DIY: Xtrons PB7639BP Android Head Unit Installation - BMW M5 Forum and M6 Forums
 64Likes
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
post #1 of 346 Old 11th February 2018, 07:31 PM Thread Starter
Rontgen
Rontgen's Avatar
So, it’s 2018 and it’s time for an audio/tech upgrade in your E39 M5? Let’s look at our options:
- Bluetooth add-on device (Mediabridge, Grom Audio, etc): These are a great way to add Bluetooth streaming (A2DP) and handsfree calling to your E39. They are relatively cheap & easy to install, do a decent job at providing the basics, and allow you to retain your stock OBC functionality. However, they do require deletion of your CD changer (do people still use CDs?) and typically have some iffy functionality constraints due to the way they connect to the car. This also requires that all of your stock audio hardware is functional
- Intravee II + Alpine iPod module: This device was way ahead of its time and was at one point the gold standard for adding functionality to the BMW audio & iBus systems. Unfortunately, lack of updates have made this option somewhat obsolete and relatively expensive for what little functionality it provides.
- Dynavin N6/N7: Dynavin led the way with plug-and-play DSP integration in 2014. Unfortunately, they’ve done very little innovation since. I could go on and on, but I’ll leave it at this – I owned a N6 for a long time and I’m not a fan, given the price point – particularly considering the $300 Apple Carplay add-on module, which makes the Dynavin a $1000+ investment
- BMW NBT Retrofit: This is as good as it gets. It’s quite literally installing the entire audio/tech package from a new BMW into your E39. As you’d expect, it’s luxury-car nice and very refined. Unfortunately, it’ll run you $2000-$2500, requires some custom parts be fabricated for install, and is not something you can expect your local audio shop to install for you.
None of these seem right for you? What if you could retain the OBC, retain your DSP, and add features to your car via the iBus – with one device?
That leaves us one more choice: Generically-speaking, the “Chinese-built Android Head Unit”
Yeah, yeah, I know how that sounds. I know what you’re thinking, because I thought the same thing. Then I did a little research.
It turns out that the majority of these Android head units use the same hardware behind the fascia. Whether you have a BMW or a VW, it’s most likely a MTCD-manufactured board under the skin and that means they have made LOTS of these for the global market. The E39 is just a small sliver of the overall market for these parts and quality control appears to be relatively good. It also means there’s tons of support out there, even if it’s not necessarily BMW-specific (see xda-develeopers).
There’s also no shortage of brands out there to choose from, and chances are you won’t recognize a single one of the names in this market. Take a look on aliexpress and search for “E39 Android” and prepare to be overwhelmed. But, if they’re all essentially manufactured from the same base parts, does it matter which brand you buy? I believe it boils down to the support from the manufacturer and moreso the enthusiast community.
In my research, one brand kept floating to the top – Xtrons. I had seen a couple positive threads about Xtrons on M3forum, but aside from that I had never heard of them. It turns out they are very successful with the European BMW community due to the quality of the product, their support, and the fact that they have a UK-based warehouse (which I believe avoids customs fees when importing to the EU).
I decided to take the plunge and order a Xtrons PB7639BP head unit, running Android 6.0. At $289 shipped direct from Xtrons (via Amazon), it seemed like a manageable gamble. With some required and optional add-ons, I’m sitting around $485 total investment
https://www.amazon.com/XTRONS-Octa-C.../dp/B01N7UW51Q
*note – Xtrons has very recently replaced the model above with the PB7839BP, which has more RAM and runs Android 8.0. I haven't used on myself (yet), but they should be very similar and the majority of this information should still apply
https://www.amazon.com/XTRONS-Androi...words=PB7839BP
Xtrons also does manufacture a 9” screen model (with no physical buttons) which is essentially the same internally as the model above. Be aware that the 9" is currently only produced as E53 fitment, so the curve of the unit does not match the E39 dash very well.
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is offline
The Following 6 Users Say Thank You to Rontgen For This Useful Post:
ger (12th February 2018), Hdhntr23 (8th March 2018), KevinM (25th February 2018), Mike S. (13th March 2018), ryanman (3rd November 2018)
post #2 of 346 Old 11th February 2018, 07:39 PM Thread Starter
Rontgen
Rontgen's Avatar
iBus Interface:
The iBus is the BMW-proprietary communication network used for the majority of systems within your car. Things like the cluster, Light Check Module, Radio, DSP Amp, and several others are all interconnected via the iBus.
For years, anyone could install an Android head unit in their E39. The trouble was that you had to sacrifice your car’s OBC data and your DSP amp, which made the head unit much less appealing. Now things have changed thanks to the Resler interface and the iBus Android app.
