Trying to Print a MPH Speedometer - Need Help w/ Dimensions - BMW M5 Forum and M6 Forums
 4Likes
  • 2 Post By TheShafro
  • 1 Post By gsfent
  • 1 Post By josiahg52
post #1 of 9 Old 23rd November 2018, 08:23 PM Thread Starter
youngbreezy310
I'm having a '00 M5 imported to the US from Canada, and per customs rules the speedo needs to be converted from km/h to mph. I'm trying to avoid switching out the entire speedo cluster in efforts to preserve both the cars originality and my wallet, and have the idea of printing out a MPH faceplate on a material like vinyl that I can lay over the existing gauge.
I don't have access to the car right now. Is someone able to tell me the diameter of their kmh speedo and perhaps measure the angles where 20 and 300 km/h sit from vertical so I can use as reference points?
Any other ideas, tips, or experiences are appreciated. Look forward to joining the club.
youngbreezy310 is offline
post #2 of 9 Old 23rd November 2018, 09:00 PM Thread Starter
youngbreezy310
Alternatively, if someone can tell the angles of their US speedo at 20 and 180 that'd probably work too.
post #3 of 9 Old 23rd November 2018, 09:01 PM
TheShafro
TheShafro's Avatar
You want to preserve originality but print an overlay speedometer? Dude c'mon LOL
The work involved alone isn't worth it. I'd get a used or see if you can rent one from @blackknight530i till you pass inspection. He also has or had black cluster faces for sale.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is offline
post #4 of 9 Old 23rd November 2018, 09:03 PM Thread Starter
youngbreezy310
It would be temporary on a material that wouldn't require adhesive. I'll give him a shout thanks for the feedback.
post #5 of 9 Old 24th November 2018, 12:26 AM
josiahg52
josiahg52's Avatar
My M5 had a US clock set with grey dials. I bought one with black dials and the repair shop who repaired my robbon cable swapped the dials at no cost. Maybe do something similar and bulletproof your ribbon cable at the same time. Now I want to find a black UK set with MPH and Celsius oil temperature.
josiahg52 is online now
post #6 of 9 Old 27th November 2018, 07:15 PM
gsfent
gsfent's Avatar
Don't think they were made that way. The board containing the gauge faces is a single board. So it was printed with either European markings U.S. markings. It is not like swapping gauge faces.
I would check with Blackknight530i as he is as familiar as anyone with these clusters.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
post #7 of 9 Old 28th November 2018, 02:04 AM
blackknight530i
blackknight530i's Avatar
Actually, the UK did get clusters with MPH and Celcius for temps. They are actually marked UK under the speedo gauge, where our US ones have a US printed there. The UK also had black faces as early as 98 I believe, so more of them available.
If someone finds one with black faces and bad pixels, send it to me and I can install them on one of the new design clusters that doesn't suffer from pixel failures. It will be mileage corrected and coded to your car.
-Paul
2003 "M5" - S62/420g swap, M5 diff, M5 driveshaft, M5 brakes, M5 Traction Bars, M5 Bumpers, M5 Full Leather Interior Swap, M5 Gloss Shadowline, M5 Mirrors, M5 Gauge Cluster,
M5 Ground Control Coilovers, Eibach Sway Bars, UUC Evo3/DSSR, M5 Borla Exhaust w/Muffler Delete, BMW NBT Retrofit, Hella G4 Bi-Xenon Retrofit, APEX PS-7s, e60 Hubs
530i 6-speed swap build thread
2003 530it6 - M54b30/S6S-420g swap, 3.15 540it diff, e60 SSK, VMR VB2 19" Wheels, M5 Gauge Cluster, Hella G4 Bi-xenon Retrofit, NBT Retrofit, Koni Sports, 540i Brakes
2002 540it - Coming soon
blackknight530i is offline
post #8 of 9 Old 29th November 2018, 03:15 PM
josiahg52
josiahg52's Avatar
Unfortunately, I haven't seen a black UK/mph set in years. When I do and if I get it, I'll be in touch with you. My ribbon cable has already been remedied but you can do the swap.
post #9 of 9 Old 29th November 2018, 08:59 PM
DennisCooper
DennisCooper's Avatar
Hi Joshiah & Blackknight!
