Supercharged M5 tuning troubles - Page 2 - BMW M5 Forum and M6 Forums
 11Likes
post #11 of 51 Old 11th October 2017, 12:49 AM
Silent
Silent's Avatar
Itís rare for TPS sensor to go bad. Iíve experienced failure of the aeromotove pump when it gets hot.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #12 of 51 Old 11th October 2017, 02:54 AM
herrubermensch
Good point. Those little Aeromotives do tend to fail when they get hot.
--Peter
herrubermensch is offline
post #13 of 51 Old 11th October 2017, 03:25 AM
gsfent
gsfent's Avatar
--Peter
Wouldn't that explain going lean, but not rich?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #14 of 51 Old 11th October 2017, 03:41 AM
herrubermensch
Probably correct, Jerry. But could be functioning erratically when hot.
--Peter
post #15 of 51 Old 11th October 2017, 10:46 AM Thread Starter
nosferau666
nosferau666's Avatar
I could try to get back to the original fuel pump but because it's runnig rich and not lean makes me think the fuel pump is not a problem. I'm going to replace the fuel pressure regulator first, although I can't explain myself how a bad regulator or something bad in the fuel system at all could cause running rich irregularly? When the FPR fails it not regulates the fuel pressure correctly and makes more fuel to pass than it should be, am I right?
The only one constant is the problem appears after similar RPMs every time.
Anyone has an idea what else from mechanical side would be good to be replaced?
nosferau666 is online now
post #16 of 51 Old 11th October 2017, 04:24 PM
gsfent
gsfent's Avatar
Unless I am not reading your graph correctly, it looks like it is running rich AND LEAN. There are two "spikes", one up and then one down. So it looks like it goes very lean (upwards spike) , then very rich (downwards spike). Perhaps it is the lean condition causing the problem? When it goes so lean, the computer is overcompensating and you get the momentary richness until the computer catches up? (remember, no O2's online during WOT). Computer should really react faster though. Can you hear any noise when it goes lean? Any knocking?
Since it happens at a certain rev range, I keep thinking less fuel pump/FPR and more CPS/Vanos. Something that causes a running change. Cam timing would do that. Have you run the Vanos test on the computer?
gsfent is offline
post #17 of 51 Old 11th October 2017, 04:48 PM Thread Starter
nosferau666
The uploaded graph is random - just one from many while we were still in the tuning process. I've got graphs without runing lean, we were able to fix it but running rich is most of the times and that's what interferes us to do a final tune.
We've done vanos test recently but looks like will need to do again just for double check.
post #18 of 51 Old 11th October 2017, 09:39 PM Thread Starter
nosferau666
post #19 of 51 Old 11th October 2017, 11:34 PM
herrubermensch
Guys what would you recommend - a stock fuel pressure regulator or aftermarket one (AEM, Aeromotive, etc.)?
Stock should be fine, but if you want to upgrade, I strongly recommend Weldon. Have to ensure you install one that can handle the 5 bar (72.5 psi) fuel pressure employed by the S62.
--Peter
post #20 of 51 Old 12th October 2017, 03:04 AM
Bimmerbear
Bimmerbear's Avatar
I use the Fuelab 53501. No issues.
Inventory | Fuelab
Bimmerbear is offline
ESS VT3-725 Supercharged DCT E92 M3 vs Whipple Supercharged Ford GT (730WHP) DLSJ5 M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 10 27th December 2013 06:43 PM
troubles again with the car nerio02 E39 M5 and E52 Z8 Discussion 21 26th July 2011 03:43 PM
Troubles with b10v8 mityo105 ALPINABoard.com | BMW Alpina Discussion 9 14th September 2010 08:26 PM
troubles when picking up my m5 Clinic87NYC E39 M5 and E52 Z8 Discussion 20 20th September 2009 02:18 PM
SMG troubles already m6steve E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 15 2nd September 2009 01:18 PM
