E39 M5 Secondary Air System Failure Destroying Cat Converter? - Page 3 - BMW M5 Forum and M6 Forums
 11Likes
post #21 of 30 Old 24th October 2018, 11:47 PM
gsfent
gsfent's Avatar
Originally Posted by fernandocrew View Post
Thank you for directing me to get a code reader. Is this something I get through BMW or elsewhere? Can you direct me where to get said item? I really appreciate the response.
If the pricing is competitive, consider using some of the advertiser's who support the site.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #22 of 30 Old 25th October 2018, 06:06 PM
autonaut
autonaut's Avatar
Why a peake reader? A much better alternative is inpa which is actually usefull for other stuff than reading codes.
Inpa is very easy to buy and get running on any laptop. And can do live data too
Autonaut
autonaut is offline
The Following User Says Thank You to autonaut For This Useful Post:
Tomba (5th November 2018)
post #23 of 30 Old 26th October 2018, 01:25 AM
Sailor24
Sailor24's Avatar
How true but... since the poster did not know he needed a code reader, don't you think that INPA might be a very large first step? I was just going to tell him to get a generic OBDII reader but I left my fire suit at the cleaners.
Sailor24 is offline
post #24 of 30 Old 30th October 2018, 03:19 PM
fernandocrew
As it turned out I did get the OBDII and will start out by using this to help identify problems. I surely appreciate all the responses that came to my questions. That's the spirit of the forum! The reality is this marvelous car whose speed and power we enjoy so much is also a complicated piece of engineering and can be expensive even when we do know what we are doing so avoiding any unnecessary expenses through the sharing of knowledge and experience is a prime good. Thank you fellows for everything.
fernandocrew is offline
post #25 of 30 Old 2nd November 2018, 06:37 AM
clicketyClack
clicketyClack's Avatar
Originally Posted by gmettus View Post
Since you state you live in a part of Wisconsin that doesn't require emissions testing, do yourself a huge favor; take this opportunity to get rid of the cats, mufflers and MAFS. This advice is contingent on the availability of a shop that can do this kind of work for you. If you live reasonably close to Naperville, Illinois I can strongly recommend one, https://www.youtube.com/watch?v=quyPRHsNSi8. I bought my 2001 M5 with 95K miles back in 2011 sight unseen off of autotrader.com and expected there would be some issues but since I purchased it specifically for the track I was not too concerned. It definitely did not have the power of other M5s I test drove so I took it to the shop and found the major issue was two bad MAFS and at the cost of $400 each we started talking about options. I already knew I wanted the mufflers removed but a full exhaust (less headers) was proposed. The clincher was they guaranteed they would keep the check engine light off and that it would pass an OBDII emissions test (obviously not a tailpipe test) as I wanted to keep it registered for street use.
The shop fabricated tubing to fill the space the MAFS occupy and hand built a stainless steel exhaust that consists of a series of three resonators per side, two cross pipes (original exhaust only has one at the rear but the addition one upfront improves exhaust scavenging) and larger diameter exhaust tips. Once they had everything hooked up they dyno tuned it. Not only did it increase hp over stock by 50 it also smoothed out both the torque and hp curves. The engine runs through the rpm range much better and also gets better gas mileage. I've never had an issue in the seven years and additional 45K miles I've had it. I no longer live in Illinois and don't have to worry about emissions anymore but I did have the shop take it for testing while I was there as I have a terrible poker face :-D
What kind of gas mileage do you get?
clicketyClack is offline
post #26 of 30 Old 3rd November 2018, 04:29 PM
herrubermensch
Not sure I would delete cats or muffler (just my $.02), but the secondary air system plays no beneficial role whatsoever, so I would delete that. We delete it in every engine we build, blocking off the secondary air ports in the heads and throwing away the pump. The ECU can be recoded to ignore the absence of the pump. Not always an option in jurisdictions that engage in emissions testing.
As for MAFs, they are expensive to replace, and the engine can be run very well with alpha-n (throttle angle) in lieu of the MAF. That said, the engine can be tuned to run very powerfully and smoothly with the MAFs.
--Peter
herrubermensch is online now
post #27 of 30 Old 5th November 2018, 09:51 AM
Tomba
Get INPA & Testo working and start observing and logging parameters instead of guessing which part you throw at it.
To///Mba
Tomba is offline
post #28 of 30 Old 7th November 2018, 01:50 AM
AGM5
AGM5's Avatar
To answer you question, the SAI (Air Pump) running or not will not damage the catalytic converters.
As to what GMETTUS is stating, removal of the catalytic converters is pointless. This is not an early emissions vehicle with a dual bed monolith converter. Removing them, even on a supercharged application, is of no benefit. The exception is a full track build where the weight reduction can be helpful, providing that you are competing at a level where 0.001 seconds are a factor; but I would ask why did you start with a 2000Kg vehicle in the first place.
Also, get you hands on a copy of INPA and DIS and start a proper diagnosis.
///M - The most powerful & expensive letter in the alphabet
1 of 123 ANTHRAZIT METALLIC (397) / WALK NAPPA/SCHWARZ (M1SW)
Tuned by BMW Motorsports 4/2001, Bone Stock at 185,000 Miles. 355.78 WHP / 345.33 WTQ
2 facts you might not know: Ducks cannot fly and they nest in trees.
Updates:
BM53 Radio / Gen-13 ULF / OEM Sirius / MK-IV Navigation / Aux input / Intravee II / KCA-410c / KCA-420i / 5th Gen i-Pod Nano / CHA-S634 / Umnitza VXX Angel Eyes / F10 ///M5 Shift Knob /
Schmiedmann Shadow Chrome Grills / Rear Fog Lights
DIY: Retro-Fit Auxiliary Audio Input Harness /// DIY: E39 - BM53 & (BMW) Sirius Radio Retrofit /// DIY: E39 - Replacement of the Left and Right Firewall Covers
For Sale:
BMW Style 5 17" 2 Piece Wheels And Tires
AGM5 is offline
post #29 of 30 Old 7th November 2018, 02:45 PM
Obioban
Obioban's Avatar
Nothing makes a nice car feel shitty faster than going catless.
Obioban is offline
post #30 of 30 Old 9th November 2018, 01:38 AM
herrubermensch
Originally Posted by AGM5 View Post
T The exception is a full track build where the weight reduction can be helpful, providing that you are competing at a level where 0.001 seconds are a factor; but I would ask why did you start with a 2000Kg vehicle in the first place.
I resemble that remark!
--Peter
Air leak from secondary air system? ///DeafM5 E39 M5 and E52 Z8 Discussion 10 5th March 2015 03:54 PM
E39 For Sale: Secondary Air System Simulator root_foo Parts / Other For Sale or Wanted 6 5th August 2014 07:11 PM
2000 e39 m5 secondary air system. greekspeed E39 M5 and E52 Z8 Discussion 14 19th October 2010 10:39 PM
P0492 Secondary air system. NEED FEEDBACK YamahaR1 E39 M5 and E52 Z8 Discussion 5 28th April 2009 02:40 AM
Secondary Air System - Not CBU everycredit E39 M5 and E52 Z8 Discussion 27 27th February 2008 02:17 PM