Josiah - I have two UK Black face M5 clusters sitting in my E39 goodies storage and I'm willing to work out a deal for you - your wait is over - drop me a PM !
Blackknight - I know you had a forum post either here on on the bimmerforums channel, but I can't find it! Do I recall that you can have Black Face (or any other colour) high quality faces printed? or am I just imagining that? I do have one of my industry level contacts who can make custom high quality faces, I believe they do stuff for Lotus the last time I spoke to them. I will find out more.
Youngbreezy - Your idea is decent, but the quality won't be good nor will it last too long if you use vinyl. With the heat of the dash area and cabin temperatures especially if you live in a hotter summer area (LA I know gets very hot in summer!) the vinyl will likely peel or bubble quite quickly. Also, you'd need to get a vinyl that is translucent enough. I will get in touch with the contact I have here who are able to make automotive grade cluster faces/overlays and update.
I have the 'Police' clocks/overlay in my car and a spare set of them as well, toying with the idea of having a custom set done (if the place can do it of course!) in a different colour !
Cheers, Dennis!
2003 Ex-Police E39 530 Diesel Touring. Alpine White, 260,000+ Miles & climbing!
Wheels;
19" Hartge Nova 5 - with custom painted 'Flash Chrome' centres & Polished Lips (set of 5)
19" Hartge Nova 5 - Awaiting custom re-finish (set of 4)
19" Hartge Classic - with custom powder coated centres in shadow chrome & diamond cut/no lacquer lips (set of 5)
20" Hartge Classic - Awaiting custom re-finish
19" 3Pc Forged wheels - ID retained until re-built & finished (2 sets)
20" 3Pc Forged wheels -ID retained until re-built & finished
19" Centres - ID retained until rebuilt & finished
Audio;
Full Custom Audio install - Arc Audio KS Mini ampliifers. DLS 5.25" 2 way front components & 4" 2 way co-axials. JL Audio 8W3-V3 subwoofer in stealth enclosure. Parrot Asteroid Smart head unit, custom door builds for DLS front stage & Earthquake SWS6 flatline subwoofers, custom rear pillar speaker pods. LumiDock iPod dock,
External;
H&R Springs, ExoticsTuning front lip spoiler, Sport F/R bumpers upgrade, Carbon Fibre effect printed Vinyl roof wrap, High gloss black vinyl window trim wrap, Hartge bonnet/hood & tailgate badges, rear rooftip spoiler, matt Black kidney grille, projector foglamps.
Internal;
Hartge auto gearlever, Hartge Handbrake handle, Hartge door sill strips, E46 M3 CSL Alcantara/Tri-stitch SMG steering wheel, full Black Leather Sport seats,
Engine;
Custom ECU re-map biased for more Power & Torque in Steptronic mode, EGR delete, K&N induction kit, Stainless steel de-cat, Stainless steel exhaust backbox with twin oval pipes. Manual 5 spd gearbox conversion.
Plenty more modifications to come!
DennisCooper is offline
Why is there a red line at the 55 mph mark on the speedometer? FitForFives E34 M5 Discussion 6 5th October 2008 02:14 PM
Pointers to v23 fixes (need to print and show my dealer) *FOUND IT* scoopz E60 M5 and E61 M5 Touring Discussion 5 31st October 2006 05:40 PM
Help reading DCS Print out... benjjman007 E39 M5 and E52 Z8 Discussion 11 23rd September 2006 07:28 AM
New 911 Turbo: 225 mph on the speedometer Gustav Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 3 12th January 2006 04:57 PM
speedometer upgrade for Z8 in mph?? clauswagner E39 M5 and E52 Z8 Discussion 30 11th August 2002 05:41 PM
