can Motec/Bosch etc. ECU coexist with instrument cluster control unit? - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 27 Old 21st September 2017, 10:13 PM Thread Starter
toobs1234
toobs1234's Avatar
Has anyone managed to install a motorsport ECU (Motec/Bosch etc.) and had it coexist with the stock instrument cluster ECU? I'd really like to install a Motec M1, but keeping the stock instrument cluster functional is a must for me. I imagine that the instrument cluster should only need to access a few sensor values over the CAN bus (rpm, wheel speed, oil pressure, etc.) which shouldn't be too difficult in theory. I would be in way over my head if I tried to do it, though.
I would really appreciate a reference to a pro with BMW experience who could help me out with this if you know someone.
thanks a lot, John
Dinan high flow MAF sensors
Dinan enlarged throttle bodies
Dinan headers
Dinan lightweight flywheel
Dinan by Brembo brakes
Dinan control arm monoball bushings
Dinan adjustable anti-sway bar
BBS Forged Individual wheels
KW Competition monotube dampers
KW adjustable monoball mounts
Meisterschaft titanium exhaust
Quaife limited slip differential
3.64:1 final drive
toobs1234 is offline
post #2 of 27 Old 21st September 2017, 10:34 PM Thread Starter
toobs1234
toobs1234's Avatar
As you can see from the diagram, the DME is relatively isolated from the rest of the control system and only communicates over CAN. Seems like it should be possible, but the devil is in the details.
Dinan headers
3.64:1 final drive
post #3 of 27 Old 21st September 2017, 10:35 PM
TheShafro
TheShafro's Avatar
Are you set on Motec? There's another option from another tuner; a full standalone that's plug and play and works the stock cluster. Infinite customization just like any good standalone too.
pavlotech
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is offline
The Following User Says Thank You to TheShafro For This Useful Post:
toobs1234 (22nd September 2017)
post #4 of 27 Old 21st September 2017, 10:47 PM Thread Starter
toobs1234
toobs1234's Avatar
Not set on Motec, but two things I would like to implement are water injection and shift automation, both of which can be done with the Motec M1. That said, keeping the rest of the electrical system functioning is a must for me.
thanks a lot for the link!
Dinan headers
3.64:1 final drive
post #5 of 27 Old 22nd September 2017, 05:37 AM
TheShafro
TheShafro's Avatar
Peter, @herrubermensch , is the only person I know that's running (or will run lol) Motec, and I know he's had to build a bunch of wiring. But he's also deleted half the modules in his car, IKE included.
Pavlotech is the only solution I know that will be as close to PNP for this car/engine as possible.
-Shady H.
@theshafro
'08 JZB/FR E92
lllM3
The Following 2 Users Say Thank You to TheShafro For This Useful Post:
post #6 of 27 Old 22nd September 2017, 09:36 AM Thread Starter
toobs1234
toobs1234's Avatar
Thanks a lot for the link! I had a chance to take a closer look and that's a pretty cool product. Seems a lot of work went into interfacing with the rest of the car, which would not be feasible for a one-off project.
The Emtron ECU they use has water control and full closed loop shift control, so it's perfect!
Dinan headers
3.64:1 final drive
post #7 of 27 Old 22nd September 2017, 05:50 PM
xrviz
xrviz's Avatar
xrviz is offline
post #8 of 27 Old 23rd September 2017, 12:04 AM
herrubermensch
Emtron is a great plug and play solution, and the people behind it are good people. That said, it does not even compare to the power and flexibility of a Motec M190. The M1 series ECUs essentially allow you to do whatever you want--you write you own firmware either from scratch or modify the code of an existing package. Knowing your project, John, I think you want the M190. It absolutely can be made to interface with the stock cluster. I know the guy who successfully married the E46 cluster and a Motec M150 and can hook you up. The M190 will take more time to install and program, but will be infinitely more fun and flexible in the long run. And you would get the benefit of all the work I have done in getting it to work with an S62!
Best,
Peter
herrubermensch is offline
The Following User Says Thank You to herrubermensch For This Useful Post:
toobs1234 (23rd September 2017)
post #9 of 27 Old 23rd September 2017, 12:06 AM
herrubermensch
I think that's correct. The AEM Infinity probably falls somewhere between the Motec and the Emtron in terms of its PNP qualities.
I deleted all my modules and all the related crap wiring in both my M5 and my M3. Running an M190 in both now!
--Peter
post #10 of 27 Old 23rd September 2017, 01:53 AM Thread Starter
toobs1234
toobs1234's Avatar
Please do hook me up, Peter. I would love to have the ability to write my own strategies. I would also LOVE to realize maximum benefit from your pathbreaking activities! I have too much on my plate, though, to be getting into bus protocol details.
If it can be done for an E46, I suppose it will also be possible for the Z8. The MSS54 and MSS52 are pretty similar and probably use the same formats, but perhaps different addresses.
thanks again, John
Dinan headers
3.64:1 final drive
My 2000 m5 instrument cluster is reading dim and rpm and fuel gauge wont and reads in german and climate control is in celcius after clutch swap MalikSaab E39 M5 and E52 Z8 Discussion 3 7th February 2015 11:46 AM
E60 For Sale: E60/E63/E64 Instrument Cluster (Gauegs) & HVAC Unit (Heater Control) SlammedM6 Parts / Other For Sale or Wanted 9 17th November 2013 07:50 PM
BMW M models' ECU (Engine Control Unit) pictures rolren E60 M5 and E61 M5 Touring Discussion 21 6th January 2009 09:51 PM
Cruise control on instrument cluster BostonRocket E60 M5 and E61 M5 Touring Discussion 13 29th January 2006 07:35 PM
ECU, EML, DME control unit and chips etc... jack880 E34 M5 Discussion 2 1st October 2004 01:31 AM
