E39 M5 is there a post with the complete fluid s`pecs - BMW M5 Forum and M6 Forums
post #1 of 4 Old 1st November 2018, 06:21 AM Thread Starter
ruprectgern
ruprectgern's Avatar
hey.
I'm changing up my fluids choices and I want to make sure that whatever I use (Liqui Moly most likely) meets or exceeds the standards set by BMW.
I'm hoping there are specs for all the fluids, engine oil, ps, brake, coolant, Transmission, clutch, Differential
while the factory viscosities are nice to have, I am speaking directly to the industry standard specifications that define whether a fluid meets the manufacturer's standards.
RG
-- RG
2001 E39 M5 Anthracite/Black/Titan
Evolve Tune, Muffler Delete(vibrant 1331s), E60 Short Shifter, F10 ZHP Knob, UUC DSSR,
Bilstein PS9 Coilovers, RKAutowerks Radiator W/Electric Fan, Derale PWM, RKAutowerks Oil Cooler,
Umnitza ICE VXX, Sink Drains, Euro Dash, LiquiMoly
ruprectgern is offline
post #2 of 4 Old 1st November 2018, 08:21 PM
gsfent
gsfent's Avatar
Originally Posted by ruprectgern View Post
hey.
RG
Wouldn't that be in the Owner's Manual?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #3 of 4 Old 2nd November 2018, 07:36 AM Thread Starter
ruprectgern
You would think there would be a table or individual info, but there isnt, the only reference to engine oil specs, for example, say that IF you cant find BMW brand oil, you can add small amounts of synthetic oil to the crankcase until you can get some BMW oil... and that you should use only oils with the API SH specification or higher.
I've always been under the impression that automotive fluids have diff stuff in them, amounts of sulfur and other chemical properties that meet the standards of the application.
the owners manual PDF that I have, is very light on information in these areas.
-- RG
post #4 of 4 Old 3rd November 2018, 07:01 AM
gsfent
gsfent's Avatar
You have the spec to look for on oil. Most approved oil is Long Life (LL). There is a ton of info on oil specs on here. Search is your friend (although it will take some sorting).
Personally, I use either LM 10w-60, or M1 15w-50 (not cold where I live). I like M1 synth ATF for power steering, M1 75w-140 fluid for the diff, and MTL for the tranny.
gsfent is offline
E39 For Sale: Complete E39 BAVSOUND Soundplicity Control III. Bluetooth complete integration OneWheelDrive Parts / Other For Sale or Wanted 19 29th April 2015 08:35 PM
E39 For Sale: *******E39 2003 BMW 530i M-Sport Complete M5 Clone*************E39 2003 BMW 530i M-Sport Complete M5 Clone****** LeKhans Cars For Sale or Wanted 3 19th February 2015 10:19 PM
so what type of transmission fluid and diff fluid do you use? markus037 E39 M5 and E52 Z8 Discussion 20 11th December 2013 04:55 AM
SMG hydraulic fluid or trans fluid? 2006M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 4th October 2011 02:32 AM
Trans Fluid / Rear Diff fluid Process... rxpwhistler1 E39 M5 and E52 Z8 Discussion 7 3rd September 2009 04:22 AM
