subframe bracket to differential broke! - BMW M5 Forum and M6 Forums
 3Likes
  • 2 Post By dougsic
  • 1 Post By mgdmb
post #1 of 6 Old 6th February 2018, 08:36 PM Thread Starter
Perrodulce
Perrodulce's Avatar
Can anyone else speak to this issue, my bracket that is part of the subframe and mounts to the differential has snapped. Everything has dropped 2" and I heard huge bangs everytime I shifted last night. I don't beat on this car at all, it's a daily driver and I never even slam the clutch. (I know, shame on me). This looks like a very weak part, not sure how this could have been designed this way. It's even perforated from the factory it seems. Anyone else have this happen and what is the fix?? Thanks in advance
Perrodulce is offline
post #2 of 6 Old 6th February 2018, 09:01 PM
mgdmb
mgdmb's Avatar
Yeah, it's kind of a thing...
https://www.dropbox.com/s/ujejhhva0u...ation.pdf?dl=0
Get a Unicorn Egg from M5_Jed. You might be able to save that frame, not sure. Regardless, re-enforce it with the plate linked in the pdf. The plate is actual size if you print out on 8.5x11 paper, and ~2.45 mm thick, beveled on the long edge...
mgdmb is offline
The Following User Says Thank You to mgdmb For This Useful Post:
Perrodulce (7th February 2018)
post #3 of 6 Old 7th February 2018, 01:56 AM
Sailor24
Sailor24's Avatar
Very common do a search and you will find a bunch of different solutions although most are how to prevent it from happening. I am sure they can be incorporated into a repair.
Sailor24 is offline
The Following User Says Thank You to Sailor24 For This Useful Post:
post #4 of 6 Old 8th February 2018, 03:13 AM
dougsic
dougsic's Avatar
Your bracket can be repaired by anyone with a TIG welder. I worked on one a few weeks ago (not finished in the pic).
1988 M5 Black
1993 e30 s50 'vert
2001 M5 S2, Black
2003 M5 S2 w/Dinan cams, Blue
2004 M3 S3-R 'vert
dougsic is offline
The Following User Says Thank You to dougsic For This Useful Post:
Perrodulce (8th February 2018)
post #5 of 6 Old 8th February 2018, 03:28 AM
mgdmb
mgdmb's Avatar
h/t to @dougsic for providing me those Dinan instructions and template. It's been passed along many times over the years...
mgdmb is offline
post #6 of 6 Old 9th February 2018, 02:37 AM
herrubermensch
Stacks of dimes!
--Peter
herrubermensch is offline
Rear sway bar bracket broke, but... caspian65 E39 M5 and E52 Z8 Discussion 14 29th October 2013 08:28 PM
I Broke My Rear Subframe and Driveshaft! HadE55NowM5 E39 M5 and E52 Z8 Discussion 87 2nd May 2012 02:13 PM
Differential broke from rear axle carrier! ///Nima E39 M5 and E52 Z8 Discussion 20 5th July 2006 11:34 AM
I broke another Sway bar bracket! BostonRocket E39 M5 and E52 Z8 Discussion 43 28th August 2005 06:06 AM
I Broke My Rear Subframe and Driveshaft! HadE55NowM5 E39 M5 and E52 Z8 Discussion 4 2nd January 2004 10:14 PM
