Thinking of upgrading the M audio. Need some advise. - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By DouglasABaker
post #1 of 10 Old 24th November 2017, 11:03 PM Thread Starter
auaq
My Nokia subs are starting to rattle even at low-mid volume and I've been thinking of upgrading the entire system to something that's better out there. I'm not looking to spend a whole of lot of money. Think of it more like a budget build or at least an improvement to the current M audio system. Any advises or recommendations on where to start looking at would be appreciated.
Danku.
auaq is offline
post #2 of 10 Old 25th November 2017, 06:23 PM Thread Starter
auaq
auaq is offline
post #3 of 10 Old 25th November 2017, 07:09 PM
taninbim
Bavsound was one of the better options, but they have nothing for the M audio anymore. I recall reading past posts about custom setups, but they were all piecemeal and required lot of modifications to fit properly.
taninbim is offline
post #4 of 10 Old 25th November 2017, 07:26 PM
xrviz
xrviz's Avatar
Everyone's too full of turkey to reply......
If you want good quality bass for cheap, and have the time, you could do what I did. Single JL Audio 8W3v3 in a home made enclosed box. Bolted up to the rear deck sub opening. Sealed off the other deck opening.
xrviz is offline
post #5 of 10 Old 25th November 2017, 10:52 PM
Rittmeister
Rittmeister's Avatar
It may not be the subs themselves. I was getting a good bit of rattle; did some searching here and elsewhere, and wound up pulling the back deck, and adding some foam and double-sided tape between the metal decking and the insulation layer that goes on top of it. The insulation has a paper backing of some kind that lays against the metal, and over time I think it has hardened or become less flexible, and it rattles/flaps against the metal depending what kind of music is playing.
After adding the tape and foam here and there, the rattle is gone for now. No idea how long this fix will keep but for now I'm pretty pleased. YMMV.
Rittmeister is offline
post #6 of 10 Old 25th November 2017, 11:06 PM
CSBM5
CSBM5's Avatar
Did a quick search on threads started by Brian as I thought he fixed something to do with rattles and the M-audio subs: https://www.m5board.com/vbulletin/e39...e-picture.html
Current stable:
CSBM5 is offline
post #7 of 10 Old 26th November 2017, 05:02 AM
DouglasABaker
DouglasABaker's Avatar
Best upgrade to the factory subs is the addition of an amplifier for the subs. The Nokia box isn't bad when you give it more power. Rate is fixed by securing the rear deck speakers - probably not the sub box itself.
Doug
DouglasABaker is offline
post #8 of 10 Old 26th November 2017, 05:57 AM
Dking078
Dking078's Avatar
Early on BavSound had an " M Audio Supplement" Which IIRC was re-mounting the cross bridge tweeter on top of the BSW midranges. They later redacted it and just went with "M audio is better, no need".
Doug
+1. Despite being pretty punny, they are decent. Now, an independent amp AND M Audio subs it'll be earth rattling
2003 BMW 540i [Sterling Gray / O5SW M5 Black Interior]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one true authority of E39 Trim. --E39 Trim Information Thread [Click]
For Sale:
2004 BMW X5 4.8is [Black/Black] [Click]
E39 OEM Refreshed Xenons with new DJ Auto euro lenses! [Click]
E60 Windshield washer sprayer nozzles "Fan" style [Click]
E39 HVAC Buttons [Click]
Got Broken E39 Rear Quarter sun shades? [Click]
Random stuff I don't list on the board: https://www.ebay.com/usr/dking056
Dking078 is offline
post #9 of 10 Old 2nd December 2017, 01:39 AM
ObjectEdit
Is this right? so keep all M Audio speakers as is... and just run M-Audio subs w/ aftermarket amp?
(I'm also looking for simple, effective upgrades to the stock M-Audio)
ObjectEdit is offline
post #10 of 10 Old 2nd December 2017, 02:07 AM
DouglasABaker
That's an alternative, but it wouldn't be my first one given the m-audio speakers. Best option is a 4 channel amp and new sets of component speakers for front and rear. Eliminate rear and run front only if you are really cash strapped.
Add an amp for the m audio subs.
Done
See my blog for more details. It is pretty easy and can be inexpensive depending on your choice of hardware.
Doug
The Following User Says Thank You to DouglasABaker For This Useful Post:
ObjectEdit (8th December 2017)
Upgrading Audio with amp and sub(s) only... Fast.M5 E60 M5 and E61 M5 Touring Discussion 5 31st July 2012 05:30 PM
Need advise on audio m_coupe1999 E60 M5 and E61 M5 Touring Discussion 11 23rd September 2011 05:17 PM
Upgrading factory audio 03silverM5 E39 M5 and E52 Z8 Discussion 0 22nd February 2007 06:49 PM
Update: My selection for upgrading the M-Audio Shenandoah E39 M5 and E52 Z8 Discussion 34 25th August 2001 01:41 PM
My selection for upgrading the M-Audio Shenandoah E39 M5 and E52 Z8 Discussion 13 30th July 2001 03:54 PM
