Supercharged M5 tuning troubles - Page 4 - BMW M5 Forum and M6 Forums
 11Likes
post #31 of 51 Old 10th February 2018, 06:46 PM Thread Starter
nosferau666
nosferau666's Avatar
Guys, just wanted to let you know we find out the issue comes from improper tune. We're working on the new tune at the moment so I hope I'll return with dyno results shortly.
Jerry (gsfent), many thanks especially to you for your support!
nosferau666 is offline
post #32 of 51 Old 17th December 2018, 01:13 PM Thread Starter
nosferau666
Sorry for the delayed update, folks. I'm happy to say wе achieved great results in August (95 degrees ambient temp):
And here it is a Dragy performance report with 100-200 km/h time:
Mods list for the future contains some good headers, 88 pulley and maybe an intercooler, but I'll need a retune as well. At last I expect about 600 whp.
Cheers,
Alex
post #33 of 51 Old 17th December 2018, 07:09 PM
Silent
Silent's Avatar
Based on my past observations your torque numbers look a bit off.
How much boost, octane level and meth if any?
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #34 of 51 Old 17th December 2018, 09:38 PM Thread Starter
nosferau666
post #35 of 51 Old 17th December 2018, 11:05 PM
Silent
Silent's Avatar
Thanks for the clarification.
Seems a bit brave to tune for 100 octane, but perhaps the 100 octane gas station is close to you.
Are you running a mixture of meth or 100%?
Also, take this with a grain of salt. You will need more than headers and 2psi to hit 600 wheels. A good set of headers like Jedís, Dinanís, Evolve or Supersprint drop the manifold pressure 1-2psi and in turn will make more N/A power. This would most likely lead you to install a smaller upper pulley to bring the boost level up to where it was resulting gains of additional power.
I am not saying itís impossible, just not likely on factory internals.
I am running 10psi on 91octane with 80/20 meth and I am not close to 600 wheel. Iíll admit my tune isnít perfect and can be improved, but thatís max 10-15hp which will still leave me short of 600 wheel.
Food for thought....
Sold
Silent is offline
post #36 of 51 Old 17th December 2018, 11:18 PM
gsfent
gsfent's Avatar
I have similar numbers. Of course my TQ is in Lb./ft, not NM! But I pulled 534 rwhp with meth and a slipping clutch on a brutally hot summer day in south Florida. 92mm pulley. I am pretty sure 93 octane here is 100 octane across the pond. Frank Smith did a live tune while on the Dynojet, best tune I have ever had on any car. He said if someone could make a replacement intake for our plastic one out of something other than plasitic, we could pick up a bunch of power due to heat soak we currently have (anyone with a 3D printer out there?? ).
As to 600 rwhp, you need about 700 crank. That to me is a sleeved block and turn up the boost to double digits (and perhaps knock a little off the static compression ratio). I think about 650 crank is all you can do on a stock block without worrying about blowing it up. Supposedly, Dinan tested to about that number and backed it off a little since they were backing their S3 with a warranty!
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #37 of 51 Old 18th December 2018, 12:00 AM Thread Starter
nosferau666
I'm running water and meth 50/50 ratio.
600 whp is my optimistic target because I have a friend in Germany (my tuner) who built a 620 whp M5 with ported heads, IC, meth, 9.5 psi, otherwise stock internals. It runs strong 15k miles already without any issues. Here it is the graph before porting the heads (704 crank):
safe image upload
Tuner says the key for the big numbers is correct cam timing leading to good throw out, no only huge boost. I don't want to port the heads for sure. Still considering the intercooler, because that involves another S/C bracket, pipes, new blow off valve etc. Planning to do a few dyno runs soon in the winter to see what power puts down when it's cold outside and see the real benefits from the intercooler if any.
post #38 of 51 Old 18th December 2018, 12:01 AM
Silent
Silent's Avatar
Jerry - You prove my point. I pulled similar numbers as you did with same conditions and issues with clutch. Fast forward to Better clutch, Jedís headers, smaller Upper pulley and much more recommended by the same guy who did your tune and I gained a bit over 30whp. Hence my point about 600 wheel.
Just because one or two cars are able to hit those numbers, it does not mean every SC car has a potential of 600. Here is what iíd Say is the best way to get power out of e39 M5, find a way to keep that engine cool.
By the way, I have a better Intake and have not noticed performance gains.
Sold
Silent is offline
post #39 of 51 Old 18th December 2018, 12:12 AM
gsfent
gsfent's Avatar
Jerry - You prove my point. I pulled similar numbers as you did with same conditions and issues with clutch. Fast forward to Better clutch, Jed’s headers, smaller Upper pulley and much more recommended by the same guy who did your tune and I gained a bit over 30whp. Hence my point about 600 wheel.
Just because one or two cars are able to hit those numbers, it does not mean every SC car has a potential of 600. Here is what i’d Say is the best way to get power out of e39 M5, find a way to keep that engine cool.
If I wasn't clear, I am definitely in agreement with you about 600 rwhp. I don't know of any cars that have 600 rwhp that have not been sleeved with the exception of the one posted above(absent a race motor by Dusty perhaps--they delete VANOs and are pretty secretive about that info! ). I don't necessarily doubt the results, clearly cooling is a priority (both IC and meth). But I am not sure I want to live that close to the edge. Did I miss the AFR's? That would be pretty important here.
Frank was guessing my setup had 30-50 rwhp with better clutch, so your numbers put him in the correct range. I don't know that the headers or my bigger TB's do much for adding HP with FI. I do have the option of 88mm from 92mm for another 1-1.5 psi of boost. Right now about 8-8.5.
Maybe we can run some hoses from the AC to the plastic intake ala Dodge Demon for better cooling??? LOL
gsfent is offline
post #40 of 51 Old 18th December 2018, 12:24 AM Thread Starter
nosferau666
Well I think my car achieved pretty good results with just 8 psi and stock headers compared to another similar setups. I'm sure 550+ is not a big deal with headers, new pulleys and a retune and I'm planning to proove it. Since one healthy M5 is capable of 600 wheel I don't see a reason why I couldn't?
ESS VT3-725 Supercharged DCT E92 M3 vs Whipple Supercharged Ford GT (730WHP) DLSJ5 M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 10 27th December 2013 06:43 PM
troubles again with the car nerio02 E39 M5 and E52 Z8 Discussion 21 26th July 2011 03:43 PM
Troubles with b10v8 mityo105 ALPINABoard.com | BMW Alpina Discussion 9 14th September 2010 08:26 PM
troubles when picking up my m5 Clinic87NYC E39 M5 and E52 Z8 Discussion 20 20th September 2009 02:18 PM
SMG troubles already m6steve E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 15 2nd September 2009 01:18 PM
