E39 M5 in LA (The "mu5") - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 24 Old 11th September 2018, 09:19 AM Thread Starter
prr
prr's Avatar
As a husband and wife team, we purchased a 2002 Titanium Silver M5 on August 26th and we thought it would be fun to document our maintenance, repairs and restoration of the car. As a background, the husband has some experience working on cars while the wife is eager to learn! The car is in good shape for its age and mileage of roughly 126k. It was a daily driver for a while but recently has not been driven much. We just ordered a Peake code reader as well.
We took it for a PPI and they said the following things would be good to address:
Oil Change (done below)
Wiper Blades (doesn't rain much here but will get to it soon)
AC belt is worn (will diy soon)
Water Pump looks like its may need to be replaced (have been told by some may need to replace the whole cooling system in that case)
Flex Disk is cracked
Cabin air filters (they looked fine to us but we can diy if we need to)
Valve cover gaskets (will diy at some point, but the car appears to not leak any fluids and its parked in the same spot each day and one was done about 20k ago)
Rear Main seal (was told this may reseat given the car was rarely driven lately and if this does need to be replaced may do the clutch too, which still feels great)
Power Steering hoses are said to leak so we will monitor the fluid levels
The previous seller changed the transmission and differential fluid around 115k miles and the spark plugs around 110k miles so we have some time before that routine maintenance will be needed again. Brake Fluid was changed at the 100k service
Work done so far:
The second day of ownership the fuel pump failed so we had that and the fuel filter replaced and took the opportunity to get an oil change then as well. Not the best start as that looks like a reasonable DIY job but given we had the car towed to the shop and needed to get it back out on the road we did not have another option.
New rear tires- Michelin Pilot Sport 4s
Project List:
Fill in/ repair paint chips on hood and buff out various scratches
Figure out a way to do bluetooth whether it is with stock head unit or aftermarket such as a Dynavin
Replace AC belt
Replace Expansion Tank Cap
Coolant Flush - i dont see a record of this having been done and it does not look like it was done at 100k
Replace flex shaft
Replace Valve Covers
Replace power steering hoses
Replace water pump
We can't wait to detail our journey with the car and hope that we can both learn and teach by doing so. Please if anyone has any comments or advice we are all ears. Also we have an instagram: @mu5adventures so feel free to follow!
And now for some pics:
prr is offline
post #2 of 24 Old 12th September 2018, 01:52 AM
Lloyd Braun
Lloyd Braun's Avatar
Lloyd Braun is offline
post #3 of 24 Old 12th September 2018, 02:20 AM
garry_lay
garry_lay's Avatar
You might also want to consider replacing the 2 MAF sensors, 4 CPS and 2 TPS. I replaced these just a few months ago on my 2003 with 114K miles and the car is running much better since.
garry_lay is online now
post #4 of 24 Old 12th September 2018, 04:25 AM
KevinM
KevinM's Avatar
If the CPS and MAFS are original, I definitely agree with Garry. At that mileage, consider replacing the radiator and the fan clutch as well. I assume the O2 sensors were changed at 100K (although I change the pre-cat O2 sensors every 50K miles). Do you have many maintenance records?
Welcome!
Kevin
2020 M2 Competition, Hockenheim Silver/6MT
2007 Z4M Coupe Silver Gray/Black
2016 F80 M3, Mineral Grey/Golden Brown/6MT European Delivery - gone
KevinM is offline
post #5 of 24 Old 12th September 2018, 05:34 AM
M5hane
I'm also in LA and just picked up your car's twin (albeit a 2003 with 80k miles)!
Mine came with pretty good maintenance records but I just replaced MAF's and have Pre-cat O2 sensors on the way. MAFs made a big difference in low rpm responsiveness for me. Hoping for similar level of improvement with the O2 sensors.
Enjoy in good health and I look forward to you documenting your restoration!
M5hane is offline
post #6 of 24 Old 12th September 2018, 03:52 PM
Silent
Silent's Avatar
If you need any help feel free to PM me.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #7 of 24 Old 12th September 2018, 07:31 PM
garry_lay
garry_lay's Avatar
Welcome!
Good point about the O2 sensors. I also replaced all 4 O2 sensors shortly after I got the car. Haven't replaced the radiator yet but will probably do that very soon.
post #8 of 24 Old 13th September 2018, 12:27 AM Thread Starter
prr
prr's Avatar
This is great. We will add the radiator to the list. The car did come with a decent set of records from the prior owner who bought the car at 86,701 miles
The CPS were replaced at 111k
R side valve cover gaskets were replaced at 105k (the receipt refers to this as bank 1) but the PPI said that both should be replaced so we will get to it at some point.
O2 sensors have not been replaced as the previous owner said it never failed smog but it seems many on the forum recommend replacing the pre-cat sensors.
MAFs were cleaned 5k ago so I will probably wait on those for a bit longer.
The code reader came yesterday so we will take a look to see what it says tonight.
prr is offline
post #9 of 24 Old 13th September 2018, 12:56 AM
kiznarsh
kiznarsh's Avatar
Nice find! Looks like a good example that's maintained well enough to be worth the purchase but still has plenty to keep you busy.
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is online now
post #10 of 24 Old 13th September 2018, 05:31 AM
KevinM
KevinM's Avatar
The collective experience of the board is that cleaning the MAFS usually results in a temporary improvement (I've never tried it). If your MAFS truly have 85K on them, you might notice a welcome improvement in performance by replacing them. Or not...I replaced mine at 60K just for kicks and didn't really notice much. If the O2 sensor have not been replaced, I'd definitely at least do the pre-cat ones. The post-cat sensors can wait until 100k miles or longer.
Kevin
KevinM is offline
Are "Shadow Chrome" and "Hyper Silver" the same color? What's correct for E39 M5's? corellian corvette E39 M5 and E52 Z8 Discussion 3 1st November 2014 10:13 AM
ModBargains.com l No Holes BMW License Plate Holder l No more front plate tickets !!! [B][URL="www.modbargains.com"][COLOR="DarkRed"]ModBargains.com[/URL][/B][/COLOR] is happy to present the [URL="http://www.modbargains.com/N Modbargains.com M6 E63 Group Buy and Sponsor Discussion and Offerings 0 5th February 2011 10:31 AM
Formerly "E46 in Philly" now "E39 in Philly", hello from a new owner... E39 in Philly E39 M5 and E52 Z8 Discussion 19 19th May 2005 03:30 PM
Anyone with a spare 18"X8" wide M5 wheel want to trade for a rear 18"X9.5" Orinoccom5 Parts / Other For Sale or Wanted 0 21st August 2003 07:11 PM
"M5 SLAYERS" article on "EUROPEAN CAR MAGAZINE" website just released!!! JIMMY GTBoard.com: General Sportscars 11 12th August 2003 10:31 AM
