Another Forced Induction Build Done Right! - Page 7 - BMW M5 Forum and M6 Forums
 184Likes
post #61 of 90 Old 1st November 2017, 02:59 PM Thread Starter
herrubermensch
Originally Posted by Patrick_Arnold View Post
Affirmative. I'm happy to check.
Bulldogee rocks the pulley world. He also made my aluminum bumper shock mounts. World class fabricator.
--Peter
herrubermensch is offline
post #62 of 90 Old 1st November 2017, 03:33 PM
boris1
Fantastic build thread. I just wanted to understand what is the benefit of removing the oil cooler?
boris1 is online now
post #63 of 90 Old 1st November 2017, 03:42 PM Thread Starter
herrubermensch
Thank you!
Can of worms, here, as there are divergent views. Our view, shared by many who have spent a lot of time trying to extract power from the S62, is that the under-plenum oil heat exchanger heats up the metal plenum and thus, increases AITs, without any corresponding or offsetting benefit. Replacing it with an external oil cooler provides the cooling benefit without increasing AITs. Now, to be sure, the heat exchanger also serves to heat up the oil after startup, but on sleeved motors, race motors and other higher performance S62s, that generally is not an issue.
--Peter
post #64 of 90 Old 1st November 2017, 04:16 PM
boris1
Thanks for the prompt response Peter. I figured there had to be a good reason for BMW engineers to put it there in the first place. I guess they weren't thinking about future forced induction mods.
post #65 of 90 Old 1st November 2017, 04:16 PM
CSBM5
CSBM5's Avatar
Yeah, I'm always amazed at the blast furnace that is the E39 M5 engine compartment. Starting way back in time here with greg's thermocouple data gathering to living with it now for the past 14 years. I've always opened the hood every time I park the car in the garage to not allow underhood temps to soar and bake everything. The lower plenum is hot as fire most all the time.
There's a profound difference compared to the E90 M3 with the S65 and its external, lower mounted, oil cooler and I suppose better airflow management through the engine compartment. It's nowhere near as crazy hot underhood, even after driving very hard.
Current stable:
CSBM5 is offline
post #66 of 90 Old 1st November 2017, 04:43 PM
gzig5
I know it is very tight under the hood and more so with a supercharger, but has anyone looked at piping fresh air to the under plenum area to get some active cooling going? Even if you could get some air to the lower front of the plenum, I'm not sure there is a good exit path for it. The hood is sealed to the firewall, so the air can't go up and looks like it would need to go down along the transmission tunnel. Time for some louvers on the back of the hood along the windshield?
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #67 of 90 Old 1st November 2017, 05:09 PM
CSBM5
CSBM5's Avatar
Louvers there would result in inflow, not out. There is a large region of separated air in the zone at the back of the hood/base of windshield in all cars where you get a lot of "pressure recovery" (aero speak for the difference in surface static pressure versus the stagnation point total pressure on the front of the body (car in this case)). The recovery ratio is very high, over 90% in most cases, so that region is a fantastic location for cabin air inlets and engine induction inlets.
If you do anything with the hood, you have to vent it nearer the low surface pressure zone (high surface velocity) near the peak of its curvature up from the front. It's possible to vent radiator air out there as you'll see on many other cars (and some race cars). How that effects the remainder of the car's Cd and Cl is "an exercise for the student."
Current stable:
CSBM5 is offline
post #68 of 90 Old 1st November 2017, 06:28 PM
Patrick_Arnold
Patrick_Arnold's Avatar
Originally Posted by TheShafro View Post
That's sick. So you can change the supercharger portion by unbolting? Is that person/place willing to make more?
@TheShafro , Mark's contact info, aka "Bulldoggee", who designed/built my pulley, is: [email protected]
Patrick_Arnold is offline
post #69 of 90 Old 3rd November 2017, 05:25 AM Thread Starter
herrubermensch
Almost done!
A few pics before we finish up!
Valve covers came out nice in matte red!
post #70 of 90 Old 3rd November 2017, 05:27 AM Thread Starter
herrubermensch
Forced Induction Build Done Right herrubermensch E39 M5 and E52 Z8 Discussion 161 3rd September 2017 07:49 PM
Forced Induction? Please inquire... bmdblyou E39 M5 and E52 Z8 Discussion 72 9th June 2013 03:08 PM
Forced Induction for E39 M5's dragonflyjones E39 M5 and E52 Z8 Discussion 18 10th September 2008 08:06 PM
Forced Induction alquazi E39 M5 and E52 Z8 Discussion 26 3rd April 2008 05:25 PM
S85 Forced Induction? M4Motoring E60 M5 and E61 M5 Touring Discussion 24 29th April 2007 02:41 PM
