New member intro DINAN S2 E39 M5 - Page 4 - BMW M5 Forum and M6 Forums
 23Likes
post #31 of 62 Old 11th December 2018, 12:30 AM Thread Starter
cncmastr
cncmastr's Avatar
Originally Posted by h0tr0d8 View Post
Where did you get the steering wheel from? that leather wrap looks very nce
Canít believe I missed this. I ordered it from EBay.
2001 DINAN S2 M5 - Imolarot
Blog: http://www.obsessedmotorsport.com/blog
E30 318is
E46 M3
E53 4.8is
F31 328xi sports wagon
E39 M5 S2
http://obsessedmotorsport.com/blog/
cncmastr is online now
post #32 of 62 Old 24th May 2019, 01:00 PM Thread Starter
cncmastr
cncmastr's Avatar
Figured Iíd provide an update, seems to make for interesting content for us ancient car lovers...
Iíll go back to a few months ago and catch up.
Finally got around to fixing the leaking washer pump in the wheel well, which scope creeped to wheel liner detailing and Dinan air filter changes...
Then I was able to replace the noise SAP.
Which also scope creeped into replacing the wiper sprayer nozzle hose because it cracked, first buying the wrong harness setup, then the correct one.
Which lead to discovering failing firewall plastic...
And then, I had a chance to fix the orientation of the hood release lever, which was dirty.
After getting the car fully sorted, and doing the coolant system except tstat, the tstat died. During reinstall the water pump casting broke, so new pump housing and tstat from Fcp went in.
During the install, while my buddy was doing it, I noticed the rubber grommets on the valve cover gasket were cracking. So I determined to replace them, all of them. Armed with dozens of new rubber grommets I set out to unpeel the components in my way:
Strut brace
Lid of airbox
Intake trumpets
30 heavy duty bolts that hold down the plenum to the throttle bodies
The oil vent drain lines
Air intake clamps
And then the fun began. Removal was pretty simple until you get to the back.
This project took me over 2.5 weeks to complete, I took my time. It was easy but overly complicated for what it was.
E30 318is
E46 M3
E53 4.8is
E39 M5 S2
post #33 of 62 Old 24th May 2019, 03:08 PM
DAS_V8
Nice work! My VCGs are seeping and need replaced so this is in my future as well. I feel you on the time issue, I'm just wrapping up a 4 month "take my time" maintenance job on my E92M3 that included VCGs, rod bearings, new undertray, new driveshaft/guibo/csb, full fluid flush, etc. It's nice when you have other cars in the fleet to drive and not forced to knock it all out in a weekend.
2003 E39 M5 S2 6MT - responsible family car
2008 E92 M3 6MT - daily
1998 E36 M3 slicktop 5MT - trackrat
2009 Cayenne GTS 6MT - hers
1990 Miata 5MT - guilty pleasure
DAS_V8 is offline
post #34 of 62 Old 25th May 2019, 07:48 PM Thread Starter
cncmastr
cncmastr's Avatar
Agreed. Itís super convenient to have an extra car to use as to not have to rush.
E30 318is
E46 M3
E53 4.8is
E39 M5 S2
post #35 of 62 Old 25th May 2019, 10:48 PM Thread Starter
cncmastr
cncmastr's Avatar
Preparing for war
E30 318is
E46 M3
E53 4.8is
E39 M5 S2
post #36 of 62 Old 7th June 2019, 01:43 PM Thread Starter
cncmastr
cncmastr's Avatar
I did the Euro arm rest thing, which came out great, except the cubby and the handle were really rough. I had no idea you can buy those parts new.
E30 318is
E46 M3
E53 4.8is
E39 M5 S2
post #37 of 62 Old 7th June 2019, 04:48 PM
CSBM5
CSBM5's Avatar
FWIW, there is no clutch delay valve on the M5. The Z8 got one for some inexplicable reason though.
Current stable:
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
cncmastr (8th June 2019)
post #38 of 62 Old 7th June 2019, 09:51 PM
kiznarsh
kiznarsh's Avatar
Originally Posted by cncmastr View Post
What else did you replace besides the shocks? Looks like new strut bearings, bump stops, dust boots, and rubber spring pads?
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
post #39 of 62 Old 8th June 2019, 12:10 AM Thread Starter
cncmastr
cncmastr's Avatar
Yes. I left no stone unturned. New springs too. Iíll sell the old koni and Dinan spring assemblies all pre-assembled.
I added the GAS monoballs too.
By the way, Dinan recommends to modify the stiffness of their Koni shock when using their monoballs, not sure if people are aware.
E30 318is
E46 M3
E53 4.8is
E39 M5 S2
post #40 of 62 Old 8th June 2019, 06:48 PM
BWM
Great reading!
You need to finish of with cherry on the top of the cake:
https://www.ecstuning.com/b-genuine-...FYWenwod368D7w
My factory one was leaking even though it was replaced recently and this one took care of it plus it belongs there anyway.
2003 BMW M5 Blue Water Metallic
VDO oil pressure gauge * ZHP weighed shifter * Euro leather armrest * Spal electric fan * Bilstein B6 (stock springs retained) struts and shocks * Supersprint headers, HJS cats, X pipe, Vibrant Performance resonators, Supersprint Magnum mufflers and all new SS T304 Vibrant Performance mandrel bend tubing.
2003 BMW X5 4.6is Saphire Black Metallic
1997 BMW 528iA Alpine White
BWM is offline
New member intro Infostrada E60 M5 and E61 M5 Touring Discussion 8 2nd May 2012 05:57 AM
New Member Intro loxx E39 M5 and E52 Z8 Discussion 12 13th January 2012 08:48 PM
new member intro/soon-to-be E39 owner kismetcapitan E39 M5 and E52 Z8 Discussion 4 29th May 2011 07:59 AM
New Member Intro rvt1000 E39 M5 and E52 Z8 Discussion 4 8th October 2009 04:04 AM
New Member Intro! MT JTN E39 M5 and E52 Z8 Discussion 27 27th April 2003 08:25 AM