Resler Interface: IBUS Interface for BMW cars
iBus App: BMW IBUS App
The Resler interface is a piece of hardware that allows your Android head unit to communicate on the iBus network. The app gives you the ability to monitor/reset your OBC data, add functionality to the car, and control the DSP amplifier. The iBus app website does a far better job listing the functionality than I can here, so please read it for the current feature list. The app is updated frequently and the app developer is a German E39 enthusiast, so most of these features have been tested on our platform prior to release.
Wiring:
Connecting the Resler interface to your car is fairly easy as it’s just 3 wires: 12V power, Ground, & iBus data line. You can connect anywhere on the bus, but for us the easiest place is using the 16:9 OBM connections in the dash. Most install guides have you cut wires -or- splice into the car’s existing wiring. I personally hated both of those approaches and figured there has to be a better way.
Luckily there is an easy way to accomplish this. The OBM connections use the same pins as the standard BMW 3-pin connector, so with about $6 in parts from BMW, you can add a connector to your existing harness. This is completely reversible, requires no cutting or soldering of your factory wiring, and is easy to do.
Parts List:
1 x BMW 61138377072 - 3 pin connector for chassis side
1 x BMW 61136931929 - 3 pin connector for interface side
3 x BMW 61130005198 - 3 pins with wire for interface side
Steps:
- Disconnect your battery.
- Disassemble the blue connector from the OBM harness with a small screwdriver. The blue hood will slide off and allow access to the pins.
- Using a very small screwdriver, depress the pin’s retaining clip and pull the following pins:
2 – brown - ground
6 – red/green – 12V
7 – white/grey/yellow – iBus Data
- Slide these pins into the BMW connector and snap the locking clip down to secure it.
Now you have a factory-quality connector to interface to your iBus network. Assemble the other side by soldering the 3 black wires to the Resler interface, following the instructions on the Resler website. Don’t screw up the wiring color code!
- Darrell
Rontgen is offline
The Following 3 Users Say Thank You to Rontgen For This Useful Post:
Hdhntr23 (8th March 2018), Mike S. (13th March 2018), Terabass (4th March 2018)
post #3 of 346 Old 11th February 2018, 07:44 PM Thread Starter
Rontgen
Rontgen's Avatar
Parts List:
XTRONS PB7639BP - $289.99
XTRONS EXL005 - 6m Extension Cable - $49.99 – Required if you have factory Navigation
XTRONS OBD02 - Bluetooth OBD2 adapter - $12.99
XTRONS DVR015 - DVR Camera - $29.99
6m FAKRA Radio Antenna Extension - $20.35 shipped from Germany LINK: https://www.ebay.com/itm/Antennen-Ve...L10DTnhjisdZRg
6m FAKRA GPS Antenna Extension - $12 shipped from China LINK: https://www.ebay.com/itm/Fakra-SMB-C...53.m1438.l2649 Send this guy a message and tell him you need a 6 meter cable and he’ll custom make one for you.
Resler Interface - $38 shipped from Germany LINK: IBUS Interface for BMW cars
iBus application license - $31 online LINK: BMW IBUS App
BMW iBus connector parts - $6
DISCLAIMER This is a relatively complex installation, so be sure you have researched appropriately before you start and be realistic about your own DIY capabilities. If the idea of taking your car’s interior apart scares you, this entire project isn’t for you. If you blow your car up and/or burn down your house, it’s not my fault. Should anything else bad happen – also not my fault.
If the idea of planning every detail, ordering parts from all over the world, and putting it all together doesn’t sound like a fun challenge – this is probably not a project for you. I’ll admit that it takes a special kind of moron to find this appealing. 
INSTALLATION:
I’m going to cover the high points of the installation only, this is not meant to be a step-by-step how-to, but should hopefully give you some pointers and help you avoid any major pitfalls. You should plan on a long day to get this done, maybe even a weekend if you’re planning a big install.
Basic Steps:
- You must Recode your DSP amp using NCS Expert. Change the BEDIENELEMENTE parameter from “bordmonitor” to “mid_basis”
- Run 6m radio extension harness, radio antenna extension, & GPS antenna extension from the trunk to the dash area
- Keep in mind that the 90-degree ends of the antenna extensions plug into the head unit
- Remove the 16:9 OBM. The CD changer, Radio, & Nav unit can optionally be removed (or at the very least least unplugged)
- Remove the factory 16:9 navigation bracket, which requires dropping the lower dash & glovebox down several inches.
