 2018, 04:29 PM
herrubermensch
The fact that the pedal malfunctions only after starting the engine is the first clue that it may be a booster failure. But I agree that the other circumstances are a bit curious. What I can tell you is that in manual brake setups (booster-less), this sort of phenomenon can occur with well-bled brakes only under one or more of the following circumstances:
1. Bad master cylinder
2. Bad slave cylinder
3. Piston seal failure
4. Brake line failure
But none of the foregoing is triggered by starting the engine. So that leads me to conclude it is the booster.
Just my $.02.
--Peter
PS: I will add that manual or boosted systems with ABS theoretically could have an ABS pump failure.
herrubermensch is offline
post #26 of 209 Old 14th December 2018, 04:42 PM
Ferris
Just my $.02.
--Peter
I don't disagree with the logic, however , I can't see a failure mode of a booster that allows this to happen, unless the rod/spring ect is deflecting and that's the additional movement and it's not being transmitted to the hydraulic. I'm not saying crazier illogical **** can't happen but I'm still skeptical
That said let me ask the OP this question, when you did the test was the car off and then you started or was it on but the engine not running? If it was off and not not running, I'd suggest turning to on but not start the engine. This way the ABS pump and system is energized but the booster is not under vacuum. I'd also suggest, if you can reset the faults, to disconnect the abs pump and body and try again (or just pull the fuses)
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #27 of 209 Old 14th December 2018, 05:19 PM
xrviz
xrviz's Avatar
The job of the booster is to make it easier to push the pedal, less force required. Your pedal sinks to the floor when you start the engine. The booster is working! Can it fail in a way that makes it work too well? I don't see how.
Sounds to me like the booster is working with an under-resistant circuit, so air in the circuit, a leak, or bad seals.
xrviz is offline
post #28 of 209 Old 15th December 2018, 03:08 AM Thread Starter
mr_g_bock
Still a crazy situation...
After I bench bled the master cylinder, I mounted it to the booster out of the car. I am very sure that the booster rod aligned up to the master cylinder piston. Makes sense that the booster is working to allow added force to the MC piston.
I just ordered up all of the parts to rebuild the calipers (o-rings, boots, pistons, guide pins with brass bearings and proper assembly lubricants). I will do the calipers, re-bleed and see if there is any improvement.
I was able to use ISTA+ to work all of the ABS valves and pumps. I don't think there is an issue with it, also since it is a separate closed system when not activated, it should have no effect on normal braking conditions.
When I next test, I will pull the DSC & ABS fuses to remove that from the equation.
This work may take me a couple of weeks to complete as parts were just ordered tonight.
Thanks Guys!!!!
To be continued...
post #29 of 209 Old 15th December 2018, 04:41 PM
herrubermensch
I hear you. Just weird that none of that "circuit" seems to fail until the engine is turned on. Generally, such a leak would show itself with the engine turned off as well.
--Peter
post #30 of 209 Old 15th December 2018, 05:14 PM
xrviz
xrviz's Avatar
--Peter
My guess is if you compared OPs pedal with your car's pedal with engines off you would feel a difference. Then with engines on your pedal is easier and his goes to the floor.
xrviz is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mr_g_bock
Brake pedal feel, engine on/off question... mr_g_bock E39 M5 and E52 Z8 Discussion 14 1st August 2018 04:31 AM
Brake pedal travel/feel Hakon E39 M5 and E52 Z8 Discussion 4 30th November 2010 09:21 AM
Weird Brake pedal feel. mruiz0280 E39 M5 and E52 Z8 Discussion 27 23rd November 2006 08:43 PM
Brake pedal feel RichardM5 E39 M5 and E52 Z8 Discussion 1 23rd June 2006 12:48 AM
Spongy brake pedal feel madmax E39 M5 and E52 Z8 Discussion 18 28th January 2004 11:31 PM
