Supercharged M5 tuning troubles - Page 3 - BMW M5 Forum and M6 Forums
 11Likes
post #21 of 51 Old 13th October 2017, 09:30 AM
TheShafro
TheShafro's Avatar
Aeromotive is a such a piece of sh*t. You should replace it regardless lol
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is offline
post #22 of 51 Old 13th October 2017, 03:28 PM
philly98540
philly98540's Avatar
DI'd you connect a fueL pressure gauge during the runs? Maybe pressure drops off. Tuner maybe adding fuel in upper bins in attempt to compensate for dropping pressure? This gives the spike rich, then when pressure collapses enough, it goes lean? ForgiVE me if you already checked this.
98 540i 6, VF S/C Customized to 16 psi, Intercooled, Water/Meth, ?? RWHP, Supersprint, HJS, 3" Ex, UUC Twin Disc, Wavetrac LSD, AEM FP, Aeromotive FPR, AEM Failsafe AFR/Boost, 65's w/275's, M5 Box, Eibach, M3 Shifter, Evans, 85 Deg Stat, PWM Fan, 10" Subs, B.A. speakers, Grom Aux/BT, Still Rolling as my DD!
philly98540 is offline
post #23 of 51 Old 13th October 2017, 10:29 PM Thread Starter
nosferau666
nosferau666's Avatar
I've never but it's good to be done. Just ordered a new OEM fuel pressure regulator and then I'm going to test. I have all symptoms of a bad regulator - black smoke from the exhaust, cold start stalling and (maybe) gasoline drips out of the tailpipe but I'm still not sure about the last one. Also should check the oil dipstick and see if I can smell fuel on it.
Thanks!
I was pretty happy with it until three failed dyno days. If I find it causes these headaches will be replaced ASAP.
nosferau666 is offline
post #24 of 51 Old 2nd November 2017, 03:36 PM Thread Starter
nosferau666
Ok guys, I replaced the fuel regulator with a genuine one but no difference. We still reproduce the problem at 50 degrees and 90 degrees air temp so I'm sure the fuel pump doesn't overheat. Also if it overheats that would cause runing lean not rich I believe.
I have no idea what else to replace from a mechanical side.
post #25 of 51 Old 2nd November 2017, 04:07 PM
ChrisSKillaZ
Hard to start, black smoke, running rich? What about a stuck or leaking injector? I'd pull the rail off with the injectors attached, and turn the key on and see if anyone of them start leaking fuel out of the nozzle.
Chris
ChrisSKillaZ is offline
post #26 of 51 Old 2nd November 2017, 04:13 PM Thread Starter
nosferau666
Chris
It starts up easily already. Injectors are brand new and also the issue appears just sometimes depending on something but no idea what. Today it happened in 3rd but not in 4th gear.
post #27 of 51 Old 4th November 2017, 08:28 PM Thread Starter
nosferau666
Wondering if the gas pedal sensor could be bad by a chance? I have a spare one from another M5 and considering to replace it, but doesn't look like this could cause that kind of issues. Also I have another one ECU. Does it worth to give a try?
post #28 of 51 Old 14th November 2017, 11:26 AM Thread Starter
nosferau666
My investigation shows sometimes Walbro fuel pumps cause running rich with stock fuel pressure regulators. It's possible Aeromotive to do the same. I already believe I need an aftermarket FPR... but first I'm going to test the fuel pressure.
post #29 of 51 Old 14th November 2017, 05:10 PM
gsfent
gsfent's Avatar
I think others SC cars are using Walbro and Aeromotive without issues. Most people are using the stock FPR. I know I am, although I have a different fuel setup (stock fuel pump and BAP). Focusing on a faulty FPR makes more sense to me.
Good luck tracking down the issue.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #30 of 51 Old 14th November 2017, 07:46 PM Thread Starter
nosferau666
Hi Jerry,
I already installed brand new genuine FPR with no result. That's the reason I want to measure the fuel pressure next. Any tips & tricks to do it properly? Looks like the car need to be with wide open throttle.
Otherwise you are right most people use stock FRP without troubles. I just can't accept it could be a software issue and still looking for a bad hardware.
ESS VT3-725 Supercharged DCT E92 M3 vs Whipple Supercharged Ford GT (730WHP) DLSJ5 M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 10 27th December 2013 06:43 PM
troubles again with the car nerio02 E39 M5 and E52 Z8 Discussion 21 26th July 2011 03:43 PM
Troubles with b10v8 mityo105 ALPINABoard.com | BMW Alpina Discussion 9 14th September 2010 08:26 PM
troubles when picking up my m5 Clinic87NYC E39 M5 and E52 Z8 Discussion 20 20th September 2009 02:18 PM
SMG troubles already m6steve E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 15 2nd September 2009 01:18 PM
