Replaced the driveshaft without removing the exhaust! - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 13 Old 8th November 2017, 05:32 PM
Trizzuth
Trizzuth's Avatar
Hi Pau,
I have this reman'd driveshaft sitting at my house in a box right now. I took it out and inspected it and it looks legit!
One obvious question, normally when people remove the driveshaft to replace just the guibo, or CSB, they mark the guibo so they are sure to mate the driveshaft back to the guibo in the exact same spot. I assume this is not necessary (as long as the guibo is installed properly) when putting in the rebuilt driveshaft sice my guibo is new, CSB is new and rear CV joint is also new, correct?
I have the correct gasket for the diff and will also be doing the rear pinion seal in the diff while the exhaust and driveshaft are off the car. Thanks!
Trizzuth is online now
post #12 of 13 Old 8th November 2017, 06:09 PM Thread Starter
Pau_Hana
Pau_Hana's Avatar
Originally Posted by Trizzuth View Post
Hi Pau,
Correct, sir! The hardest part is ensuring the guibo is installed correctly. The driveshaft is an easy R&R otherwise.
Pete
2003 Black Beastie...quite fun!
Pau_Hana is offline
post #13 of 13 Old 29th November 2017, 01:08 AM
Trizzuth
Trizzuth's Avatar
Just a note that I did this job and ordered the driveshaft from the same place as you, OP. Car drives amazing now, glad I ran across this thread when I did!
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
GROUP BUY: The Driveshaft Shop - Carbon Fiber Driveshaft FastHackem M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 25 10th March 2019 06:25 PM
Removing/Torqueing driveshaft smithr E39 M5 and E52 Z8 Discussion 6 30th March 2017 08:21 PM
Replaced Exhaust CPS - Still Low Torque & Blatty Exhaust Shivgtr E39 M5 and E52 Z8 Discussion 80 29th July 2015 09:24 PM
E-brake cable repair. Drop exhaust and driveshaft? russap5 E39 M5 and E52 Z8 Discussion 30 24th February 2010 12:53 AM
Squeaking sound when rolling...replaced my center driveshaft support wrecks E39 M5 and E52 Z8 Discussion 3 5th November 2007 06:30 PM
