DIY: Xtrons PB7639BP Android Head Unit Installation - Page 5 - BMW M5 Forum and M6 Forums
 64Likes
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
post #41 of 346 Old 28th February 2018, 04:48 PM
xrviz
xrviz's Avatar
Originally Posted by Rontgen View Post
Hi Dennis,
I'll admit, I have a limited understanding of Time Alignment. My understanding was it was a way of adjusting the sound timing so that all sounds arrive at a specific location within the car at the same time(I assume the driver's head would be the most common). My only experience with it was with my Dynavin N6 and it didn't even work with the DSP amp (at least in the early N6 days). If there's more to it, please feel free to add.
The screen shots below are from my Xtrons unit. The screen looks very similar to the TA screen on my N6 and the TA does appear to work, with one exception. If I choose anything in the rear seat, audio goes totally silent. I'm not sure if this is a result of something with the Xtrons, the DSP amp, and/or the fact that I have M-Audio, so I don't have any speakers in my rear doors.
*Edit*. Had some time to do some reading tonight about TA and Iím changing my tune, I agree with Dennis that this does not appear to have time alignment capability. The screen does look very similar to the Dynavin at first glance, but after comparing it does not have the individual time delay settings.
FWIW, with the Fader adjusted to the "Front" preset, it sounds very good. Much better than with it centered, actually.
Here's the screen from my N6. Right side cursors adjust individual speaker volumes which is what I believe the Xtron is doing. Left side cursors adjust time delay.
xrviz is offline
post #42 of 346 Old 28th February 2018, 04:59 PM Thread Starter
Rontgen
Rontgen's Avatar
Yep, that looks familiar now. I guess that's what I get for relying on my memory!
More importantly, we need to drink some beer!
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is offline
post #43 of 346 Old 28th February 2018, 06:02 PM
xrviz
xrviz's Avatar
xrviz is offline
post #44 of 346 Old 4th March 2018, 02:46 AM
Terabass
Terabass's Avatar
Originally Posted by DennisCooper View Post
Hi,
Depending on which recognized car audio brands you use for the amplifier(s) and components speakers/co-axials/sunwoofers, then assuming you go 'middle level' on those, then they'll similarly not perform to what they're capable of when using a cheap quality chinese head unit, so my point is, you'll 'most likely' be disappointed in the short/medium and longer term!
Would it be possible to get a digital signal from the Chinese units to an upgraded aftermarket amp/system so there would be no quality loss in the signal?
I want to use the Chinese unit because of Android and original fitment, but I see the need to upgrade the entire sound system.
Ideas range from Bluetooth audio out from Chinese unit to aftermarket high-end Amp, to WiFi to digital signal chord.
Is there any Amplifier or module that connects to any high end amp that has an App to control audio dynamics, so they can be completely skipped on Chinese unit's end and we get full sound quality exceeding DSP or Android aftermarket, while keeping Android functionality and OBC/iBus control through iBus app.
What are your thoughts on this?
Terabass is offline
post #45 of 346 Old 4th March 2018, 03:27 PM
DennisCooper
DennisCooper's Avatar
Hi TB,
The internal electronics are more generic in their capabilities as well as quality. This means aspects like optical out or a digital output won't be possible at the stage prior to any audio processing/digital to analogue conversion. What you are asking for is higher end functionality that the 'generic' IC's used in these chinese units aren't used because of course they cost alot more. Even if they did use a better digital stage like that, then they'd also have to use much better quality DAC's and Audio stages IC's throughout the rest of the electronics in order to get the best from them.
If you have any level of 'good audio' and 'high quality performance with no loss of quality' then the chinese units aren't going to provide this. Car audio which does have what you want in terms of fantastic sound quality and aspects such as optical outputs/connections for a pure(r) signal path does exist but it's not found on low grade chinese units but on high quality brands products and solutions. I'll answer on your other thread as well !
Cheers, Dennis!
