Trizzuth's 2003 E39 M5 Maintenance Thread - Page 2 - BMW M5 Forum and M6 Forums
 8Likes
post #11 of 178 Old 11th October 2017, 04:20 PM
Rontgen
Rontgen's Avatar
That Flex Seal seems like it would trap water underneath, making the problem worse?
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is offline
post #12 of 178 Old 11th October 2017, 04:30 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Originally Posted by xrviz View Post
First off, try to find out what the PO has done regarding the VANOS. Then read the vanos diy threads in the diy sticky. The main issue is not startup rattle but crud plugging the solenoids causing them to not advance/retard the cams properly. Many people experience a jerky throttle in lower gears.
If it hasn't been done, you need to pull the solenoid boards, remove the gauze filters, blast the noids with brake cleaner/compressed air, and replace the solenoid O rings. Inspect/test the solder points.
Thanks for the detail, I will need to inspect this and see if this may be what is causing the hesitation, as I want this car to drive normally and it's frustrating the way it drives around town right now!
No way, it was completely bone dry before I put the flex seal on there, and now that it's dried out, it's totally glued tight to the paint work and there is no way any water can ever get underneath now.
Trizzuth is offline
post #13 of 178 Old 11th October 2017, 05:32 PM
Ibmotoren
Ibmotoren's Avatar
From my basic understanding of rust, you have only hidden it from your view. It will continue to creep underneath the flex seal until one day you'll see it peeking out. Wait too long and it will appear on the outside of your filler area. It's your car, do as you please, but I wouldn't be so adamant that flex seal has stopped rust bubbles.
Originally Posted by Obioban View Post
...My gas cap area water collector/storage area (terrible design) had developed its inevitable rust. I waited too long to go after it-- it has spread to under the gas door, which is visible with the gas door closed. Really kicking myself for that.
Anyway, ground it down to bare metal (didn't take any pics because I was too busy hating myself), degreased it, metal prepped it, POR15ed it, and painted it. It's visible if you're looking for it, but not the worst thing ever. Kicking myself for not going after this before it spread to a visible area of the car (I actually asked the body shop to address this when it was recently in, but they forgot).
At least the spread should stop, now that it's POR15ed...
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is offline
post #14 of 178 Old 11th October 2017, 06:11 PM Thread Starter
Trizzuth
Trizzuth's Avatar
I agree that what i did has certainly not stopped the rust creep, but seeing that water pool in there, any time it rains or there is enough dew to run down the car is 10000 x worse in my opinion. My E46 turned into a rust bucket up here in the northeast and I will do everything I can to prevent this car from becoming that, although I know it is ultimately inevitable!
New exhaust brackets installed and new O2 sensor wire hangers also installed. Man the old ones were rough. Pics coming in a bit.
Trizzuth is offline
post #15 of 178 Old 11th October 2017, 06:13 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Here’s the exhaust bracket carnage and new installed..
New o2 wire hangers
Does this rear metal brace bar look bent to you? Or should it be like that?No idea wtf the PO was driving over to get this kinda scratches in the bottom of the gas tank! Speed bumps maybe??
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #16 of 178 Old 11th October 2017, 09:43 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Polished up my tips!
Dirty
Clean
Also, testing a black rear valence with some plasti dip.. will see if I like it or not..
Trizzuth is offline
post #17 of 178 Old 12th October 2017, 03:27 AM Thread Starter
Trizzuth
Trizzuth's Avatar
Valence done and remounted. Came out pretty nice, but light was dark as it was dusk so I will take a good look tomorrow..
Trizzuth is offline
post #18 of 178 Old 12th October 2017, 03:55 AM
Ibmotoren
Ibmotoren's Avatar
Or a curb. Yeah that's bent well. Check out this pic from Redshift. Should lay nice and flat.
Looks like your right side, which would be PN 51717892186. Probabably just want to contact Clemster over in the Parts for Sale section. I'm sure he can fix you up with a decent one for much less money.
post #19 of 178 Old 12th October 2017, 05:52 AM
Pau_Hana
Pau_Hana's Avatar
I had the same hesitation (from a stop, roll into the throttle and the car would respond, then hesitate in 1st and 2nd).
I changed the fuel filter (dated 8/02) and the hesitation went away.
This weekend- driveshaft and guibo!
Pau_Hana is offline
post #20 of 178 Old 12th October 2017, 01:31 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Originally Posted by Ibmotoren View Post
Attachment 828666
Attachment 828674
Thanks for the pic and I was already checking out Clem's thread, what a gold mine! I will reach out and see what he has..
But you have an E60 M5 correct?
I will say that I put the car immediately into sport mode this morning, and I don't know if it was a placebo effect or what from giving the car a bit of love, but it fired up and sounded more beastly than normal. Then my clutch felt great and no creaks when engaging first. Could it be that those loose and obviously rattling exhaust brackets contributed to most of the noise I was hearing in the clutch area before? Car also drive much better in 1 and 2 in Sport. I will keep an eye on things and report back.
I changed the fuel filter on several high mileage E46's and they looked totally fine when I cut them open. I am somewhat skeptical about fuel filter changes as with the plastic gas tanks in the BMW, there is no chance of residue from the car's tank, it would only be from the gas stations, and it all seems to be very clean up here in the northeast. I think they require frequent replacement of the underground tanks in most places as well, based on what I have seen in other fuel filters.
Trizzuth is offline
Feeblebob's Maintenance Diary Thread feeblebob E39 M5 and E52 Z8 Discussion 70 10th October 2016 04:18 PM
E60 M5 Maintenance Thread Black Hawk E60 M5 and E61 M5 Touring Discussion 74 8th June 2016 11:39 PM
Rust/maintenance on a 2003 in S.E.A nakmuay E39 M5 and E52 Z8 Discussion 0 30th July 2012 09:50 AM
For Sale: 2003 M5 66,000 miles CPO/extended maintenance Jenner Cars For Sale or Wanted 8 2nd August 2008 07:34 PM
Just found out MY 2003 comes with full maintenance!! Bluewater M5 E39 M5 and E52 Z8 Discussion 7 4th March 2003 06:56 PM
