Brake hoses - preventive maintenance - Page 3 - BMW M5 Forum and M6 Forums
 3Likes
post #21 of 21 Old 27th March 2019, 08:22 PM
kiznarsh
kiznarsh's Avatar
Originally Posted by CSBM5 View Post
Anything downstream of the furtherest upstream connection that is disconnected will have air bubbles that need to be pushed through it. As long as a connection is not undone (and air is not introduced) upstream of the ABS unit, you should be fine. Brake fluid flows right through #1 & 2 all the time, and bleeding will or course force fresh fluid through them. In other words, all fluid flowing from the master cylinder to the calipers will only be flowing through those lines.
In that case, a standard bleed should take care of it. I have 2 fresh bottles and may just flush with 2 liters for completeness.
Thanks.
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
Preventive Maintenance L3NGHRN E39 M5 and E52 Z8 Discussion 14 19th November 2009 12:59 AM
Airco preventive maintenance question(s) '95 3.8 Crash & Burn E34 M5 Discussion 2 27th May 2009 05:01 PM
Preventive maintenance dj leethal E34 M5 Discussion 12 30th July 2008 05:55 AM
Preventive Maintenance? CWY_M5 E39 M5 and E52 Z8 Discussion 11 7th November 2006 07:30 AM
Preventive maintenance: Intake, coolant system etc raymondw E28 M5 Discussion 27 13th July 2005 08:32 AM
