Trizzuth's 2003 E39 M5 Maintenance Thread - BMW M5 Forum and M6 Forums
 10Likes
post #1 of 198 Old 11th October 2017, 02:48 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Hello gents,
I came from the E46Fanatics world as I had been on that site since 2005, and just lost my 2001 330i to a total loss accident. An 85 year old woman claimed her foot slipped off the brake and onto the gas as she shot out of a parking lot unbeknownst to me and crushed the right rear quarter of my car. Being an 01 with 236K miles (all maintained by me) insurance felt the car was pretty worthless. Took a few weeks and proof via many many receipts of parts (all my labor unfortunately) to raise the value to an acceptable figure. I was also able to rape the car for any other aftermarket parts I could unload so I did ok in the end.
Picked up my new (used) 2003 TiAg M5 with 79K miles about 2 hours away from home, but still in Mass. Wiggled on the price a little bit and in the end considering what I was able to get for my E46, I picked this up for just under 20K.
Small things I have done thus far to bring my thread up to speed:
1) Had to get new front tires (Michelin Pilot Sport A/S to match the backs that were new). The Fronts were older Michelin Pilot Sport A/S from back in 2010 and had chunks of rubber missing from the tread area, even though the tread was still deep, tons of dry rot and it made me nervous on a car of this caliber so I had new ones put on.
2) Installed the short clutch stop from the ebay user recommended on here, made that lower clutch pedal dead spot so much better and car still starts no problem!
3) Hardwired my V1 so I am protected or at least on the defensive end all the time.
4) Inspected all 4 brakes, everything looks good, washed and waxed with Klasse All in One before the winter comes.
5) Figured out a decent solution to the water pooling in the gas cap area, for which I will post up some pics soon so you all can see. Granted it's not an optimal solution, but with the door closed you can't see anything and that was the only area on the entire car where there were some small rust bubbles.
6) Got under the car to check everything out, repaired the lower right fender belly panel the best I could until I get a new one, and found some exhaust brackets totally rusted through. I have the replacements from FCP in my garage right now waiting to go in.
7) Found out there is green coolant in this car (YIKES!!!) and not OE BMW Blue. Have records from PO of thermostat being replaced around 2013, so that is new-ish, as well as the clutch.
8) Issues I am currently perplexed with: Strange hesitation sometimes in 1st and 2nd gear, I've read on here about this, seems better with Sport mode engaged, but does not feel like it drives perfectly in 1 and 2. The rest of the gears are good. I am exaggerating this issue, but there is definitely something up. Also the clutch makes a spring-like sound when depressed and released which I also read can be normal, but my bigger concern (hoping it's the loose exhaust bracket rattling) is that once 1st gear is engaged, during the process of engagement, there is a strange creak.
I need to get my airbag recall done soon, so I am hoping to have the dealer at least assess the car overall and take a peek at the 1 and 2 gear issue along with the clutch noise. We'll see what they say.
Otherwise this thing is amazing, it's literally my favorite car of all time, so much so that when my girlfriend and I were dating, she rented me one from a high horsepower rental place for like $600 for one day! It stuck in my mind ever since. That was back in about 2001.
Just rolled the ODO over 80K the other day. Oil looks perfect, no leaks anywhere from what I can see. Will try to post up some pics that are on my phone soon.
Trizzuth is online now
post #2 of 198 Old 11th October 2017, 02:54 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Here are a few pics I had stored on my pc..
One is of my buddy's 2000 528i (with swapped 540i trunk) that has just about 400K miles!
Another is of the 18" style 5 reps I had for my E46 that had an E39 center bore and came with hub-centric rings to fit the E46. Just confirming if they fit so I could use them as a spare if necessary, and they did, although offset pushed in a bit.
post #3 of 198 Old 11th October 2017, 02:58 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Few more pics here...
put my old 5 speed ZHP shift knob in there right away, is so much better now that it's a bit lower, and my 6th gear is incognito! Ha, I may get a 6 speed one eventually but right now it works great.
Also found the OE M Mobility kit with godknowshowold tire sealant!
post #4 of 198 Old 11th October 2017, 03:01 PM Thread Starter
Trizzuth
Trizzuth's Avatar
^^ also can see chunks of rubber missing from front tires. This was not the worst part either. With no spare at the time, I didn't want to take the chance getting stranded somewhere and have to get this car towed within weeks of getting it due to a flat!
Pic there also of the KTEMP value as I was checking proper operation of my thermostat. This was after a bit of around town driving, it stays steady at 78-79 most of the time otherwise and seems to be perfectly operational.
post #5 of 198 Old 11th October 2017, 03:04 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Lastly, I bought a stainless steel tow hook plate bracket since they are insane here in Mass with front plates. I drove my E46 for a few years with no front plate but eventually got tagged and warned, so I just don't want to be at risk giving them any reason to pull me over, and this was my best (unfortunately hideous) option so the plate would be secure and wouldn't flop like crazy. I have checked out all other options on here and may eventually go to the center mounted one that has the quick release. It set off my front PDC sensors like crazy, so I have disconnected the 2 on that side and now it's quiet inside.
post #6 of 198 Old 11th October 2017, 03:54 PM
Rontgen
Rontgen's Avatar
Congrats and welcome! Looks like it's in great shape!
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Rontgen is online now
post #7 of 198 Old 11th October 2017, 03:55 PM
xrviz
xrviz's Avatar
Hesitation issues may be VANOS. Any idea if/when maintenance was done?
Keep up the good work!
xrviz is offline
post #8 of 198 Old 11th October 2017, 04:04 PM Thread Starter
Trizzuth
Trizzuth's Avatar
This was my immediate thought, however I get zero rattles on a cold start, so wasn't that the basic sign that your vanos was going out? I did multiple vanos seals repairs on E46s, but the E62 vanos repair is far more complicated. Nothing I am afraid of, just car needs to be down for awhile.
If there is hesitation when the car is cold and it gets better once warm, is that also a sign of bad vanos seals? And how come it's really only an issue in gears 1 and 2?
post #9 of 198 Old 11th October 2017, 04:09 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Here are more pics as promised.. gas gap area fix with Flex seal from a can carefully poured in to create a slight incline so water can just roll out of there..
Rusted exhaust bracket that is loose, have replacements ready to go in..
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
post #10 of 198 Old 11th October 2017, 04:13 PM
xrviz
xrviz's Avatar
First off, try to find out what the PO has done regarding the VANOS. Then read the vanos diy threads in the diy sticky. The main issue is not startup rattle but crud plugging the solenoids causing them to not advance/retard the cams properly. Many people experience a jerky throttle in lower gears.
If it hasn't been done, you need to pull the solenoid boards, remove the gauze filters, blast the noids with brake cleaner/compressed air, and replace the solenoid O rings. Inspect/test the solder points.
xrviz is offline
Feeblebob's Maintenance Diary Thread feeblebob E39 M5 and E52 Z8 Discussion 70 10th October 2016 04:18 PM
E60 M5 Maintenance Thread Black Hawk E60 M5 and E61 M5 Touring Discussion 74 8th June 2016 11:39 PM
Rust/maintenance on a 2003 in S.E.A nakmuay E39 M5 and E52 Z8 Discussion 0 30th July 2012 09:50 AM
For Sale: 2003 M5 66,000 miles CPO/extended maintenance Jenner Cars For Sale or Wanted 8 2nd August 2008 07:34 PM
Just found out MY 2003 comes with full maintenance!! Bluewater M5 E39 M5 and E52 Z8 Discussion 7 4th March 2003 06:56 PM
