My German Autobahn Mile Muncher - '01 Titanium Silver E39 M5 - Page 4 - BMW M5 Forum and M6 Forums
 310Likes
post #31 of 293 Old 18th December 2017, 02:13 PM Thread Starter
sreten
sreten's Avatar
Originally Posted by kiznarsh View Post
Awesome! This post read like how one of the senior technicians at work talks: "all'z ya gotta do is take the cluster out, swap the ribbon, and then put it back together again. I mean how hard can it be?!"
Haha, I did make it look easy with the pictures.
Originally Posted by armada View Post
Im gonna follow this thread! Thumps up
Thanks for reading!
I refreshed belts and pulleys over the weekend.
Searched the forum and found the corresponding pulleys to be suitable.
I went with Ruville parts which had INA engraved on them.
Water Pump / Alternator / Power Steering Belt - 11281710045 x2
AC Compressor Belt - 531076010 x1
And Continental belts.
Fairly easy and quick job to do. Drove the car onto the ramps, removed the fan clutch and underbody panel and that gives you enough space to work with.
All 3 pulleys were shot and spinning freely, but surprisingly didn't make that much noise.
AC belt was replaced at some point and was still good, while the serpentine had cracks.
Glad to have done this. The parts are not expensive and it's good maintenance.
And now the upcoming major update.
I decided to replace the clutch. When I test drove the car in Italy it wasn't that bad and felt like an old original clutch.
Now that I've been driving it more, I can feel that it's showing symptoms of a failing clutch.
For example, the clutch pedal is very stiff and catches I would say kinda high.
If I'm not careful with the gear changes and my foot isn't entirely off the clutch, it will slip. If it's leaned just a bit on top of the clutch pedal, it will start to slip.
When I push it hard and just go through the gears, it will never slip and I can probably get a lot more miles out of this clutch, but it's not very enjoyable to drive and since this is probably the original clutch it makes sense to change it before it gets worse and I burn the flywheel completely. Hopefully, I can get away without replacing the flywheel this time, but I won't know that until the transmission is out.
So I made a pretty decent parts list for this job which I will post later down the road. There is a lot of useful information on the board regarding this topic which helped a lot.
Unfortunately, this isn't something I can do myself on the floor of my garage and I found what appears to be a very good shop that will do the work for me.
They are not far from me and they specialize in M models from this era. I paid them a visit last week and had a nice chat with them. They are also BMW enthusiast who daily drive E36 M3, E46 M3 and X5 M. I was told that they do everything by the book and won't rush the job which is important to me.
They were actually working on another E39 M5 that day. '02 Le Mans blue M5 with 100k miles that was getting around $7.000 worth of work. New guides, vanos, bearings... Kinda scary to hear and see this. His opinion is that this example was seriously neglected and was just nasty when they opened it up.
My M5 should go under the knife on Wednesday so stay tuned.
sreten is online now
post #32 of 293 Old 18th December 2017, 04:24 PM
Bojangles
Bojangles's Avatar
What an awesome introductory thread! Definitely subscribing for future updates. I am actually in the process of performing similar maintenance on my recently acquired '03 M5. It has been a fun process, but I wish I had the time and discipline to document everything like many users on this board are doing. Keep up the good work!
Bojangles is offline
The Following 2 Users Say Thank You to Bojangles For This Useful Post:
sreten (20th December 2017)
post #33 of 293 Old 20th December 2017, 09:27 PM Thread Starter
sreten
sreten's Avatar
Thank you, sir! Wish you good luck with your beast.
The good work indeed continues. I left the car at the shop this morning and I was getting updates all day.
Good thing about a car from Italy is that the undercarriage is rust free and things were going smoothly according to him.
The exhaust really is gigantic.
I had a diff leak at the input shaft seal so they knocked out that as well. The rest of the diff is dry. Had the same leak on my old M5 from there.
Cracked driveshaft center bearing.
Guibo was still good, but replaced with a new one anyway following the good old logic of while in there.
And my suspicions about the clutch were correct. Clutch disc and pressure plate are toast.
