Mileage on Our Beasts - BMW M5 Forum and M6 Forums
 12Likes
post #1 of 55 Old 9th November 2018, 09:22 AM Thread Starter
Vladimir
Vladimir's Avatar
My car (2001 European model) is approaching 210,000km (130,000 miles) and is running smoothly, with the exception of some electrical problems. I've been trying to take good care of it and have not had any serious problems with the engine or other major parts. I replaces most of the rubber gaskets on the engine and other elements some 3-4 years ago and some parts which were mentioned as possible problems on threads here.
What is your experience? What mileage do you have on your cars and how long did the engine last without a need of a serious repair?
'01 BMW M5 LeMans Blue
Previously
'01 BMW 316 i
'88 Audi 80
Pilot eLogbook
Swiss Flight
Vladimir is offline
post #2 of 55 Old 9th November 2018, 09:27 AM
neilb62
neilb62's Avatar
109500 miles (2001 car) Iíve replaced the thermostat main coolant hoses, radiator and viscous fan but apart from servicing Iíve never been inside the engine.
neilb62 is offline
post #3 of 55 Old 9th November 2018, 03:22 PM
Obioban
Obioban's Avatar
Obioban is offline
post #4 of 55 Old 9th November 2018, 03:26 PM
mubarak
mubarak's Avatar
102000 miles ,,,2003 ,,supercharged it at 55000 miles in January 2012,,
Did the following prior to supercharged :
Thermostat,,replace all coolants hoses ,,replace radiator ,,replace all hoses under plenums,,waterpump,,fan clutch ,,clutch and flywheels,,fuel pump and fuel pressure regulator,,alternator,,,starter,,all suspensions undercar,,engine mounts,,short shifter,,valves cover gaskets,,RMS rear main seals,,change all fluids in car,,Evap under plenums ,,I hope I did not forget something
Car running excellent,,and pushing 485hp at wheels.
Thank you-
mubarak is offline
post #5 of 55 Old 9th November 2018, 05:21 PM
pguinnane
pguinnane's Avatar
Im at 197xxx miles and sheís daily driven, bought her in March at 186xxx. Pulls like a train and Iíve been picking away at some deferred maintenance from PO.
'01 ///M5 Anthracite
pguinnane is offline
post #6 of 55 Old 9th November 2018, 05:29 PM
Code_Monkey
Code_Monkey is offline
post #7 of 55 Old 9th November 2018, 06:37 PM
M3Fan
Just cracked 170K, drive it every day 30 miles each way on the highway.
Evolve Alpha-N tune, FMU Rear Exhaust, E60 Shifter
M3Fan is offline
post #8 of 55 Old 9th November 2018, 07:27 PM
dreamerz679
185K, daily driver though I work from home now. Timing chain guides at 125k, otherwise normal maintenance.
dreamerz679 is offline
post #9 of 55 Old 9th November 2018, 08:34 PM
M3Fan
... and @170K no major work on my motor. Original guides and bearings. I think the fact that it drinks 10L of oil between oil changes means it's always had fresh oil!
M3Fan is offline
post #10 of 55 Old 9th November 2018, 11:10 PM
Awake77
137kmi on mine. Just did a full tuneup and sent the oil out to Blackstone, everything is looking great internally. Original guides and bearings. I change my oil every year or every 4000 miles, whichever comes first
-C
2001 Lemans Blue M5
1999 Ducati 900SS
1995 Honda Accord
1996 Ford F-250 460 w/ZF5 \m/ \m/
Awake77 is offline
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
JohnAnthony
Who has high-mileage Beasts? t10001 E39 M5 and E52 Z8 Discussion 22 14th May 2008 06:10 PM
A Gaggle of E60 Beasts & Two Stray E39 Beasts MCarRacr07 Sightings / Spotted M5 around the world: was it you? 9 14th November 2006 03:36 PM
High Mileage Beasts Frank the Tank E39 M5 and E52 Z8 Discussion 15 7th September 2005 11:32 AM
Kerosene bath for our beasts! schnelleM5 E39 M5 and E52 Z8 Discussion 12 14th January 2003 08:18 PM
S. Florida "Beasts do the Beasts!" MarkM5Lauderdale E39 M5 and E52 Z8 Discussion 12 30th July 2001 03:08 AM
