Front Subframe / Axle Carrier control arm mount. Repair or Replace? - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By herrubermensch
  • 1 Post By Landscraper
post #1 of 6 Old 26th November 2018, 09:59 PM Thread Starter
Landscraper
Landscraper's Avatar
While swapping out control arm bushings for monoballs I discovered - to my horror - the hole for the driver's side rear control arm (the straight one) mount in the subframe had 'wandered' (see images below).
I suspect this is due to not being torqued to spec.
My question is whether it's worth it to try and repair/patch the mount or just pony up and swap out the entire subframe? I assume the latter will come with a labor cost premium.
Landscraper is offline
post #2 of 6 Old 27th November 2018, 02:57 PM
herrubermensch
Ugh. I would replace. Cheap part (get from Clemster) and do it yourself over a weekend. That said, I'm sure it could be welded back into spec.
--Peter
herrubermensch is online now
post #3 of 6 Old 28th November 2018, 01:29 AM Thread Starter
Landscraper
Thanks Peter,
It looks like removing the front subframe will require suspending the engine?
post #4 of 6 Old 28th November 2018, 02:44 AM
herrubermensch
Thanks Peter,
Correct! And if you have never done it before, it sounds like a big deal, but I assure you, it is not! I absolutely have done this myself--no help--many times. It is rather easy. It just SEEMS daunting. But it's not.
--Peter
I also note that you are in Seattle. My son, Sam (boardmember with his own E39 M5), starts at Cray Supercomputer this Summer after he graduates, so if you want some help, he and/or I can certainly provide it at that point!
--Peter
post #5 of 6 Old 29th November 2018, 12:44 AM Thread Starter
Landscraper
--Peter
--Peter
Thanks for the vote of confidence Peter and for the very generous offer. Hopefully I will be done with the subframe by the summer.
Congratulations to your son at what sounds like a very cool job (i've always been curious about the work Cray does). If you guys want any local recommendations, advice, or even a tour guide I would be happy to help.
post #6 of 6 Old 28th February 2019, 10:27 PM Thread Starter
Landscraper
Just to close the loop. Had the subframe replaced. No sweat.
I had a very reputable frame shop (Tru-Line) take a look and they thought it would be very easy to repair and did not warrant the replacement, but I wanted the peace of mind.
Rear subframe diff mount just broke in half. What are my options for repair tube E39 M5 and E52 Z8 Discussion 18 10th October 2018 04:39 AM
Rear diff mount/axle carrier repaired BenTong E39 M5 and E52 Z8 Discussion 10 20th November 2015 05:41 PM
New BMW Campaign "Rear axle carrier"??? Tonygoalie E60 M5 and E61 M5 Touring Discussion 3 18th September 2009 05:34 AM
Differential broke from rear axle carrier! ///Nima E39 M5 and E52 Z8 Discussion 20 5th July 2006 11:34 AM
Axle carrier bushes ECM4 E34 M5 Discussion 23 16th February 2005 04:11 PM
