2000 Imola M5 Journal/Build Thread (Long and picture heavy) - Page 17 - BMW M5 Forum and M6 Forums
 54Likes
post #161 of 174 Old 29th October 2018, 08:08 PM Thread Starter
TexaZ3
TexaZ3's Avatar
There are quick connects on both sides, BUT! The "front" side also have the pressure regulator and a vacuum line connected to it, so I suggest to leave it as is, and just unscrew the filter from the regulator. You will need two pretty large wrenches (don't remember the sizes off the top), or a wrench for the filter and a channel locks to hold the regulator. Also, put a copper crush washer between the filter and a regulator to prevent leaks.
Quick connects do not require any tools, I just used needle -nosed pliers to push it in. Also, on the regulator, there is a valve to release fuel pressure, I suggest you do that before disconnecting any lines. Alternatively, you can pop the fuel pump fuse and start the car and let it run until it dies.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #162 of 174 Old 11th November 2018, 10:36 PM
cncmastr
cncmastr's Avatar
I gotta do my fuel filter next, after I tackle Transmission fluid change.
2001 DINAN S2 M5 - Imolarot
Blog: http://www.obsessedmotorsport.com/blog
E30 318is
E46 M3
E53 4.8is
F31 328xi sports wagon
E39 M5 S2
http://obsessedmotorsport.com/blog/
cncmastr is online now
post #163 of 174 Old 19th March 2019, 01:11 PM
Trizzuth
Trizzuth's Avatar
Curious how your leather is holding up after the leatherique treatment and that other stuff you put on? I did leatherique on mine immediately after I bought it and it takes the beating from my *** daily and still looks amazing. Definitely doing it again this summer once it gets hot.
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is online now
post #164 of 174 Old 19th March 2019, 03:55 PM Thread Starter
TexaZ3
TexaZ3's Avatar
Its holding up just fine, but its no surprise really, I have been using leatherique and been impressed with it for many years. I don't drive the car as much as I probably should, though.
The leather in E39 is the softest napa I have ever seen, and I'm starting to wonder if it was ever processed to the same degree as leather in later cars, since it responds to leatherique so well.
In any case, yes - yearly treatments are recommended to keep it up.
TexaZ3 is offline
post #165 of 174 Old 3rd June 2019, 10:23 PM Thread Starter
TexaZ3
TexaZ3's Avatar
Finally did my PS reservoir and hoses yesterday. I had a slow drip, but over time it has apparently developed into a bigger drip, until one day I lost some of the fluid that made my pump sound like this:
So it was time to address that. Bought replacement kit at FCP:
Fluid was leaking both at the reservoir and at both hoses connections, which suggested just really old hoses and possibly cracked tank itself. Disassembly started:
Hoses were original. Soaked:
Ripped it out:
That’s pretty bad!
New reservoir and hoses are ready:
New o-rings:
And all bolted up to the cooler:
And to the pump:
Flushed and re-filled the system. No more fluid on the floor! Steering is also super quiet with the new fluid.
TexaZ3 is offline
The Following 2 Users Say Thank You to TexaZ3 For This Useful Post:
KevinM (5th June 2019)
post #166 of 174 Old 4th June 2019, 01:22 PM
Trizzuth
Trizzuth's Avatar
That's pretty awesome right there...
I did this on several E46's, and it's funny, there was this long time theory where people felt that any power steering leaking down from the reservoir was just from the cap "relieving itself" of pressure through the tiny hole where the ribs are where you grab. I think there was an extremely extremely long thread about that, people claiming it was the reservoir, swapping that out, problem solved, etc. You know what it was all along? Just a bad O-ring in the cap. Like a $0.60 part, HA. So if you ever see it weeping from the top and running down the reservoir, replace the O ring first and you may be good to go for many thousands of miles more, but clearly in your case the hoses were shot! Job looks pretty simple..
Did you clamp everything hose-wise outside of the car so it matched the original layout? Appears like you did that, and was wondering why, rather than connecting the hoses down low, and having the clamps loose so they could still move a bit and then clamping them once everything is all mated up...
post #167 of 174 Old 4th June 2019, 04:57 PM Thread Starter
TexaZ3
TexaZ3's Avatar
Yeah, I tried the gasket trick first (I had an old cap, which wasn't leaking), and it didn't help. Overall, the reservoir and hoses were not that expensive to fix the annoying leak.
I did clamp everything outside, and just dropped the hoses from the top - I did line them up so all bolted down perfectly. There is really a lot of room there to work, but I guess could be done either way.
TexaZ3 is offline
post #168 of 174 Old 4th June 2019, 08:54 PM
kiznarsh
kiznarsh's Avatar
kiznarsh is offline
post #169 of 174 Old 5th June 2019, 01:02 AM Thread Starter
TexaZ3
TexaZ3's Avatar
Originally Posted by kiznarsh View Post
See, I told you it was the pump!
Yeah, you we right, definitely was the pump whine starving on the fluid and gulping some air.
TexaZ3 is offline
post #170 of 174 Old 5th June 2019, 01:09 AM
kiznarsh
kiznarsh's Avatar
Wait...no, I was wrong! I thought you had a faulty pump, but it was just your hoses and reservoirs. Much easier fix.
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
Modded 6 Speed E60 M5 Photo/build Journal (Cold M3) cold m3 Owners Gallery 27 5th February 2019 10:46 PM
Enthusiast Details NYC ongoing detailing thread(Picture heavy) Fation Syla USA Northeast Forum 4 23rd October 2014 01:59 AM
Journal Entry 1 - Avus Blue 2000 M5 JTB E39 M5 and E52 Z8 Discussion 9 10th September 2008 08:58 PM
Journal Entry 1 - Avus Blue 2000 M5 JTB Owners Gallery 6 9th September 2008 03:43 PM
Timeline of E60 M5 Build--How Long it Takes from Build to Drive MJ E60 M5 and E61 M5 Touring Discussion 38 21st October 2005 02:43 AM
