Trizzuth's 2003 E39 M5 Maintenance Thread - Page 19 - BMW M5 Forum and M6 Forums
 10Likes
post #181 of 195 Old 4th June 2019, 01:00 AM Thread Starter
Trizzuth
Trizzuth's Avatar
Pics of the style 32ís in 18x9 form
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is online now
post #182 of 195 Old 4th June 2019, 01:02 AM Thread Starter
Trizzuth
Trizzuth's Avatar
Tires in and just need mounting and balancing, these are for winter so they got pirelli Cinturato Strada Sport all seasons in 265/35/18
post #183 of 195 Old 4th June 2019, 02:35 PM
TexaZ3
TexaZ3's Avatar
Looks like you might need a spacer!
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #184 of 195 Old 4th June 2019, 02:59 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Yeah, chances are high, I'm going to see what it looks like once tires are mounted up.
post #185 of 195 Old 4th June 2019, 04:52 PM
TexaZ3
TexaZ3's Avatar
Yup, but I definitely see a 10-12mm with these.
TexaZ3 is offline
post #186 of 195 Old 10th June 2019, 08:44 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Style 32's in effect, and for now, they appear to fit with no signs of rubbing the strut! I only went for a very brief test drive around the block and down the road on Saturday though, so need more seat time and a good solid highway drive.
Also, I found that with a loaded car, my right rear tire is rubbing the fender liner inside just a tad, so at least now I know where that noise is coming from when I have a full compression with 4 people in the car..
This car feels SO SO SO incredibly planted and flawless on brand new wheels and tires it's a feeling you will never forget once you can experience it. Pics are on my phone so they will be coming in here in the next post. Front gap is large, but I'm likely done with lowering my car, unless the urge becomes such that I cannot take it anymore and I end up getting some coilovers (where I will likely run into fitment issues with these wheels for SURE). So I will deal with the gap for now, after all these are my winter set...
post #187 of 195 Old 10th June 2019, 08:48 PM Thread Starter
Trizzuth
Trizzuth's Avatar
Found a decent set of old center caps that will work for now...
Iím hoping it settles a bit more once I drive around for awhile.. also may decide to put a small spacer all around just for a buffer since the front clearance is so close.
post #188 of 195 Old 10th June 2019, 11:12 PM
TexaZ3
TexaZ3's Avatar
Looks good! Surprised there was no rubbing!
TexaZ3 is offline
post #189 of 195 Old 11th June 2019, 01:00 AM Thread Starter
Trizzuth
Trizzuth's Avatar
Just took a nice long drive through some back roads and up on the highway for a bit, car incredibly solid and steering heavier due to the bigger fronts but I like it. Will pull them off in a week or so and inspect inner edge of strut and inside edge of wheel and tire to see if any rubbing..
post #190 of 195 Old 11th June 2019, 02:28 PM Thread Starter
Trizzuth
Trizzuth's Avatar
A week or so ago my "service engine soon" light came on, so I ran the codes. Got a few to come up, then several days later the light went off. So yesterday while I was waiting for my son to get done his golf lessons, I ran the codes again and will post up what I found in the next post.
EWS voltage code strange, as is the LED code for alarm..
And what's up with the tank sensor without fuel pump?
IHKA Auxiliary water pump I believe are those 2 heater valves to the right of the engine when you open the hood. Everything seems to be working ok, but maybe they are soft-failing...
Outside temp sensor may have come loose when I installed the latvian pork chops, but the temp still reads fine, so no clue why I am getting that code either...
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
BlueJ , Trizzuth
Feeblebob's Maintenance Diary Thread feeblebob E39 M5 and E52 Z8 Discussion 70 10th October 2016 04:18 PM
E60 M5 Maintenance Thread Black Hawk E60 M5 and E61 M5 Touring Discussion 74 8th June 2016 11:39 PM
Rust/maintenance on a 2003 in S.E.A nakmuay E39 M5 and E52 Z8 Discussion 0 30th July 2012 09:50 AM
For Sale: 2003 M5 66,000 miles CPO/extended maintenance Jenner Cars For Sale or Wanted 8 2nd August 2008 07:34 PM
Just found out MY 2003 comes with full maintenance!! Bluewater M5 E39 M5 and E52 Z8 Discussion 7 4th March 2003 06:56 PM
