2000 Imola M5 Journal/Build Thread (Long and picture heavy) - Page 4 - BMW M5 Forum and M6 Forums
 57Likes
post #31 of 178 Old 28th September 2017, 12:56 AM Thread Starter
TexaZ3
TexaZ3's Avatar
I just made sure the fitment was good. Didn't require much cutting, i guess trimming would be a better word.
My fender liner on driver side looks like it has been replaced at some point, pass side is ok, but has one ear gone, and couple of cracks in it, so a good candidate to be replaced.
Not the priority right now, are OEM pieces reasonable in price or there is another source?
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #32 of 178 Old 28th September 2017, 02:08 AM
amancuso
amancuso's Avatar
They are ridiculously expensive as OEM. Aftermarket pieces are much cheaper but are ill fitting.
2003 M5/Sport Imola/Imola
amancuso is offline
post #33 of 178 Old 28th September 2017, 02:44 AM Thread Starter
TexaZ3
TexaZ3's Avatar
https://www.ecstuning.com/b-genuine-...t/51718159424/
Looks like $70 per, which is not too bad for OEM. Unless you were talking about the porkchops, then yes, those are effing joke.
TexaZ3 is offline
post #34 of 178 Old 28th September 2017, 03:52 AM
amancuso
amancuso's Avatar
Yeah, the chops.
amancuso is offline
post #35 of 178 Old 28th September 2017, 07:36 AM
kiznarsh
kiznarsh's Avatar
Yeah I bought my fender liners and some underbody plastic panels from ECS, but also bought a bunch of parts from Pelican. I'm close to them so the 1-day free shipping deal is pretty sweet.
Don't forget about getting new pop rivets for the fender liners. The ones on the back are pretty much consumables.
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
post #36 of 178 Old 28th September 2017, 06:51 PM Thread Starter
TexaZ3
TexaZ3's Avatar
As promised, more on the interior – I think at this point I would consider interior 99% finished – I’m still waiting for fresh set of floormats and a tiny black cover that goes over the screw in the rear door handle.
Other than that, its all done. I might change instrument cluster to a correct black one at some point later on, but right now this is not a priority.
So, both rear and passenger side rear quarter window sunshades were not functioning right. In the case of door shade, it was a typical problem with the plate holding the tab being broken, as was evidenced by the attempted fix by somebody else once I removed the shade:
I have reinforced the tab with some hot glue, wound back the spring, and re-installed the shade back on the door. Works great again!
The rear shade motor was working fine, but the culprit of these mechanisms was always those tiny plastic tabs that slide in the shade rail, they ALWAYS break off. Pretty weak design by BMW if you ask me. Of course, mine were broken off when I purchased the car, and the guides were sticking up (and tore up holes in the tint on the back window!)
What I have discovered when I started looking at the shade itself, was that one of the rollers on the driver side was missing as well.
So, I have ordered OEM roller set, but for the tabs I decided to go with something a little sturdier than OEM – a precision CNC-machined set of tabs with allen screws and lock nuts made from aluminum. Pretty much guarantees I never have to deal with this problem ever again on this car.
Both showed up last night and I have installed both to fix the shade. CNC tabs are absolutely awesome product – highly recommended. Fit great, feel even better – if anyone wants details on eBay seller – PM me. They were $37 shipped so not too bad compared to OEM plastic junk.
The trickiest part was to drill out the old rivets, which I have accomplished by sliding a piece of wood under the old guide rail to avoid putting my drill bit through the window.
Once both sides were drilled out, I have used 6mm socket and a 3/32 allen wrench to lock the new aluminum tabs in place.
After that, it was just a matter of screwing the rollers back on the rail, and making sure the tabs are greased properly. It lives – rear sunshade is back in business – hopefully for good.
Finally, I have tackled the notorious front cupholder. Just replaced the broken one with the OEM I got cheap on eBay. I never going to use it anyway, but wanted this fixed.
With the interior complete, I plan to switch over to the underhood/engine area and replace windshield cowl, some firewall covers that have completely disintegrated, plus address few other minor issues there as well. Stay tuned!
TexaZ3 is offline
post #37 of 178 Old 28th September 2017, 07:13 PM
lovepow
lovepow's Avatar
Worst placement of a cup-holder ever.
2000 BMW M5 Titanium Silver
2002 Nissan Frontier XE
2011 Infiniti FX 35 (wife)
lovepow is offline
post #38 of 178 Old 29th September 2017, 01:20 AM Thread Starter
TexaZ3
TexaZ3's Avatar
TexaZ3 is offline
post #39 of 178 Old 29th September 2017, 05:19 PM Thread Starter
TexaZ3
TexaZ3's Avatar
Question for the masses - what is the best shock/spring combo used nowadays? Probably need to refresh the suspension with all the bushings and links, but wanted to settle on shocks and springs first. Just go with stock Sachs and use stock springs (cheap), or go with Bilsteins and H&R springs to lower a bit? What's the consensus? Don't want to go coilovers and such as I want to keep the car close to stock ride height and feel. Thanks!
TexaZ3 is offline
post #40 of 178 Old 29th September 2017, 05:22 PM
mac214
mac214's Avatar
May also consider Koni/Stock or Koni/Dinan. Stock/stock always seems to be a very popular option as can be seen by the number of people that went aftermarket and ended up reverting back to OEM.
Here is an extensive suspension thread that has/had pics of different suspension set-ups.
The Suspension Thread – Popular coilover & spring/shock setups compiled here
https://r.tapatalk.com/shareLink?sha...0&share_type=t
2000 M5 Carbon Black/Black
1999 540i/6 Oxford Green/Sand Beige
2001 Ford F-150 King Ranch
mac214 is offline
Modded 6 Speed E60 M5 Photo/build Journal (Cold M3) cold m3 Owners Gallery 27 5th February 2019 10:46 PM
Enthusiast Details NYC ongoing detailing thread(Picture heavy) Fation Syla USA Northeast Forum 4 23rd October 2014 01:59 AM
Journal Entry 1 - Avus Blue 2000 M5 JTB E39 M5 and E52 Z8 Discussion 9 10th September 2008 08:58 PM
Journal Entry 1 - Avus Blue 2000 M5 JTB Owners Gallery 6 9th September 2008 03:43 PM
Timeline of E60 M5 Build--How Long it Takes from Build to Drive MJ E60 M5 and E61 M5 Touring Discussion 38 21st October 2005 02:43 AM
