winter season undercarriage cleaning, right way(s) or don't do it at all? - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 12 Old 6th January 2018, 06:13 PM Thread Starter
gixxer
Hello,
Been searching and either our cars age well from factory's underbody protection, and such, not too much conversations around this topic.
Even if the factory intention of protecting the undercarriage is good and all (eg. germany, i would think their winter is nothing to laugh about), other stuffs like fasteners, brake lines, suspensions, etc. are left susceptible?
So first winter here in North Carolina triangle area. Moved down from Boise, Idaho.
And past days hit with what i would consider a small snow falls, and NC tackled with salt brine's and road salts, which after following day turned the roads with those white residues.
Solutions: don't clean, clean, don't drive, don't live in place that do this, ...
I would like to tackle the cleaning, when the temperature warms up next week to 50's and 60's (go figure to this inconsistent winter in NC, but also best thing about inconsistent winter).
I've picked up from various comments and articles on doing pressure wash (using moderate pressure), lawn sprinkler idea, run your car over tall glass, drive over large puddle, and list goes on.
Including do not do it, eg. can damage your transmission sensors, perhaps strip factory's underbody protection. Perhaps these failures are from not using moderate pressures.
So, how do folks in areas where salt brine's and road salts are used, say in inconsistent winter season, or not, go about maintaining their car's underbelly?
Current thinking is around doing pressure washing using something like this item, though nozzles themselves are not adjustable, the pressure can probably be adjusted from the pressure washer system,
Any suggestion welcomed.
I'm going to post this inquiry to two other favorite forums, m3forum.net and bimimerfest, and will try to roll up comments from others. I don't think e46 m3 is any different in cleaning its undercarriage, but wouldn't hurt to get their forum sayings.
Thanks much.
gixxer is offline
post #2 of 12 Old 6th January 2018, 08:36 PM
intrepid one
intrepid one's Avatar
Originally Posted by gixxer View Post
Hello,
Thanks much.
I live in a salty heavy winter area and used to buy a seasonal pass to a touch free car wash with a strong undercar rinse..Never had an impact in anything but the salt...I also have a heated garage..never an issue with sensors are anything else....I would think that in NC you are going to see more rain than snow, I wouldn't get overly concerned about it.
intrepid one is offline
post #3 of 12 Old 6th January 2018, 09:10 PM
mwmwmwm
mwmwmwm's Avatar
Its been my experience
Most fasteners are now-a-days built to handle road grime. This includes mag chloride, salt and h2o. Where necessary engineers use moisture resistant plugs, galvanized bolts, stainless parts and plastic rivets / screws. I'm always fascinated on relatively modern cars with their use of drain holes and parts integration. In particular BMW. They have come a long way from an E9.
I've wintered my car for years. During the clutch job I recently completed I even retained my exhaust manifold bolts. 16 year old car @160.
Jeeps use to be frozen together after a few years of salt. Not so anymore.
Wash when it gets dirty. White buys you the most time.
Letting Ms sit should be a crime unless your out of money for gas and tires.
My 2 pence.
mwmwmwm is offline
post #4 of 12 Old 7th January 2018, 06:34 AM
Azkael
E39 doors seem to rust when the drain and weatherstripping is clogged. I would recommend flushing the dirt out
Azkael is offline
post #5 of 12 Old 7th January 2018, 07:57 AM
Hey, Nice Marmot
Hey, Nice Marmot's Avatar
Would a drip oil spray be an option? I don't know much about it but someone from Canada could probably comment on it.
A guy on the YouTubes, AMMO NYC, might have some info on your question as well.
Hey, Nice Marmot is offline
post #6 of 12 Old 7th January 2018, 01:54 PM
CSBM5
CSBM5's Avatar
With the car on a lift, remove the underbody panels, and you can quickly spray it down and use car wash soap/degreaser/etc on the whole underside. The best solution is to not drive it on our roads with all this salt stuff -- especially during the first rain like expected later this week. There are some areas just caked in salt right now -- totally white and thick. That stuff is going to be nasty during the first rain and likely into the 2nd rain event. Even with a thorough underside scrubbing/spraying on a lift, you can't easily get to places you need to where that salt spray from driving in that first rain event will end up. If you're so inclined, once on the lift, you can remove all wheels, pull all the underbody panels, pull the front and rear fender liners, pull the front and rear bumper covers, and really go at it simply using a good car wash soap/all-purpose cleaner/degreaser.
For the most part, we see so little winter road stuff here in the RDU area, most local cars hardly show signs of it from just a few days/year. However, you can really see it on a car from up north -- all the rust on exposed bolt threads/nuts, other steel based items, and corrosion on all the aluminum parts, etc. We've always had an older 4th car that receives use during times like these, and I never worry about it. (E91 doing this duty now). I sold our Volvo 850R wagon two years ago after owning it for 20 years here, and it saw a good bit of winter roads over that time -- still zero rust on any body part and only very minor surface rust on exposed bolts/nuts/etc.
Current stable:
CSBM5 is offline
post #7 of 12 Old 7th January 2018, 04:49 PM
xrviz
xrviz's Avatar
I will occasionally go to a drive-through brushless carwash for the underbody wash feature.
xrviz is offline
post #8 of 12 Old 8th January 2018, 03:12 AM Thread Starter
gixxer
Thanks all for the feedback's and suggestions.
I do not have a heated garage so i'll need to find a day this week to spray (with hose and sprayer), and have the car sit for few hours to thoroughly dry out. The region is supposed to hit 65 on Friday this week.
That's good to know since you said the forecast has thu/fri/sat for chance of rains.
And coming out of 540 toll to Cary exit, you can see good 15 or so yards of thick white residues.
Though this past snow seem seem small fall, NCDOT really pulled out all the stops.
gixxer is offline
post #9 of 12 Old 8th January 2018, 04:37 AM Thread Starter
gixxer
Someone posted following gizmo, something like the lawn sprinkler idea, with you controlling the angle of the spray. And the pressure doesn't seem all that strong but does say one can adjust the pressure from the garden hose attach. At least doesn't require separate pressure wash system. There is no nozzle but just some holes drilled in the pvc pipe.
One could take this concept and apply in your weekend DIY.
The Underwasher :: Hose accessory that lets you clean under your car, RV, boat or ATV!
gixxer is offline
post #10 of 12 Old 8th January 2018, 02:28 PM
CSBM5
CSBM5's Avatar
Yes, it truly seems like they went crazy overboard. I guess the extreme cold temperatures forecast for after the snow led them down that path, but this is by far the worst I've ever seen our roads. Some areas are insane like you mention -- just noticed the area around I-540 and Capital Blvd entrances and exits look like snow everywhere along the side of the road but is in fact a thick layer of salt. Hopefully we'll get some serious rain later this week to help get rid of this junk.
Current stable:
CSBM5 is offline
e63 m6 vs winter on all season tires video m6pl E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 10 4th February 2016 06:20 AM
Winter season with the ski/snowboard rack. DKNewYork E60 M5 and E61 M5 Touring Discussion 8 6th April 2014 01:32 AM
Wheel cleaning products - don't use PAM! palantirion E39 M5 and E52 Z8 Discussion 28 9th August 2006 03:51 AM
cleaning/detailing wheel wells/undercarriage schnelleM5 E39 M5 and E52 Z8 Discussion 3 31st December 2002 02:03 PM
Anyone used All Season tires in Winter? Digi E39 M5 and E52 Z8 Discussion 1 19th July 2002 06:15 PM
