Fixing up an S62 before plunking it into an E34 - Page 23 - BMW M5 Forum and M6 Forums
 20Likes
post #221 of 234 Old 21st September 2018, 07:48 PM Thread Starter
TSI
TSI's Avatar
Originally Posted by terraphantm View Post
Maybe just run the one then. The dme doubles the maf value if only one signal is present.
You're kidding, right? I may just have to bash my head in if you're serious!
I had no idea, that would simplify my life a hundredfold. Which bank gets the IAT reading?
TSI is offline
post #222 of 234 Old 22nd September 2018, 01:13 AM
Sailor24
Sailor24's Avatar
You still need two tubes to not create high vacuum. If you have two tubes you can also run the two MAFs in a single tube so you don't have to re code the DME error from only having one.
This is sort of making me happy I spent 1200 redoing the sub frame to move the motor back an inch and down a half. It is also really pretty with its powder coat not that anyone will see that.
Sailor24 is offline
post #223 of 234 Old 13th October 2018, 03:36 AM Thread Starter
TSI
TSI's Avatar
Overdue update: I've barely driven the car while I've been battling two massive leaks. One, power steering fluid, was caused by a faulty -6AN fitting.
The other is oil, looks like a combination of bad valve cover gasket (very disappointing) and also from a -10AN fitting on the oil lines I had made from the filter housing to the engine mount arm.
TSI is offline
post #224 of 234 Old 18th October 2018, 10:43 PM Thread Starter
TSI
TSI's Avatar
I'm struggling with a starting/possibly charging problem.
As of this morning, I've gone through 3 failed starter motors since July. I'm wondering if the fact that I use the M5's 120A alternator has something to do with this (original E34 is 140A). My lights do flicker a bit at idle, it's barely noticeable and goes away as soon as I hit 1000 rpm.
My battery is healthy, and aside from the starters failing to crank altogether, never had a hard start.
TSI is offline
post #225 of 234 Old 18th October 2018, 11:33 PM
RVAE34
I had forgotten how fickle the E34 electrical was! I recall having to upgrade my alternator when I did the M52 swap.
RVAE34 is offline
post #226 of 234 Old 19th October 2018, 05:22 PM
Sailor24
Sailor24's Avatar
Starters don't fail like that. Something is weird maybe the starter should get a postmortem to determine what is killing them. If the starter never got slow just died sounds like the electricity is flowing through wrong, is the motor got a good ground strap on it?
Sailor24 is offline
post #227 of 234 Old 19th October 2018, 05:23 PM Thread Starter
TSI
TSI's Avatar
Argh. I wish I had thought of that before spending all that money on an alternator rebuild.
Anyone know of a 140A+ alternator for the S62? My searching so far has proven itself fruitless.
TSI is offline
post #228 of 234 Old 19th October 2018, 11:00 PM
RVAE34
I know I upgraded but it's been far too long to remember what I went with so don't take that as the gospel. But I "think" you are on the right track.
RVAE34 is offline
post #229 of 234 Old 20th October 2018, 02:05 AM Thread Starter
TSI
TSI's Avatar
Thanks. I'm going to try to find an alternator repair place to rewind it with additional coils. Hopefully I can squeeze out a few more amps.
TSI is offline
post #230 of 234 Old 22nd October 2018, 03:59 AM
terraphantm
The M5 alternator apparently bolted onto this guy's 528i: https://www.bimmerfest.com/forums/sh...82&postcount=2
Which if true probably means M54 alternators could bolt onto the S62. I believe the most powerful of those is 155A model (part number 12317541696). Technically those alternators use some fancy serial interface for diagnositcs and have a different connector, but I've heard of people changing their connector and using the alternator without issue
Otherwise there's a 140A alternator from the X5 3.0i (part number 12317551253) with the same connector as the stock S62 connector
terraphantm is offline
E34 S62 swap s62e34 E34 M5 Discussion 65 6th January 2018 11:45 PM
Rebuilt S62 or Sleeved S62, built to your spec service tradin1 M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 1 20th June 2012 08:56 AM
E34 M5 S62 for sale dallas E34 M5 Discussion 17 17th March 2011 04:10 AM
E39 S62 V8 into E34 M5, when will the first E39 M5 with V10 S85 be ready? Gustav E39 M5 and E52 Z8 Discussion 34 11th February 2011 06:49 AM
s62 in e36/e34 Payam972 E39 M5 and E52 Z8 Discussion 16 28th October 2009 07:53 AM