- Run the extension cables while you have the dash lowered
- Run any optional cables (DVR, Microphone, Backup Camera, USB cables, etc) to their correct locations
- Tap into the iBus network and attach the Resler USB interface to one of the USB inputs on the Xtrons
- Install the Xtrons mounting brackets (see below)
- Darrell
Rontgen is offline
post #4 of 346 Old 11th February 2018, 07:48 PM Thread Starter
Rontgen
Rontgen's Avatar
MOUNTING
The Mounting solution for this unit is terrible. Really, really terrible. In fact, it's the only real complaint I have with this system and i guess given the price, I should probably just shut up and deal with it. But as a warning - the brackets that are included with teh Xtrons are awful. They are flimsy and the holes are nowhere close to where they belong for an E39.
Thanks to the German-language Xtrons wiki and Facebook group, there is something that resembles a solution. With these modifications performed, it fits better, but I wouldn't call it great by any stretch of the imagination. It's not going to fall out, but be forewarned that this is a part of the "finished" product that I'm not real happy with. Friends of mine think I'm kind of crazy for obsessing over it, but what can I say? Might be a touch of OCD, as I'm sure a lot of us can relate to lol
Xtrons wiki (use Google Chrome and it will translate for you): BMW Xtrons Wiki
Facebook Group: https://www.facebook.com/groups/1954844871468973/
- Darrell
Rontgen is offline
The Following 4 Users Say Thank You to Rontgen For This Useful Post:
Hdhntr23 (8th March 2018), Mike S. (13th March 2018), whitewolf8181 (13th June 2018)
post #5 of 346 Old 11th February 2018, 07:53 PM
cncmastr
cncmastr's Avatar
Thanks for doing this! How do you like the unit?
E30 318is
E46 M3
E53 4.8is
F31 328xi sports wagon
E39 M5 S2
http://obsessedmotorsport.com/blog/
cncmastr is online now
post #6 of 346 Old 11th February 2018, 08:10 PM Thread Starter
Rontgen
Rontgen's Avatar
So far I like it a lot! Much, much more than the Dynavin N6 it replaced. With that said, I'll admit I'm still in the honeymoon phase and I try to be as honest and transparent about that when recommending other people spend their hard-earned $ on things. At the moment, I have a couple "issues" I need to work through
- The Xtrons bluetooth microphone was waaaay too short, so I'm using the internal mic at the moment. Eventually I want to get a OE BMW mic and wire it in
- Not really an Xtrons issue, but I have a wifi hotspot in the car, connected to switched 12V. The Xtrons boots almost instantly, yet the hotspot takes forever to boot & connect to 4G/Wifi, so I need to come up with a better solution. Tethering to my iPhone may end up being that solution, actually.
- The iBus app will occasionally need to be restarted after starting the car. It's quick and easy to do, and I know the app developer is working on it, so for now not a major issue
- For some reason Spotify will occasionally stutter and skip as I'm driving. I tend to think it's a data connection issue with AT&T, but I need to troubleshoot a little more. Also, with 32GB of onboard storage + SD Card, there's no reason I couldn't just download several Spotify playlists onto the unit, which would probably resolve this for good
- Like a moron, I mounted the front-facing DVR camera without ensuring it's straight, so now it's crooked. lol
- Darrell
Rontgen is offline
post #7 of 346 Old 11th February 2018, 11:22 PM
E55AMG2
E55AMG2's Avatar
E55AMG2 is offline
post #8 of 346 Old 12th February 2018, 12:02 AM
autonaut
autonaut's Avatar
Good writeup..
What if you dont have factory navi but the business radio? Will i still gain obc functions installing the xtron unit?
Autonaut
autonaut is offline
post #9 of 346 Old 12th February 2018, 03:34 AM
ger
ger's Avatar
Loving this, it's looking likely that I'll be doing this in the near future
Thanks for sharing.
ger is offline
post #10 of 346 Old 12th February 2018, 04:28 AM Thread Starter
Rontgen
Rontgen's Avatar
Originally Posted by autonaut View Post
Good writeup..
I believe what you’ll see depends if you have the “low” or “high” OBC? Aside from some
And actually the business radio makes the install a little bit easier since you don’t have to run the extension harness
- Darrell
Rontgen is offline
DIY: Avin Android Head Unit Install (plus new amp) Ikazuchi E39 M5 and E52 Z8 Discussion 58 25th January 2018 10:16 PM
Xtrons PB7639BAP Android Initial Thoughts, Comparison to Dynavin N6 jbla E39 M5 and E52 Z8 Discussion 14 17th November 2017 04:50 PM
Parrot Smart - Shallow Depth Double DIN Android head unit! DennisCooper E39 M5 and E52 Z8 Discussion 68 6th April 2016 01:11 AM
E39 For Sale: Full Nav set up: BM53 radio, MKIII unit, 16x9 E46 Nav head unit SASM5 Parts / Other For Sale or Wanted 14 23rd January 2014 01:55 AM
Cd head unit broster E39 M5 and E52 Z8 Discussion 3 29th December 2012 01:28 AM
