Fire Extinguisher Mount - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 12 Old 23rd April 2018, 03:03 PM Thread Starter
uhad2point
uhad2point's Avatar
One Lap of America requires a fire extinguisher to be mounted in the car. Not to mention, cool points with the scene kids.
I already had a 2.5lb halotron bottle and bracket but couldn't find a good way to mount it. It turns out that euro E39s had a little bottle available as an accessory that mounted to the front of the seat. If you don't mind buying from overseas ebay sellers, you can still find the bracket but the bottles are impossible to find.
Fortunately, forum member Bleedsblue made a bracket that utilizes the existing holes in the seat frame and provides for mounting of the standard bracket that comes with pretty much all 2.5lb bottles.
He actually designed it for the E34 (the thread in the E34 board is here: https://www.m5board.com/vbulletin/e34...e+extinguisher) and sort of discovered it fits the E39 by accident.
I ordered through his website and was able to install it on the passenger side in about 20 minutes. I opted for the nuts/bolts version and not the rivets. It's hard to get a wrench on the nuts but doable. On the E39, the mounting bolts are a bit too long but I informed Bleedsblue so I'd expect any future E39 orders will come with slightly shorter bolts. Only downsides of the passenger side mounting (apparently Bleedsblue didn't experience this mounting on the driver side of his test E39) was that the bottle only fits in one orientation, which is nozzle outboard, with the bracket bolted down to the inboard set of mounting holes. Otherwise the nozzle or handle hits the seat or seat shroud.
We did some autocross runs after the install and the bottle didn't make any noise at all, which is great. Additionally, it's within easy reach of the driver and yet is visually unobtrusive.
Definitely give Bleedsblue aka Angry *** Solutions the thumbs up on this one and recommend it if you want to mount a bottle (let's be honest...with the age our cars are, everyone should have one). I also recommend springing for the halotron so you can avoid the dry chemical corrosive aftermath. I already had the 2.5lb bottle and it does indeed fit but the smaller bottle (1lb I think it is?) would probably be a really clean fit. But hey I've got 2.5lbs if I need it!
uhad2point is offline
The Following User Says Thank You to uhad2point For This Useful Post:
Ibmotoren (26th April 2018)
post #2 of 12 Old 23rd April 2018, 03:06 PM Thread Starter
uhad2point
uhad2point's Avatar
Pic of the bottle mounted. Note the orientation; it’s the only way the 2.5lb bottle fits
josiahg52 (23rd April 2018)
post #3 of 12 Old 26th April 2018, 01:35 AM
Sanowk
Sanowk is offline
post #4 of 12 Old 26th April 2018, 01:38 AM
Sanowk
Sanowk is offline
post #5 of 12 Old 26th April 2018, 02:12 PM Thread Starter
uhad2point
uhad2point's Avatar
post #6 of 12 Old 30th April 2018, 05:48 AM
Silent
Silent's Avatar
I was able to mount mine with the outlet facing the driver.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #7 of 12 Old 30th April 2018, 07:53 AM
Sailor24
Sailor24's Avatar
It appears you are missing an important safety feature on your extinguisher. There must be a safety tie to resist the pin being pulled out. It is usually a bumpy, specifically designed zip tie. There is also an inspection label that goes with it. I only mention because if you are required to have an extinguisher as you said, you don't have one without those two things. If they inspect your extinguisher then the inspector will tell you you don't have an extinguisher. You might want to check if you will be inspected or have it corrected so to don't have a huge hassle the day you leave.
Sailor24 is offline
post #8 of 12 Old 30th April 2018, 03:00 PM Thread Starter
uhad2point
uhad2point's Avatar
Good catch on the tag; I routinely check over the bottle myself so I have sort of forgotten about it. I’ll get it reinspected.
Share a pic of how your bottle mounted if you can. I’m sure variances in the bottles will allow different orientations or maybe we were just having a moment.
post #9 of 12 Old 8th May 2018, 06:15 AM
ObjectEdit
Perfect! Thanks...
I have a safecraft extinguisher I wanted to mount... (halon 1211, with billet nozzle)
https://store.windingroad.com/safecr...SABEgITSPD_BwE
And a oem BMW unit as well, deciding which to install...
Btw, if u feel under the M5 seat there are threaded holes already there. I used them to mount a oem first aid kit on the passenger side.
I wonder if the Angry brackets can utilize them(?)
ObjectEdit is offline
post #10 of 12 Old 30th August 2018, 02:55 PM Thread Starter
uhad2point
uhad2point's Avatar
Originally Posted by ObjectEdit View Post
Perfect! Thanks...
Someone was asking about this so I'm bumping the thread a bit. The AAS one was actually designed for the E34 and it was only by complete accident that they realized it lined up for the e39 also. I bet it could be made to use the threaded holes for an easier install, but honestly the through-bolt with the high-grade fasteners from the kit is more secure anyways.
Fire Extinguisher Mount to Front Seats (Factory) Tortuga E60 M5 and E61 M5 Touring Discussion 0 23rd September 2014 10:57 PM
Fire extinguisher gregh86 E39 M5 and E52 Z8 Discussion 53 30th May 2012 03:50 AM
E39 Want to buy: Fire Extinguisher agreenrhino Parts / Other For Sale or Wanted 1 7th November 2009 09:27 PM
Trunk-mount Halon fire extinguisher idea ELEVENS E39 M5 and E52 Z8 Discussion 41 6th March 2003 04:34 PM
M5 Fire Extinguisher Mount - Help! robert47 E39 M5 and E52 Z8 Discussion 2 9th June 2001 05:46 PM