The previous owner was a proper douchebag in the whole buying process and now I know he shouldn't be allowed to operate a kick scooter let alone a clutch in a car with 400 PS. Though, granted it's not mission impossible to burn the clutch in this car quickly.
According to the shop the flywheel is still good which is a relief to hear.
I should pick up the car tomorrow. Very excited!
post #34 of 293 Old 21st December 2017, 04:16 AM
kiznarsh
kiznarsh's Avatar
Glad it's working out. Replacing with an OEM clutch?
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is online now
post #35 of 293 Old 21st December 2017, 10:03 PM Thread Starter
sreten
sreten's Avatar
Thanks! Everything turned out great. Yes, OEM clutch kit. Didn't want to experiment too much there.
They finished it this morning so I picked it up after work and we are back in business!
What a refreshment this is compared to the old clutch. The clutch pedal is buttery smooth and gear shifts are clean and crisp.
To recap, this is the parts list that I used. I didn't want to go too wild with while in there parts and I got what I thought was essential.
OEM LUK clutch kit - 21217515146
This is the original M5 pivot pin made of plastic.
I went with a steel one from 850CSi - 21511223281
Transmission mounts x2 - 22316771221
Guibo/Flex disc - 26112228781
(Even though original parts were still good)
Pressure plate bolts x6 - 07119906045
Clutch fork - 21511223302
Spring clip - 21517570284
Drive shaft center bearing - 26122228917
Exhaust pipe gasket x2 - 18301728734 (not in the picture)
Rear main seal gasket - 11141736521
Differential cover gasket - 33108305033 (wasn't necessary, it had no leaks there)
Differential input shaft seal - 33121213949
Differential drain plug gasket - 07119963355
Drive flange washer - 33121205138
Brake fluid - ATE Typ 200 (they said that the old brake fluid was nasty)
Transmission fluid - Liqui Moly 75W-80 (this too came out nasty)
Differential fluid - Liqui Moly 75W-140 (this wasn't that bad)
I believe I have everything accounted for.
Shop also did a courtesy check of the car. They run a vanos test and the results were great!
They checked for leaks around the engine and everything is dry. Brakes, controls, bushings... all good and tight!
They only advised that there might be little play in the front strut mounts. These are known to develop cracks in the rubber over the time so I will be replacing that in the near future. These are cheap and can be replaced without taking the sturt off the car. I also have Meyle HD sway bar links coming in so that will be refreshed as well.
Now I just have to take it easy over the next 600 km or so and break in the clutch properly. BMW break-in procedure that I found here states that I shouldn't go in high rpm or do high power shifts and that I should shoot for 800-1000 gear shifts. I lost count at 3.
Shop charged me 550€/$650 for the labor which I think is fair given the amount of work.
My bank account sure has suffered but now I'm one happy M5 driver!
Bis später!
post #36 of 293 Old 22nd December 2017, 09:33 PM Thread Starter
sreten
sreten's Avatar
So, ever since my Le Mans blue M5, I've been eager to do something with the exhaust and get more sound out of that lovely V8.
Since I live in Germany, my options are pretty limited and simple stuff like muffler delete is out of the question. That would never fly around here, it means immediate fail on inspections and trouble with Polizei. When they pull you over, they actually snoop around your engine bay and under the car to see what is your setup and even bang on the rear cans to see if they are empty. If I don't have a TUV certificate for my aftermarket exhaust they can impound my car and slap me with a big fat ticket.
There are only two exhausts that I know of that have TUV approval. Eisenmann Sport and Supersprint Performance/Magnum, impossible to find used and stupid money if you buy them new.
Searching used car parts today, I stumbled upon something interesting. An original rear muffler that, if I understood him correctly, has electronic flaps before the silencers.
You can remotely control the flaps and when they are closed, it sounds just like a normal stock muffler, but when open it bypasses the rear the muffler and basically acts like a muffler delete. Having best of the both worlds if you will.
This of course is not legal either, but at least it would give me some flexibility and it's not that obvious.
