Quick reminder how to get rid of US spec long clutch pedal travel. - BMW M5 Forum and M6 Forums
 4Likes
  • 3 Post By BWM
  • 1 Post By mgdmb
post #1 of 5 Old 13th May 2018, 12:28 AM Thread Starter
BWM
It was probably mentioned here before but here it is anyway:
I hated the fact that my car had a long clutch travel and after I installed thicker clutch pedal stop, I had the problem with car not starting due to piston not depressing all the way. On 03 the EWS / cruise switch is integrated with the piston and I've seen some posts where rewiring that sensor resulted in some limited success. Plus, I really prefer not to rewire anything that is connected with EWS.
Than I though about my P.A Soft and sure enough, simple as a pie:
Go to EWS coding data and there is a section with 2 options: US automatic gearbox / clutch (that was default on mine) and Euro manual gearbox option. Switched to Euro manual gearbox, saved the data and voila, car now starts without pressing the clutch pedal.
Obviously, word of caution: You have to make sure car is in neutral and I'm a truck driver so it's second nature to me. So it's definitely not viable option for everybody but just thought to share the info.
2003 BMW M5 Blue Water Metallic
VDO oil pressure gauge * ZHP weighed shifter * Euro leather armrest * Spal electric fan * Bilstein B6 (stock springs retained) struts and shocks * Supersprint headers, HJS cats, X pipe, Vibrant Performance resonators, Supersprint Magnum mufflers and all new SS T304 Vibrant Performance mandrel bend tubing.
2003 BMW X5 4.6is Saphire Black Metallic
1997 BMW 528iA Alpine White
BWM is offline
The Following 2 Users Say Thank You to BWM For This Useful Post:
gsfent (13th May 2018), josiahg52 (13th May 2018)
post #2 of 5 Old 13th May 2018, 07:50 PM
mgdmb
mgdmb's Avatar
Also handy when you're at the track and your clutch switch takes a dump on you and the car won't start...
mgdmb is offline
post #3 of 5 Old 16th May 2018, 12:34 AM
SidekickChuck
SidekickChuck's Avatar
Yeah I did this years ago and still have the clutch bypass enabled. I never park in gear so its not an issue for me, but there was ONE time when I had new tires being put on. After the install, they parked the car in their lot and when I went to start it up, I didnt check the gear selector (since I always park in neutral and typically dont check myself) and the car lunged. I was already pretty close to a brick wall, but luckily I managed to stomp the brakes in time to stop the car from slamming into it.
Lesson learned for me to check every time, which I do now. I had the same issue with the clutch stop. It would not start the car with the clutch stop installed. Oddly enough, if I lifted myself up so my weight wasnt on the seat, it would start right up. I dont know if there is some dependency on an occupancy sensor or something, but it would always fire right up if I did this. But in the end, it was easier to enable the clutch bypass.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
South Bend Stage II Endurance Racing Clutch
CNS Lightened Flywheel
KW Variant 3 Coilover Suspension
RDSport 19" RD2
AC Schnitzer Type II Racing 19x9.5F 19x10.5R
Latest Photos
SidekickChuck is offline
post #4 of 5 Old 20th May 2018, 02:39 PM
terraphantm
I haven't tested this, but if you want to keep the safety aspect while still allowing the shorter travel, try setting K_START_SGANG (0x73a4 in the DME for programs 1601 and 1701) to 1. If I'm reading the code correctly, if that's set to 1, the DME won't start the engine unless either the clutch is depressed or the gear lever is in neutral.
terraphantm is offline
post #5 of 5 Old 23rd May 2018, 12:01 AM
SidekickChuck
Whoa! So there might be a way to disable starting the car if the gearbox is in gear? That would be wonderful!
2001 BMW e39 M5
Powerchip Tune
RDSport 19" RD2
Latest Photos
VERY Long Clutch Pedal Travel voltex E39 M5 and E52 Z8 Discussion 5 27th August 2014 01:45 AM
Promlem with clutch pedal travel Philo E28 M5 Discussion 0 9th August 2013 07:22 AM
Brake pedal travel/feel Hakon E39 M5 and E52 Z8 Discussion 4 30th November 2010 09:21 AM
Clutch pedal travel question VancouverM E39 M5 and E52 Z8 Discussion 18 29th November 2005 12:41 AM
brake pedal travel [email protected] E39 M5 and E52 Z8 Discussion 1 7th June 2000 11:11 AM
