Mileage on Our Beasts - Page 4 - BMW M5 Forum and M6 Forums
 12Likes
post #31 of 56 Old 2nd December 2018, 04:45 PM
JohnAnthony
JohnAnthony's Avatar
The biggest downside that comes with mileage, is the electrical connectors. After enough heat cycling they start to crumble when you try to remove them, I'm already looking at what my options are for replacing the connector vs. splicing the BMW replacement wire looms.
JohnAnthony is offline
post #32 of 56 Old 3rd December 2018, 05:01 PM
wilsodh
wilsodh's Avatar
Originally Posted by Sharocks View Post
Picked up a 230k 2000 Royal Red/Caramel 2 Owner car a few months ago. Been slowly getting her back out of DD shape.
Love Royal Red ... but I'm biased. I had a parking lot mishap a couple of years ago.. some dude texting ran into my left front at low speed. The replacement panel/hood look great, but alas the original RR paint has faded a bit, so there is a slight mismatch between the new and original panels. The unfaded paint is deeper and more stunning than the faded... reminds me why I loved the color so much back in 2005.
I'm the second owner of the car....150k miles now, and still on the original clutch! Recently did rear main seals and the clutch still looked pretty good so I didn't replace it. There's a history on this board ragging about the weak clutch of the e39 M5. I've never tracked this gal, so I've not had any reason to complain!
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
post #33 of 56 Old 3rd December 2018, 08:33 PM
Obioban
Obioban's Avatar
Obioban is offline
post #34 of 56 Old 3rd December 2018, 09:25 PM
booster_
I'm at just over 100k, and so far the must do things excluding wear/tear items are:
RMS/clutch
valve cover gaskets
oil pan gasket
power steering lines
EVAP valve
rear view mirror leak repair
cluster pixels
thermostat
sun roof
I'm also doing a lot of extra maintenance work:
Full suspension
drive train bushings, etc
VANOS accumulator upgrade
shifter/bushings upgrade
Navi screen
exhaust (headers/decat left to do)
need rear tires (got 10K out of first set)
fuel filter
Vanos maintenance (seals/boards)
booster_ is offline
post #35 of 56 Old 10th December 2018, 10:32 PM
rdsmith85
2001 LMB -163K - Daily driven and ironically enough has proven to be the most reliable E39 I've ever owned. CEL light on b/c of SAI, will code it out eventually.
rdsmith85 is offline
post #36 of 56 Old 15th December 2018, 02:50 AM
KevinM
KevinM's Avatar
I'm at 98K miles. It was my daily driver from 2004 - 2016. Overall it has been very reliable. I've had to do no significant engine work, but have been compulsive about maintenance. I've only been stranded once. At 70K miles or so the relay sensor for the gas level went out and the fuel indicator read 1/8th of a tank but I ran out of gas...which killed the fuel pump. I've done all the usual maintenance and the T-stat needed to be replaced at 60K miles. Most recently, the plastic radiator cracked and one of the two rubber brake lines near the engine sprung a leak. If anyone is close to 100K miles, consider replacing the radiator (and while you are there, the hoses, etc.) and the break lines.
Kevin
2016 F80 M3, Mineral Grey/Golden Brown/6MT - ED delivery 6/3/2016 http://f80.bimmerpost.com/forums/sho....php?t=1291837
2007 Z4M Coupe Silver Gray/Black
Too many kids' cars...
KevinM is offline
post #37 of 56 Old 21st December 2018, 12:01 AM
TexaZ3
TexaZ3's Avatar
Just hit 115K last week. Barely broken-in.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #38 of 56 Old 31st December 2018, 03:02 PM
Marvinnga
Marvinnga's Avatar
Marvinnga is offline
post #39 of 56 Old 31st December 2018, 07:35 PM
amancuso
amancuso's Avatar
I'm at 153,xxx. Not a DD, but afraid to drive it anywhere, anytime, and oddly enough, one of the most "reliable" e39s I've owned.
2003 M5/Sport Imola/Imola
amancuso is online now
post #40 of 56 Old 31st December 2018, 08:55 PM
e39s62m
e39s62m's Avatar
My 2001 just crossed 100,000 miles. I've put about 6,500 miles on the clock in the 13 months I owned her. Reasonable shape when I picked her up, prior documented work included some CPS and a clutch, but decided to go all in:
* PDR, paint correction
* rod bearings (while in there cylinder walls and other internals looked great)
* VANOS overhaul (had to come out anyway for a very slight oil seepage)
* thermostat
* suspension refresh (new struts, thrust arms, Dinan rear sway bar, etc.) - this made the most immediate difference in the feel of the car, magic blend of supple and tight
* Leatherique treatment last summer
* refinished wheels and PSS4S (and a separate less impressive set with winter rubber for the cold months)
* Dinan CAI, exhaust and tune
* Avin Avant 3 head unit
* Bavsound speaker upgrade
* a few hoses as I've noticed weeping or brittleness
*steam cleaning underneath and some new cosmoline in potential trouble areas (it's my daily, and while I try to stay out of the worst of it, the brine and salt that goes down on the roads hangs around for a while)
Absolute joy, and hope to still be driving her when 200,000 ticks over.
2001 Anthracite M5
e39s62m is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Who has high-mileage Beasts? t10001 E39 M5 and E52 Z8 Discussion 22 14th May 2008 06:10 PM
A Gaggle of E60 Beasts & Two Stray E39 Beasts MCarRacr07 Sightings / Spotted M5 around the world: was it you? 9 14th November 2006 03:36 PM
High Mileage Beasts Frank the Tank E39 M5 and E52 Z8 Discussion 15 7th September 2005 11:32 AM
Kerosene bath for our beasts! schnelleM5 E39 M5 and E52 Z8 Discussion 12 14th January 2003 08:18 PM
S. Florida "Beasts do the Beasts!" MarkM5Lauderdale E39 M5 and E52 Z8 Discussion 12 30th July 2001 03:08 AM