This is how it sounds.
https://drive.google.com/file/d/1X3T...ew?usp=sharing
To be honest, I got in touch with Eisenmann a while back and they gave me a very nice discount on a new Sport exhaust through the local M club here. But seeing this one got me thinking. The guy wants around $550 with the install and I keep my original exhaust which is much cheaper than the Eisenmann. On the other hand, I don't want to put just whatever on the car and potentially hurt its value. I love keeping things original, but stock setup is simply quiet.
What do you fellas think?
post #37 of 293 Old 23rd December 2017, 02:03 AM
JohnAnthony
JohnAnthony's Avatar
550.00USD doesn't seem that bad for a set of muffler installed. The only thing that holds up the mufflers are 6 bolts, the hard part is cutting the exhaust while it's still mounted.
For Supersprint have your checked the pricing from Schmiedmann? They're having a sale on SS products.
I don't think either Eisenmann or Supersprint would hurt the resale value, especially if you have the OE mufflers to go with it. On the other hand splicing in the exhaust bypass can raise eyebrows. I would be more skeptical of how they did the wiring vs. a quick cut with a metal saw.
JohnAnthony is offline
post #38 of 293 Old 23rd December 2017, 06:53 AM
toastie
toastie's Avatar
toastie is offline
post #39 of 293 Old 23rd December 2017, 05:07 PM Thread Starter
sreten
sreten's Avatar
Originally Posted by toastie View Post
Great thread!
Thank you!
I slept on it and I'm definitely not doing this. You are totally right, it might raise eyebrows and at the end of the day, it's just not what I want to do. I have my mind set on Eisenmann.
I checked Schmiedmann and there is a sale on SS products. SS magnum/performance is around $1.000, but only if the delivery address is outside EU, if it's Germany there's no discount and they have to add 19% VAT and the price is $1.460. I heard SS magnum in person and while I liked it, it didn't seem like a big improvement over the stock mufflers to justify spending that kind of money. If you pair it with an X-pipe it would be a different story, but that's also illegal here. For little less than that I can get Eisenmann Sport which is what I will most likely do.
Finally gave the M5 a proper hand wash and followed up with Meguiar's Carnauba wax. Planning to detail it completely in spring, but I'm very happy with the condition of the paint.
Could just sit back and stare at it for hours, looks beautiful from every angle. I love it!
post #40 of 293 Old 23rd December 2017, 07:07 PM
r2t2k2
r2t2k2's Avatar
Great thread! I think quite a few of us have had those same piles of new parts for our M's. I had hoped that mine would be stealthy enough that people would think it was a plain ole 5 series. Not so... I lucked out when I found mine and got the Carbon Black. My E46 M3 is silver so I was wanting something different. I love the beast on the open highway. I used to have to drive from Boise to Cedar City on a fairly regular basis and the M5 was always my choice. Freinds are shocked and amazed when they realize how fast and comfortable it is at "speed".
Another thing I love about older M cars is that they only came with manual transmissions. My daughter wouldn't drive either because she doesn't like having to shift... And most of the guys she dated over the years couldn't drive on either.
RayK
'01 E39 M5
'06 E46 M3
r2t2k2 is offline
The Following 2 Users Say Thank You to r2t2k2 For This Useful Post:
sreten (23rd December 2017)
searching for clean, low mile, Titanium Silver M5 (2002 or 2003) jasonfreed E39 M5 and E52 Z8 Discussion 17 27th September 2010 05:09 PM
My Titanium Silver E39 M5 SpeedTweaker USA South BMW M Forums 2 6th March 2010 02:45 AM
Titanium Silver E39 in Scranton Strike Sightings / Spotted M5 around the world: was it you? 0 17th August 2009 05:38 PM
2000 E39 M5 Titanium Silver jlvink Cars For Sale or Wanted 2 20th January 2007 05:00 AM
UK E39 M5 Titanium Silver For Sale LancsM5MAN Cars For Sale or Wanted 0 17th March 2006 09:46 AM