2003 Ex-Police E39 530 Diesel Touring. Alpine White, 260,000+ Miles & climbing!
Wheels;
19" Hartge Nova 5 - with custom painted 'Flash Chrome' centres & Polished Lips (set of 5)
19" Hartge Nova 5 - Awaiting custom re-finish (set of 4)
19" Hartge Classic - with custom powder coated centres in shadow chrome & diamond cut/no lacquer lips (set of 5)
20" Hartge Classic - Awaiting custom re-finish
19" 3Pc Forged wheels - ID retained until re-built & finished (2 sets)
20" 3Pc Forged wheels -ID retained until re-built & finished
19" Centres - ID retained until rebuilt & finished
Audio;
Full Custom Audio install - Arc Audio KS Mini ampliifers. DLS 5.25" 2 way front components & 4" 2 way co-axials. JL Audio 8W3-V3 subwoofer in stealth enclosure. Parrot Asteroid Smart head unit, custom door builds for DLS front stage & Earthquake SWS6 flatline subwoofers, custom rear pillar speaker pods. LumiDock iPod dock,
External;
H&R Springs, ExoticsTuning front lip spoiler, Sport F/R bumpers upgrade, Carbon Fibre effect printed Vinyl roof wrap, High gloss black vinyl window trim wrap, Hartge bonnet/hood & tailgate badges, rear rooftip spoiler, matt Black kidney grille, projector foglamps.
Internal;
Hartge auto gearlever, Hartge Handbrake handle, Hartge door sill strips, E46 M3 CSL Alcantara/Tri-stitch SMG steering wheel, full Black Leather Sport seats,
Engine;
Custom ECU re-map biased for more Power & Torque in Steptronic mode, EGR delete, K&N induction kit, Stainless steel de-cat, Stainless steel exhaust backbox with twin oval pipes. Manual 5 spd gearbox conversion.
Plenty more modifications to come!
DennisCooper is offline
post #46 of 346 Old 6th March 2018, 11:49 PM
effduration
FM Radio reception on this Xtrons Install?
Hi can i please ask OP how he handled the FM Antennas? It is my understanding that the e39 has two radio antenna feeds. Did you somehow connect them both to the Xtrons unit? Was an extra cable or adapter needed for the extra antenna?
How is reception? Thanks
effduration is offline
post #47 of 346 Old 7th March 2018, 02:57 AM Thread Starter
Rontgen
Rontgen's Avatar
Thereís only one antenna connection at the stock radio, so thatís the only one connected here. Mine is an earlier car (12/00 build) so it supposedly has a powered antenna that needs another adapter. However, it seems to work as-is for the one local FM station I listen to once in a while. I seem to recall AM reception with my Dynavin was very iffy, but I never listen to AM, so I never pursued it.
- Darrell
Rontgen is offline
post #48 of 346 Old 8th March 2018, 05:03 AM
Hdhntr23
Hdhntr23's Avatar
Thanks for posting, great write up and follow thru.
How do you load songs into the 32GB HDD? Also, where is the SD card slot?
Thanks!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is online now
post #49 of 346 Old 8th March 2018, 02:32 PM Thread Starter
Rontgen
Rontgen's Avatar
Thanks!
Thanks!
There are 2 Micro SD Card slots on the front of the unit. You can load to the 32GB a couple different ways: download to it (via WiFi), or attach an external storage device (Micro SD or USB) to the unit and use the File Browser app to move files onto the onboard storage
- Darrell
Rontgen is offline
post #50 of 346 Old 8th March 2018, 02:33 PM Thread Starter
Rontgen
Rontgen's Avatar
Also, to update my earlier posts (since we canít edit here), thanks to a fellow member for the heads-up about the 6m GPS cable. This is now available without a special request to the seller:
The topic mentions a GPS extension cable that can be used to make use of the existing GPS antenna in the car. I've messaged the seller to get a 6m long version of the cable, as suggested in the topic, and he has now created a separate product for that on ebay. It can be ordered here: https://m.ebay.com/itm/Fakra-SMB-C-5...72?_mwBanner=1
- Darrell
Rontgen is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
DIY: Avin Android Head Unit Install (plus new amp) Ikazuchi E39 M5 and E52 Z8 Discussion 58 25th January 2018 10:16 PM
Xtrons PB7639BAP Android Initial Thoughts, Comparison to Dynavin N6 jbla E39 M5 and E52 Z8 Discussion 14 17th November 2017 04:50 PM
Parrot Smart - Shallow Depth Double DIN Android head unit! DennisCooper E39 M5 and E52 Z8 Discussion 68 6th April 2016 01:11 AM
E39 For Sale: Full Nav set up: BM53 radio, MKIII unit, 16x9 E46 Nav head unit SASM5 Parts / Other For Sale or Wanted 14 23rd January 2014 01:55 AM
Cd head unit broster E39 M5 and E52 Z8 Discussion 3 29th December 2012 01:28 AM
