DIY: Xtrons PB7639BP Android Head Unit Installation - Page 2 - BMW M5 Forum and M6 Forums
 65Likes
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
post #11 of 346 Old 12th February 2018, 05:04 AM
Dking078
Dking078's Avatar
Excellent write up! I was wondering why you sold the N6
2003 BMW 540i [Sterling Gray / O5SW M5 Black Interior]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one true authority of E39 Trim. --E39 Trim Information Thread [Click]
For Sale:
2004 BMW X5 4.8is [Black/Black] [Click]
E39 OEM Refreshed Xenons with new DJ Auto euro lenses! [Click]
E60 Windshield washer sprayer nozzles "Fan" style [Click]
E39 HVAC Buttons [Click]
Got Broken E39 Rear Quarter sun shades? [Click]
Random stuff I don't list on the board: https://www.ebay.com/usr/dking056
Dking078 is online now
post #12 of 346 Old 12th February 2018, 02:21 PM
flumoxed
flumoxed is offline
post #13 of 346 Old 12th February 2018, 03:28 PM Thread Starter
Rontgen
Rontgen's Avatar
So far, very good. No noticeable delay with the exception of a couple seconds for Waze to boot up.
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is offline
post #14 of 346 Old 12th February 2018, 04:46 PM
boris1
Quick question, why do you need 6m FAKRA GPS Antenna Extension? I thought that these Nav units come with their own GPS antennas that you just mount under the dash somewhere.
boris1 is offline
post #15 of 346 Old 12th February 2018, 07:04 PM Thread Starter
Rontgen
Rontgen's Avatar
They do, but I found with my Dynavin that the reception with the included antenna was poor until I added the extension to use the factory GPS antenna instead. Maybe it was just an issue with the Dynavin and it's not a concern with the Xtrons, but I didn't want to chance dealing with it again. Also, it's one fewer item to try and stuff into the dash...
- Darrell
Rontgen is offline
The Following 2 Users Say Thank You to Rontgen For This Useful Post:
ger (13th February 2018)
post #16 of 346 Old 13th February 2018, 02:53 PM
stickey
stickey's Avatar
Thanks for the thread! Starting to accumulate parts. Looks like the Android 6.0 is out of stock on Amazon and xtrons.
Looks like Amazon is the place to get the head unit, and xtrons is the place to get the cable. The cable, on amazon, is $79. (EXL005)
Anyone have a DIY / step guide on how to get a new set of speaker wires into the door? Is the rubber "snorkel" wire flex tube. This forum is great for lots of stuff - but a bit weaker as compared to stereo related stuff (IMHO).
2000 E39 M5 Dinan S2, Estoril Blue
stickey is offline
post #17 of 346 Old 13th February 2018, 03:21 PM
ger
ger's Avatar
I'm thinking of going for a 7839.
A few initial questions:
There's no mention of ipod control. I have a rather old 'classic' which has the old, large connector. Could this be connected to one of the usb ports and be controlled from the headunit?
Does the headunit have wifi capabilities or would I need to get the 3g/4g(maybe wifi) dongle? I wouldn't often need internet acces, I was thinking of letting it connect to my phone and use it's 4g connection when needed (updates etc).
My car currently has the mfd and a cd drive(no nav), which means it has the single slot frame 'carrier'.
Will this need to be removed and a full nav unit carrier be installed or does it not use any of the original carriers?
Is it just a plug and play unit? I don't have the logic amp, but I do have an amp in the boot for subs, currently switched on by the diversity antenna 'live' (a white wire in the loom iirc, it works!). Would I need to re wire both of these or are they (ie diversity) fed through the 'big' radio connector (flat pin in my case), that's behind the dash in my case (ie not in the boot since I didn't have nav).
Thanks for any replies and help. I realise some of these should be aimed at the seller but it's nice to be fore-armed
ger is offline
post #18 of 346 Old 13th February 2018, 04:13 PM Thread Starter
Rontgen
Rontgen's Avatar
I'm glad you brought the ipod control up as I forgot to mention it. At the moment, when I plug my iPhone in it does charge, but I don't have any way to control the phone's music from the head unit. With that said, I've literally spent about 2 minutes playing with that function, so I'm nowhere close to admitting defeat. I'll eventually do the CarPlay dongle, which will give all the functionality of Apple CarPlay on the Android unit, to include ipod/music/spotify control. I'm guessing there's an Android app available to interface to the older Ipod, but I don't have a specific recommendation
The head unit does Wifi (and does it well), and I believe that's the only way to connect. Even the 3g/4g dongle Xtrons sells simply broadcasts a wifi signal and uses USB for power only. I'm currently using an AT&T wifi hotspot in my glove box, but I would think you could do without cell connectivity fairly easy. Download an offline maps app (there are several available), download your music to the unit, and allow it to connect to your home wifi when it's parked at home.
The full carrier would need to be removed, regardless of which carrier you've started with (nav vs non-nav). The unit includes it's own brackets, which are terrible. I just saw a post this morning on the German FB group that someone is looking at creating 3D-printed brackets which supposedly fit better. We shall see...
For you, I believe it should be a fairly simply install. You won't need any of the extensions listed above, possibly an antenna adapter, and you will need to use the included GPS antenna. As far as the amp question, I'm honestly not sure.
- Darrell
Rontgen is offline
The Following User Says Thank You to Rontgen For This Useful Post:
post #19 of 346 Old 13th February 2018, 05:09 PM
xrviz
xrviz's Avatar
Great writeup as usual! Looks much better than the N6, especially the IBUS info. Yet another project to add the growing list.
xrviz is online now
post #20 of 346 Old 13th February 2018, 08:23 PM
ger
ger's Avatar
Big thanks for the reply.
I wonder if ipod control is over one of the usb connectors only?
Re carrier, the lower dash would need to be 'moved', this isn't much of a job anyway.
How is the unit secured? Are the supplied mounting plates screwed to the side of the unit, like little ears and then these screwed onto the dash, behind the lower dash trim?
Also, I read somewhere that the newer android 8 units have a small usb issue, would this affect the 7839 you think?
Re Ibus app and intravee- the app seems very good. I currently have an intravee (iv) setup, from what I can see most of the 'iv's' functionality is duplicated in the app and some extra features built in. Could an iv remain attached or would it be more sensible to remove it?
Also, are there any features of the bc (or mfd) that the app does not support? I have not noticed the 'code' feature but I can't look properly at it, I do use code sometimes, gives a small degree of peace of mind!
ger is offline
DIY: Avin Android Head Unit Install (plus new amp) Ikazuchi E39 M5 and E52 Z8 Discussion 58 25th January 2018 10:16 PM
Xtrons PB7639BAP Android Initial Thoughts, Comparison to Dynavin N6 jbla E39 M5 and E52 Z8 Discussion 14 17th November 2017 04:50 PM
Parrot Smart - Shallow Depth Double DIN Android head unit! DennisCooper E39 M5 and E52 Z8 Discussion 68 6th April 2016 01:11 AM
E39 For Sale: Full Nav set up: BM53 radio, MKIII unit, 16x9 E46 Nav head unit SASM5 Parts / Other For Sale or Wanted 14 23rd January 2014 01:55 AM
Cd head unit broster E39 M5 and E52 Z8 Discussion 3 29th December 2012 01:28 AM
